Toggle switch -heavy duty replacement
I was watching an F3J video from Les Stockley from NZ and he showed that he replaces his slider radio switches out for heavy duty toggle switches. Claims cycles move from 5000 to 50000 by moving to a high quality toggle.
http://electrical.hardwarestore.com/...-switches.aspx My question is do any F3J guys use these and do you use a three pole or two pole and not hook up a charge lead through the switch as traditional.
Any advice would be appreciated, I know the slide switches are not good but what are some of your experiences. Thanks |
I put one of these in my Sprite 2M: http://www.frys.com/product/2860284
In the off position I wired the charging jack; the on position goes to the RX. Feels very solid and easier to use than a slider. |
Here's somebody elsr that uses a toggle http://kevin-newton.blogspot.com/2001/01/switches.html
Seems like a good idea. Dave |
Well here is something new and interesting I ran accross at Planet Soaring
Magnetic switch http://zepsus.com/magnetic-switch/ |
| Thread Tools | |
| Discussion Spektrum Dx6i Trainer Toggle Switch Replacement | rarner | Radios | 4 | May 18, 2012 10:27 PM |
| Sold Maxx Products Heavy Duty Charge Switch | krossk | Aircraft - General - Radio Equipment (FS/W) | 0 | Nov 02, 2011 07:47 AM |
| Question Can I replace the trainer toggle switch with a DPDT toggle switch in a Futaba EX6AP? | shawn595 | Radios | 2 | Jan 01, 2011 04:50 PM |
| Help! Futaba Skysport 6YG - D/R replacement toggle switch | Dr Kiwi | Radios | 4 | Oct 30, 2006 06:37 AM |
| Rave Standard and Heavy Duty Switch Harnesses | plasmaman | Aircraft - General - Radio Equipment (FS/W) | 6 | Dec 31, 2004 10:50 AM |
