| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 |
Crash Master
WattAge Crazy Max 3D
Well, Anybody know anything?
All I know is the news release in RCM October. I want to check one out. Haven't seen any reviews and can't find any info anywhere else. I'm chomping at the bit! |
#2 |
heli on the brain
...you mean the 'crazy 8'? i was at hobbie people and asked about it yesterday and was informed that its scheduled for release around thanksgiving. it looks like a fun aerobat, full arf, pre covered and almost ready to go....price is $89.
...btw, if its the same plane youre talking about, its far from a slowflyer! Last edited by dezflyer; Nov 01, 2001 at 01:51 PM. |
#3 |
Crazy Max and Crazy 8 are different
Crazy Max is a Mini Max with a reinforced tail, fuselage, and a fully symmetric wing. It uses the 370 motor and gearbox (instead of the standard 280). On 8 of our 800mAH NIMH AAA cells, it has super vertical and is really really fun flyer for small fields.
The Crazy 8 is an all wood aerobatic plane designed for the growing popularity in 450-480 size motors like the Multiplex Turbo 450, Velkom 2027, or MPI Cobalt 400. We originall flew the Crazy 8 with the turbo 450 and 800AR's but with the availability of the CP1300 cells, the flights and flight times are even better. Both are due around the end of November. -Mike |
#4 |
Genebond, are you talking about the minimax with ailerons? I believe this is what you are talking about.I seen it in rc microflight ,but like you I cannot find anything on it. Like you I would like to find about it to,if anybody has any info. Vest Regards deeejay
#5 |
Here is the gallery page for the Crazy 8
http://www.hobbypeople.net/gallery/128427.htm Gallery Page is not yet done for the Crazy Max Here's some specs: Specifications: Span: 35 inches Wing Area: 284 sq. inches Length Overall: 26 inches Weight, ready to fly: 12-13 ounces Wing Loading: 6.1-6.75 ounces per square foot Equipment Needed: 4 channel Radio with Micro Equipment (computer radio recommended if using separate aileron servos, but not necessary) (3-4 CS-10 servos-according to aileron setup, Cirrus Micro Receiver 15-30 Amp ESC (Wattage IC-15A or 30A according to setup) 8 cell, 800 mah Nimh 5/4 AAA battery pack (Wattage 128538 Charger (Wattage 1 amp peak charger recommended) -Mike |
#6 |
Genebond
I've looked all through my oct RCM and can't find it-could you tell me a page number. I have just retired my mini max fuse but after 5 planes I finally learned to fly on the mini so instead of another mini-max I would love one of these crazy max's. Long live the mini-max! Thomas |
#7 |
registered user
Here's a picture of it...no price listed yet.
#8 |
The price is 49.99 through Hobby People Mail Order. I'm sure our dealers will have similar pricing.
#9 |
Love the fact that I now have proof that Joe Stalin flew r/c!
#10 |
Crash Master
Mike: Thanks for the info! I'll be in line for it. The LHS can get it through Global I assume... Too bad the CS-10's are out of stock, had to buy some SL110's (expert). 15-30A? Wow! Must be some *serious* vertical!
Thomas: Top of page 12. My MiniMax now has ailerons, but the weather's too bad to test! Built a BluCor wing for it, worked OK in the front yard, but too much wind and backwards servo! You aught to try the MiniMax Motor/gear on a LiteStik -- what a blast. 2 tie wraps to the top of the stick and let 'er rip... (use a 5a ESC) Later! |
#11 | |
Mike, what will the gear box ratio be? If you can offer like a 5:1 and a 6 V 400 plus enough ground clearance for a 13 x 6 you will get it to hover on eight 500s. That would be the killer backyard flyer. Andre |
#12 |
400!!!!
The Crazy Max comes with the same gearbox housing as the Mini Max.
But inside is a 6 volt, 370 motor and a 3.67:1 gear ratio. On 8 cells (5/4AAA 800nimh) and our stock prop using lightweight equipment it will not quite sustain hover. However the speed is great and overall flight is exciting. Takeoff roll is almost zero. But with the switch to the APC SF prop, we've been hovering no problem. As for the ESC, the motor stock is pulling under 15 amps static so 15 is reasonable. However, if you go to individual aileron servos, the 1/2 amp current capacity of the BEC in the 15A is too small so you have to bump to the 30 amp. Most 30 amp ESC's have a 1amp power supply which will take the load of 4 servos. I'm pretty sure the Crazy Max would handle the 400 but the weight of beefing up the fuselage, plus the larger motor, gearbox, and batteries might negate the advantages. The higher wing loading could kill the cool slowflying capcity of the stock airplane. It is big fun! -Mike |
#13 |
are the crazy max's on sale yet? I can't wait to own one!
#14 |
The shipment is expected here by December 1.
I am hoping to get it here for Thanksgiving. It is all up to how long it takes to get them through customs. -Mike |
#15 |
Crash Master
Got one on B/O through LHS through Global...
Will advise!!!!! |
| Thread Tools | |
| NIB Wattage Crazy Max 3d | Bud Morrison | Aircraft - Electric - Airplanes (FS/W) | 1 | Aug 10, 2003 10:25 PM |
| FS: Wattage Crazy Max 3D Park Flyer New in Box | Spaulding | Aircraft - Electric - Airplanes (FS/W) | 6 | May 14, 2002 01:02 PM |
| Wattage Crazy Max 3D | PunkerTFC | Electric Plane Talk | 20 | Jan 29, 2002 06:44 PM |
| Crazy Max 3D is a winner! | Andreas | Parkflyers | 9 | Jan 02, 2002 09:55 PM |
| Crazy Max 3D ROCKS!!! | ls77 | Parkflyers | 4 | Dec 13, 2001 01:27 AM |
