Old Jan 31, 2013, 06:56 PM
Gregg28 is offline
Find More Posts by Gregg28
Don't lie to my dog.
Gregg28's Avatar
United States, DE, Wilmington
Joined Jun 2005
Originally Posted by breakwater View Post
Hah.
Do you want a free Whirlwind for parts?
It's fully siezed, but if you really want the electronics inside or the drum.....
Or the screw. The screw. Man, the screw. Why do we make some things so stupidly proprietary.. Like the whirlwind screw.
I guess they saw a market for replacement screws at a pence or two.
This winch is really not worth it, but the offer's on the table.
Of course I will take it! I will make you a deal. If I get it working I will send it back to you. If not, I will keep it for parts.
Gregg28 is offline Find More Posts by Gregg28
Old Jan 31, 2013, 07:09 PM
breakwater is offline
Find More Posts by breakwater
United States, MA, Wenham
Joined Jan 2007
Hah,
Well, I can Garuntee it's hopeless. Standley took it apart a few weeks ago and read it it's last rights.
It was inside a boat that was side-swiped by someone else in one of these "all classes sailed" type things and went down to davey-jone's locker. Then sat in a basement for a few years.
does that change anything?
breakwater is offline Find More Posts by breakwater
Old Jan 31, 2013, 07:12 PM
Gregg28 is offline
Gregg28's Avatar
Joined Jun 2005
Hah,
If Standley took it apart and pronounced it dead, I have to respect that. Damn, I love to fix things.
Old Jan 31, 2013, 07:18 PM
Joined Jan 2007
Yup, Bummer.
Finding a replacement winch for it was a bear. Stinks we've lost the mid-grade market.
It's more or less Hitec or RMG, no in-between.
Anyways if you want that stuff, it's yours, but it's probably better off in the dumpster. (I recycle all electronics by the way, might as well.)
Old Jan 31, 2013, 08:31 PM
klkirkman is offline
Find More Posts by klkirkman
Joined May 2012
Winch sources
Breakwater,
Consider the old Don Prough/Dumas. Buy about a dozen of them and get to some time on a milling machine and lighten the plates and gears with mucho lightning holes.
So much backlash they consume very little power.
Karl
klkirkman is offline Find More Posts by klkirkman
Old Jan 31, 2013, 09:26 PM
Joined Jan 2007
That's actually a great idea.
those are good winches, and fit the bill for the "midgrade" winch, not total junk Hitec, not pure-gold RMG
The boat this whirlwind came out of is a boat from the 90's that isn't going to win any world championships anyways, so that winch is more than suitable for club racing.. The whole goal with this peticular boat is to build the club.
Who's Holdin'
Old Jan 31, 2013, 10:03 PM
mrpenguin is offline
Find More Posts by mrpenguin
Australia, TAS, Penguin
Joined Mar 2012
.... All that foam for buoyancy adds weight!
This pile of polystyrene (packing formers from a standard 3 bay computer box) weighs 96 grams....
Enough for two one metre boats...
mrpenguin is offline Find More Posts by mrpenguin
Old Feb 01, 2013, 08:28 AM
bigpat is offline
Find More Posts by bigpat
Love RC Yachts!!!
Australia, VIC, Melbourne
Joined Aug 2012
Honestly, buoyancy foam is a band-aid solution to a fundamental problem....
If the boat is taking water inboard, why? A lek in the hull, fincas, mast tube, o deck fittings is easily traced and fixed.
If its a leaking hatch, if it can't be sealed or fixed,just use sticky back. It's cheap, and works 100% of the time. You can reuse it numerous times before it needs replacement( and its cheap anyway). Sometimes I realise that thin hulls may pump when sailing, sucking in water. In that case a 1/8" breather hole in the bulkhead, or a thin tube from the deck will help with that.
And besides, 50 grams or so of potential corrector weight is lost, and only gives moisture something else to form on....
bigpat is offline Find More Posts by bigpat
Old Feb 01, 2013, 04:33 PM
Joined Mar 2012
So is life insurance....
Old Feb 01, 2013, 04:53 PM
ToniGe23 is offline
Find More Posts by ToniGe23
ToniGe23's Avatar
United Kingdom, London
Joined Jun 2005
or these
ToniGe23 is offline Find More Posts by ToniGe23
Old Feb 01, 2013, 06:26 PM
Joined Jan 2007
Originally Posted by ToniGe23 View Post
or these
Well,
Bigpat is right. Before you address adding buoyancy, it's better to look at the boat from the perspective of WHY are you adding buoyancy and try to correct that problem first.
after that, if you must, those airbags seem like a better option.
You never want to add anything, unless you have to
Old Feb 01, 2013, 06:49 PM
Joined May 2012
Leaks and winning races
If one makes a careful study of what is required to win high level M class regattas, you will find that consistency is terribly important. I believe we concluded that having a breakdown-free Nationals was worth the difference between 1-2 places in the standings in a typical Nationals. That means things being equal, a leak free boat that is in the hunt has a much improved chance of winning over less reliable competitors.
We took it a step further and declined to use a film covered deck like some of the light weights of the day because one collision, even if you were not at fault, could lose a regatta.
Fitting flotation is, to me, closing the barn door after the horse is gone if one expects to be truly competitive.
Karl
Old Feb 01, 2013, 06:51 PM
Gregg28 is offline
Gregg28's Avatar
Joined Jun 2005
I for one can attest that you WILL NOT win a race when your sinks. It is slow.
Old Feb 01, 2013, 08:30 PM
Joined Jan 2007
You'll never finish first if you don't finish!
Old Feb 01, 2013, 09:21 PM
Mike Denest is offline
Find More Posts by Mike Denest
Brighto?
Mike Denest's Avatar
United States, DE, Newark
Joined Dec 2003
As demonstrated here.
America's Cup - Boats breaks and sinks (2 min 9 sec)
Mike Denest is offline Find More Posts by Mike Denest
Discussion Marblehead Help Needed.- Whirlwind Olympic Winch eurosystem0 Sailboats 21 Nov 03, 2015 01:09 PM
Sold Marblehead/10r/IOM etc Keel for Sale breakwater Boats (FS/W) 5 May 24, 2014 02:26 PM
Question Plans for vintage Marblehead? john_k Sailboats 4 Dec 29, 2011 02:53 PM
Discussion Homemade silicone Marblehead bowbumpers Art Gallagher Sailboats 5 Nov 12, 2011 11:06 AM
For Sale RC Marblehead racingyacht cheddarcaveman Boats (FS/W) 0 Oct 02, 2011 02:52 AM
