Old Feb 29, 2012, 09:55 PM
dedStik is online now
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
Any thoughts on releasing a blueprint? I'd be more than interested. I've built balsa but nothing like this. Are all your parts hand cut?
dedStik is online now Find More Posts by dedStik
Old Feb 29, 2012, 10:04 PM
jonquinn is online now
Find More Posts by jonquinn
USA, PA, Westmoreland Co.
Joined Aug 2008
was this from a Brian Taylor plan?
did you cover it with fiberglass cloth?
your model flies so nice, looks great too.
jonquinn is online now Find More Posts by jonquinn
Old Mar 01, 2012, 04:48 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
To answer a few questions -
Mine was based on the free plan issued with RCM&E magazine Autumn Special edition, 2010. The plan is by Tony Nijhuis, a prolific designer and builder, and still available along with a CNC cut balsa kit, plus the canopy, cowl, and exhaust stack moldings if required.
I used the basics of the plan to design my own structure using Depron foam, there is no Depron plan, I just made it up as I went along. Admittedly that, '..made it up....', was based on many years of model building and a good plan to start with.
Here's a link to the magazine's plan service, (no longer free), - http://www.myhobbystore.co.uk/produc...7-spitfire-mk5
and a link to the Tony Nijhuis web site - http://www.tonynijhuisdesigns.co.uk/
eflightray is offline Find More Posts by eflightray
Old Mar 01, 2012, 08:28 AM
dedStik's Avatar
Joined Feb 2012
That's gorgeous I just don't have enough build experience under my belt to attempt a wood to foam conversion like that.
Can't wait to see what else you build.
Old Mar 01, 2012, 02:39 PM
RogueTitan is offline
Find More Posts by RogueTitan
Foam Av8r
RogueTitan's Avatar
In Teh Garage (Rossville, GA. USA)
Joined Sep 2008
I actually have a copy of tonys spitfire plans and have wanted to build it for some time now.
RogueTitan is offline Find More Posts by RogueTitan
Old Mar 02, 2012, 05:26 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I am Mister Cool.........
......because if I wasn't, the air would be blue, (from rude words), I would have torn all my hair out, (what's left of it), and there would be a pile of Depron in the waste bin.
Why ?
As mentioned before, I had a wheel swivel about, '..then forgot to put flats on the leg for the axle shaft screw. Doh!'.
And the saga begins.......
Mark the leg to put the flat in the correct place.
Grind a flat on the leg.
Replace axle and tighten the screw.
Check for wobble. IT STILL DOES.
Tighten screw even more. STILL WOBBLES.
ARRRGG!. It's the leg itself turning slightly in the retract.
Keeps my cool
Removes servo the get at linkage, disconnects linkage, removes retract.
There is a screw inside the pivot the locks the the leg in place, it's loose.
Tighten screw, replace retract, connect link, replace servo, check the wheel clears the wheel well.
The other wheel just scrapes a little, so adjust axle slightly.
The axle wobbles a bit.
Check. Yes the other leg moves slightly in the other retract.
So,.....yes you guest...................
Right axle back on, axle back on align wheel, it moves on the leg.
The pinch screw is not tightening.
Ok I'll cut this story short.
I eventually found a better fitting pinch screw and it all works again.
The plane is still in one piece, the police were not called because of any swearing, I did keep my COOL.
I just wish this straight jacket was a nicer fit...........
Old Mar 02, 2012, 07:13 AM
Pickle72 is offline
Find More Posts by Pickle72
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
They say one size fits all?
Well I am glad you are getting it sorted out.
Good luck
Matt
Pickle72 is offline Find More Posts by Pickle72
Old Mar 02, 2012, 07:24 AM
Lanius is offline
Find More Posts by Lanius
Spain, GA, Miņo
Joined Jan 2012
Nice job!!
Lanius is offline Find More Posts by Lanius
Old Mar 02, 2012, 07:25 AM
rhysduk is offline
Find More Posts by rhysduk
Rhys - Forever Learning
United Kingdom, Wales, Nelson
Joined Feb 2007
Excellent Ray! Looks just as good as a similar sized balsa constructed Spitfire I've seen! You're building skills are simply superb
I'll keep an eye out for it whizzing around the skies down here in Sunny S.Wales
rhysduk is offline Find More Posts by rhysduk
Old Mar 04, 2012, 03:11 AM
how much is offline
Find More Posts by how much
how much's Avatar
United Kingdom, England, Wigan
Joined Jul 2011
Ray you really are the grande master of depron..
your Spitfire is fantastic... well done (again)
david
how much is offline Find More Posts by how much
Old Mar 04, 2012, 04:09 AM
headlessagain is online now
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
I know Ray has posted his MIG on one of Pontious's thread's and if you like large depron model from a later era then have a look at these from Pontious
http://www.rcgroups.com/forums/showp...&postcount=225
http://www.youtube.com/watch?feature...&v=A2H3iOX44ts
http://www.rcgroups.com/forums/showthread.php?t=1175767
He's part way through building a Supermarine Scimitar.
Andy
headlessagain is online now Find More Posts by headlessagain
Old Mar 04, 2012, 07:02 AM
tvcasualty is offline
Find More Posts by tvcasualty
Erik with a K
tvcasualty's Avatar
Toledo, OH
Joined Aug 2007
Great work! Especially on the finish details like the guns! Very clean!
tvcasualty is offline Find More Posts by tvcasualty
Old Mar 04, 2012, 12:59 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Andy
Agreed, 'Pontious' is a true master, I'm still a scratch builder, leaning as I go along, and just willing to have ago at various things.
Old Mar 22, 2012, 08:09 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Here's another video of her flying. The retracts now work fine, nice and slow, (can't see it on the video, but take my word they did look good). Also did a little aerobatics.
Sorry the video of poor quality, it was a rather dull day and quite windy, (it look off in about three feet), the wind and gusts are also the reason for one of my, "arrg!, get down you devil...", landings. (Another one ? ).
Spitfire2.wmv (3 min 16 sec)
Old Mar 22, 2012, 08:15 AM
rhysduk is offline
Joined Feb 2007
She looks lovely eflite! Really lovely... hard to believe she's made from Depron.
Discussion ESM Spitfire 72,5" Jocke Glow to Electric Conversions 89 Jul 07, 2014 04:35 PM
Build Log Depron spitfire 42" playaviation Foamies (Scratchbuilt) 26 Mar 03, 2012 07:16 AM
Question Depron vs. Insulation Foam AVIATION_RULZ Foamies (Scratchbuilt) 19 Sep 14, 2011 11:12 PM
Wanted Broken Foam (EPP/EPS/Depron/etc.) Planes Wanted uberjay Aircraft - Electric - Airplanes (FS/W) 2 Sep 05, 2011 09:49 AM
Discussion spitfire in depron finished rcta15 Foamies (Scratchbuilt) 7 Apr 21, 2011 03:10 PM
