Closed Thread
Old Feb 11, 2012, 04:01 PM
HappyGoLucky
chochmah's Avatar
Germany, BW, Ibach
Joined Dec 2009
Small Rertacts
Hi,
I have been looking for retracts, electric or mechanic or even pneumatic for a 1.7kg plane made for takeoffs and landings on smooth asphalt surfaces at low to very low speeds (around 30km). So no grass or hard 60km/h landings.
Problem is, almost all retracts I could find had a depth (height) of 20mm or higher and the wing is only about 15mm deep.
I'm now going to try this one here: (depth 10.6mm)
http://www.overdrive-racing.de/fahrw...zfw-14g/a-782/
  • Do you think that this retract will put up with the stress of a 1.7kg plane? Could I strengthen the retract sufficently by building a plywood/resin box around it?
  • Do you know of any other retract system that fits the requirements i.e. depth of 15mm or less? I have searched on HK/Lindinger etc. for about two hours now and I was unsuccessful.
Thank you very much!
p.S.: The Nose Gear is no problem since there is a lot more space in the front.
chochmah is offline Find More Posts by chochmah
Closed Thread
Found Techone or small thing to fly in small space Bringinitallback Aircraft - Electric - Micro & Indoor Airplanes 6 Nov 17, 2011 08:01 AM
Looking for a small foamy sport plane which can take a small brushless .... Hogster Foamies (Kits) 1 May 18, 2004 07:47 AM
WTB: 2 Sub-micro servos, 3 or 4 channel TX with small RX and a small battery.. Nik-rc Aircraft - Electric - Airplanes (FS/W) 0 Oct 23, 2003 09:08 AM
WTB: Small flying wing or something that has alerions and is small Nik-rc Aircraft - Electric - Airplanes (FS/W) 3 Sep 15, 2003 01:13 AM
Small AXI vs. small Mega? nadt770 Power Systems 7 Sep 12, 2002 03:11 PM
