Old Feb 12, 2012, 03:48 AM
johnIn2SonAZ is offline
Find More Posts by johnIn2SonAZ
Tucson,AZ
Joined Dec 2007
DJI F550 Hexa Custom Build by AddictiveRC
I just finished a Custom Build Using the New DJI F550 Hexa frame and Naza FC by DJI as well.
Specs of the Build:
Frame: DJI-F550 Hexa 550mm
Controller: DJI-NAZA
Motors: DJI 2212 920Kv
ESC's: DJI 18amp
Props: Graupner 10 x 5 E-Prop
Landing Gear/Camera Mount: XAircraft (with Modified DJI Lower Chassis)
TX: DX8
RX: AR8000
LiPo: 3S 6000mah (11min Flight Time)
Results:
Very Stable flight and Super easy to Fly.
I am Very Happy with this set-up.
Next: XA Camera Mount and GoPro Hero2 Installation.
We also Offer Full High-End Custom Built Camera Ships For the Amateur and Professional.
All Parts Available at RcHobbyHelicopter.com
Cheers, John W. From AddictiveRC
johnIn2SonAZ is offline Find More Posts by johnIn2SonAZ
Site Sponsor
Old Feb 16, 2012, 04:51 PM
Socratic is offline
Find More Posts by Socratic
United States, NH, Barrington
Joined Sep 2011
About ready to order but......
Just about ready to buy one of these with the electronics but came across this review which raised a flag.....did you find this an issue?
Dji Flame wheel frame (RED / White version ) Twisting / flexing PART 2 (3 min 54 sec)
Socratic is offline Find More Posts by Socratic
Old Feb 16, 2012, 05:07 PM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Las Vegas/Lake Tahoe
Joined Feb 2010
That was Quad Addict. No one has been able to reproduce his flex with out loosening the mounting screws. I do not have the problem with my quad or my DJI hexa.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Old Feb 16, 2012, 05:24 PM
Socratic is offline
Joined Sep 2011
I picked up a Black Vortex board and thought the DJI 550 might be a good combo. When I looked at the build manual for the 550 it appeared that 3 leads are connected to the power board???? Maybe I misunderstood the picture? Does the DJI connect differently then other boards? With the esc's I have on my existing quad, I only have positive and neg connected to power board and signals wires with one hot lead going to my FC. Same with DJI? Thanks.
Old Feb 16, 2012, 05:30 PM
DJI Support
Joined Feb 2010
The bottom plate of the DJI hexa plate only has a positive and negative connection for each esc. It also includes two pads for the lipo of +/-. The signal wires from the esc's go to the Naza/WKM without the positive lead, unless you are using the OPTO escs which do not have a bec.
Site Sponsor
Old Feb 17, 2012, 10:39 AM
liteglow is offline
Find More Posts by liteglow
Joined May 2005
what is the size from motor to motor ? in cm
thank you
liteglow is offline Find More Posts by liteglow
Old Feb 17, 2012, 10:45 AM
DJI Support
Joined Feb 2010
550mm.
Site Sponsor
Old Feb 17, 2012, 10:51 AM
liteglow is offline
Joined May 2005
550mm.
Thank u.
I have the jakub frame today (990mm) !
Will the DJI HEX frame be OK to lift 3-3.5kg total weight?
And will it be big enough to use 11" props?
Old Mar 03, 2012, 10:06 PM
JoeinTenn is offline
Find More Posts by JoeinTenn
Look mom, I really can fly.
Joined Mar 2012
super kewl F550
I really liked your landing gear.
What kind of battery are you using?
Joe
JoeinTenn is offline Find More Posts by JoeinTenn
Old Mar 08, 2012, 12:50 AM
modifyit15 is offline
Find More Posts by modifyit15
Joined Nov 2006
Hey John, I have the same set up but mine is giving me oposite feedback form the input I am giving it. (ex ail left stick is lean right on the hexa F550) ELE is the same way. Forward stick is tilt back. Can you tell me your setup please?
modifyit15 is offline Find More Posts by modifyit15
Old Mar 08, 2012, 06:12 AM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Go into the software and click on the Norm button (to the right of each slider, it will change to say Rev) on the TX Calibration screen and reverse the channels that are backwards. Click Write and you should not see the sliders move the correct way.
Sid3ways is offline Find More Posts by Sid3ways
Old Mar 13, 2012, 12:47 AM
mrleenagle is offline
Find More Posts by mrleenagle
fpv addict
mrleenagle's Avatar
Sydney, Australia
Joined Nov 2007
Originally Posted by Socratic View Post
Just about ready to buy one of these with the electronics but came across this review which raised a flag.....did you find this an issue? http://www.youtube.com/watch?v=0yKy9cDKQb8
I got my 550 yesterday mand the arms are very very very stiff! I heard there was a plastic revision though
mrleenagle is offline Find More Posts by mrleenagle
Old Mar 13, 2012, 01:06 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
The material hasn't changed and the problem didn't go away.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Mar 13, 2012, 01:36 AM
Z06 Tony is online now
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
Can you READ? He just posted the arms are VERY stiff. Grab a dictionary and look up stiff.
Z06 Tony is online now Find More Posts by Z06 Tony
Site Sponsor
Old Mar 13, 2012, 05:20 AM
brodjack is offline
Find More Posts by brodjack
usual old know-it-all
Blackpool,U.K.
Joined May 2005
AND the guy in the video said it flies great,which surely is the main purpose of flying machines..
brodjack is offline Find More Posts by brodjack
Discussion DJI F550 Hex Build, with 2-axis NEX-5N/GH2 Gimbal... GGoodrum Multirotor Talk 9560 May 28, 2014 12:06 AM
Discussion want to build a Octokopter or hexa with DJI, please advice stefaanmertens Multirotor Talk 14 Mar 17, 2012 12:08 AM
Discussion UAVframe Hexa E85, PH AV200 and DJI WKM build. UAVProducts Multirotor Talk 14 Nov 21, 2011 03:39 AM
Discussion Custom Built Karbonic-X RTF Build By John W. at AddictiveRC johnIn2SonAZ Multirotor Talk 15 Oct 14, 2011 06:57 PM
Discussion KarbonicDrones Karbonic-Six Build Thread By John at AddictiveRC johnIn2SonAZ Multirotor Talk 6 Aug 26, 2011 07:17 AM
