Old Feb 13, 2012, 02:46 AM
lemel_man
lemel_man
Guest
n/a Posts
Inverter went BANG
A friend has a Mitsubishi S520E inverter on his lathe. When he switched
it on the other day it went BANG and now (unsurprisingly) no longer works.
Is there a fuse or something that can be replaced relatively easily, or
is it unrepairable?
Regards, Gary Wooding
(To reply by email, change gug to goog in my address)
Old Feb 13, 2012, 03:25 AM
Andrew Mawson
Andrew Mawson
Guest
n/a Posts
Re: Inverter went BANG
"lemel_man" wrote in message news:jhaf55$j6k$1@dont-email.me...
>A friend has a Mitsubishi S520E inverter on his lathe. When he switched it
>Is there a fuse or something that can be replaced relatively easily, or is
>it unrepairable?
Input diodes, main reservoir capacitors and or output mosfets or their
equivalent I would say in that order however if an input diode goes short
circuit it usually takes the capacitor(s) as well.
AWEM
Old Feb 13, 2012, 05:15 AM
Ian P
Ian P
Guest
n/a Posts
I had the same symptoms with a Siemens VFD but in my case I was able to
repair it easily.
A 'Varistor' (or whatever surge protective device it is) was wired across
the incoming supply and had shorted and burned before blowing the fuse.
Since there were two other identical devices (to cater for 3 phase input) I
was able to replace the failed one. It still leaves me a spare because I
will never have 3 phase input.
Ian
"lemel_man" <binswood@guglemail.com> wrote in message
> it unrepairable?
Old Feb 13, 2012, 07:51 AM
lemel_man
lemel_man
Guest
n/a Posts
On 13/02/2012 07:46, lemel_man wrote:
Thanks for the feedback guys; I'll report back on the outcome.
Old Feb 13, 2012, 10:46 AM
news.plus.net
news.plus.net
Guest
n/a Posts
> repair it easily.
> Ian
> "lemel_man"<binswood@guglemail.com> wrote in message
>> it unrepairable?
If the Varistors have gone then it may have talen out the PCB tracks too
in which case it's a bin job. Was the drive overheating? Normally they
last for ever in an application like yours where the duty factor is light.
Can you see what's blown up? I'm an ex drives designer and may be able
to help.
Rob.
Old Feb 13, 2012, 02:47 PM
Ian P
Ian P
Guest
n/a Posts
Rob
I was fortunate with my Siemens drive in that the tracks were not damaged.
On another power board there was quite a bit of metal/carbon coating
deposited by the exploding varistor. I dremelled clearance gaps and then
varnished the area.
I know the manufacturer would have scrapped the drive so I had nothing to
lose with my 'bodge' repair. On the other hand, I have a large brushless
servo motor and drive that blew its fuse (appeared to be caused by the DC
bus or a capacitor shorting) Its cleared itself now still does not work. I'm
loathe to write it off but the cost of repairs seems to be geared to what
companies will pay to keep a machine running rather than to what the repair
would actually cost.
Ian
"news.plus.net" <me@here.com> wrote in message
news:f7idnYh4oaHtraTSnZ2dnUVZ7rmdnZ2d@brightview.c o.uk...
>> repair it easily.
>> I
>> Ian
>>> it
>>> is
>>> it unrepairable?
> Can you see what's blown up? I'm an ex drives designer and may be able to
> help.
> Rob.
Old Feb 14, 2012, 06:13 AM
news.plus.net
news.plus.net
Guest
n/a Posts
On 13/02/2012 19:47, Ian P wrote:
> Rob
> varnished the area.
> Ian
> "news.plus.net"<me@here.com> wrote in message
>>> repair it easily.
>>> I
>>> Ian
>>>> it
>>>> is
>>>> it unrepairable?
>> help.
>> Rob.
When you power it up does it not go bang now? Are you able to tell if
the DC link has any volts on it. If the input fuses have gone then it's
normally the IGBT bridge that has gone pop. Input rectifiers don't
normally fail unless you have been single phasing a three phase drive.
If you over do a three phase drive on single phase then you will shag
either or both the DC link cans or the recitifer. On drives i've done
the processor looks at the amount of DC link rippe to determine of there
is a phase lost whereupon it will issue a "phase trip" and disable the
output.
Normally what happens is the IGBT bridge goes, which then normally takes
out the gate drive eletronics. If that happens then it *really* is not
worth mending.
Drive manus normally only repair anything over 20kW. Anything smaller
generally is scrapped and replaced.
Sincerely,
Rob.
Discussion Chitty Chitty Bang Bang Heading to Auction MtnGoat Life, The Universe, and Politics 18 Apr 27, 2011 02:12 AM
Discussion HeadPlay goggles went out with a bang LHTPlane FPV Talk 9 Apr 10, 2011 06:02 PM
Discussion My controller went bang kd4lyh Power Systems 4 Mar 16, 2010 03:14 PM
Discussion My controller went bang kd4lyh Electric Ducted Fan Jet Talk 1 Mar 15, 2010 11:40 AM
3D Pro Brushless motors went bang nick.parker Micro Helis 7 Jul 19, 2005 09:35 PM
