Old Feb 11, 2012, 03:05 PM
metalfred is offline
Find More Posts by metalfred
Falling with style
metalfred's Avatar
Canada, QC
Joined Apr 2010
Motor / ESC / prop combo for 5.5lbs plane
Hello, I am scratchbuilding my first plane and I need help with its power system. AUW estimation is about 5.5lbs, I would like to use 2 x 4S 3300mah bats in parallel, 11x7 3-blade prop, NTM 35-42 1000kv motor and a 80 Plush ESC.
I am trying different combinations on this site.
Is 2816g of static thrust enough for 5.5lbs AUW ?
Any help is appreciated.
metalfred is offline Find More Posts by metalfred
Old Feb 11, 2012, 05:07 PM
whitecrest is offline
Find More Posts by whitecrest
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
Given an average sport airframe, 6.2 pounds is plenty of thrust for a 5.5 pound plane. You may not need such a large battery for sport flying.
Here's a great calculator for problems like this:
http://www.google.com/url?sa=t&rct=j..._Jp_RA&cad=rja
Just input your plane's vital statistics. The "Help" button leads to an excellent tutorial. Good luck with your project!
whitecrest is offline Find More Posts by whitecrest
Old Feb 11, 2012, 05:12 PM
Doug Bartley is offline
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
2816 gr = 99oz thrust = 6.2 lbs. My concern here is the motors ability to handle the 11/7/3 on 4S. Check loads with a wattmeter!
A 3542/1000 Turnigy (not NTB) is good for 400watts on 3S with a 12/6/2, and no more than 550 ( I think thats pushing it). FWIW Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Feb 11, 2012, 06:22 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Doug is right... 11x7x3 on 4s will fry that motor very fast... at 141g, the 3W/g "rule of thumb" says 420W max... one of the HK reviewers measured 440W with a 12x6 APC E on just 3s!!!!!!
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Feb 11, 2012, 10:07 PM
Joined Oct 2008
I tested the Turnigy 3542/1000 with 12/6 Apc using a 2200/3S/25C Flightmax.
My wattmeter showed 430 watts in, a 30 second run made the motor luke warm on the bench. While it likely could handle a little more in the air, I left it alone at that reading. FWIW Doug B
Old Feb 12, 2012, 08:00 AM
Falling with style
metalfred's Avatar
Canada, QC
Joined Apr 2010
This is the motor.
It is supposed to be a 700 watts motor?!
Old Feb 12, 2012, 08:21 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Over-rating of cheap motors from HK is a way of life.....at 146g the 3W/g "rule of thumb" says about 440W is closer to what the motor should be asked to deal with. If you push 700W into it you may well be at <60% efficiency, so where does that lost 300W go... into waste heat, cooking your motor.
Just for fun I fudged numbers for an AXI of similar size and Kv and loaded it with ~700W input (way beyond its rating)... even then, it would still run at 75% efficiency, so it would have to dissipate only half the amount of waste heat your NTM would have to.
This AXI is more conservatively rated at only 37A max.(~400W-500W)!
Old Feb 12, 2012, 11:01 AM
Falling with style
metalfred's Avatar
Canada, QC
Joined Apr 2010
Ok thanks for your help, I really appreciate. I still have lots to learn in this field!
The only other motor I have here is a Hacker A30-10L v2 not sure how it would behave with that setup.
Basically I should buy a motor of a reputable brand for this bird.
What do you think of this 3S setup.
82% efficienty, 424watts, 10x6 2-blades, 2285g of static thrust.
Old Feb 12, 2012, 11:21 AM
Falling with style
metalfred's Avatar
Canada, QC
Joined Apr 2010
5lbs of thrust for a 5.5 lbs plane is a bit low, no?
Old Feb 12, 2012, 11:32 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
5lb should be plenty unless you intend to go vertical or hover! For gentle flying you may get away with as little as 1lb thrust per 2-3lb of plane.
Here is a passage from Jeff at headsuprc:
How do I choose an outrunner motor for my plane?
The 'watts per pound' method of choosing a motor is often used, but it's a little complex and confusing to some people. I prefer a simpler method - 'thrust to weight' ratio. For this method, you need to know two things: the actual amount of thrust a motor will produce, and the estimated weight of the plane. I provide thrust data for all of the motors that I sell, and the all up weight of a model is usually fairly easy to determine. Most models will fly with about a 50% thrust to weight ratio, so a 20 oz model would need about 10 oz of thrust to fly at a very modest level of performance. I prefer at least an 80% thrust to weight ratio, so a 20 oz plane would require 16 oz of thrust, and would fly rather nicely. Even better is a 100% thrust to weight ratio, and this is what I recommend for trainer type planes. You want plenty of thrust to get you out of trouble, and a low pitch prop to keep the speed down. For unlimited vertical performance and 3D flying, I suggest at least a 120% thrust to weight ratio, so you would want at least 24 oz of thrust with a 20 oz plane. This high level of performance is easy to achieve with todays brushless motors and Lipo batteries. When choosing your motor, keep in mind that outrunners that spin larger propellers are generally more efficient.
Jeff is a pretty experienced RC guy.
http://www.headsuprc.com/servlet/the.../faqindex/Page
Old Feb 12, 2012, 03:20 PM
Falling with style
metalfred's Avatar
Canada, QC
Joined Apr 2010
Awesome that setup will work well then Thanks a lot for the help !!!!!!!
Discussion Near silent motor/prop combo that can fly up to 1.5 KG aircraft? TheNiceGuy Power Systems 22 Dec 01, 2013 10:16 AM
For Sale new 25a brushed esc and HP 380 motor combo + motor & folding prop 19 shipped blueindian Aircraft - Electric - Airplanes (FS/W) 0 Dec 21, 2011 09:59 PM
For Sale Lazertoyz Blue wonder Motor+ESC+Prop+Gyro Combo teha99 Aircraft - Electric - Multirotor (FS/W) 0 Jul 21, 2011 07:05 PM
Question Selecting an ESC for this motor/prop combo marhar Power Systems 2 Jul 16, 2011 02:45 PM
Motor/ESC/Battery Combo for 9.5 oz 3D Plane? rmgmag 3D Flying 3 Nov 08, 2005 08:28 PM
