Old Feb 16, 2012, 06:19 PM
Jim2011 is offline
Find More Posts by Jim2011
Joined Aug 2011
Originally Posted by slarys View Post
I want to order one of those but late BEVRC news stopping me to hit the buy button. I heard their website was hacked and dont know if they turned their system back to normal and is stable now. Also reading some reviews about their 0 support about returning the broken or missed items.
Anyone can advice here?
I ordered my skywalker 1900 and it was delivered a few days later.
Jim2011 is offline Find More Posts by Jim2011
Old Feb 19, 2012, 04:12 PM
Jim2011 is offline
Joined Aug 2011
Parts recommendations?
I am new to RC plane building and I want to do this one right. Since it will have several dollars in electronics inside and be flown a good distance I would like to build it as reliable as possible. Digital servo's VS regular? Larger ESC? I have heard the Scorpion motors are very efficient and reliable so I will probably go with a Scorpion motor. Any recommendations? The recommended parts are:
4 9g micro servo's
45 amp ESC with 25 to 30 cm power input wires
AXI 2814 KV920 Outrunner brushless motor
APC9060E propeller
5000 mah 4S battery
Old Feb 19, 2012, 04:13 PM
gromitvt10 is offline
Find More Posts by gromitvt10
gromitvt10's Avatar
United States, MD, Solomons
Joined Feb 2002
I'm about to order the SW 1900 from Bevrc and don't know what size carbon rod to get, they've got several choices but don't specify which one is for the regular wing and which is for the new longer wing. Or is the rod in picture for the wing? If so then i guess the other rods you can purchase are for the fuselage, in any case some one let me know what i need to
get:-) Any help would be great, thanks.
http://www.bevrc.com/accessories-carbon_c40.html
gromitvt10 is offline Find More Posts by gromitvt10
Old Feb 19, 2012, 04:49 PM
Jim2011 is offline
Joined Aug 2011
The round Carbon Fiber rod that came with my 1900 has a CF rod for the wing and it has a measurement of Inner Diameter 7.5, Outer diameter 10mm, 43 1/4 inches long (1000 mm or 100 cm). As far as an extra support that you custom install I do not know.
The CF rod for the body is 8.5mm, outer diameter is 10mm x 23.5 inches (600 mm) The 168 body is used on the 1900, it is even stamped "Skywalker FPV 1680" on the side of the body the same as the 168, I purchased one of each.
The original 168 V5 wing CF Rod is - inner diameter 6.75mm, outer diameter 9mm, length 30 1/4 in or 768 mm.
Old Feb 19, 2012, 04:56 PM
cabster101 is offline
Find More Posts by cabster101
United States, TX, Austin
Joined Jul 2011
Flew my V5 skywaker with the 1900mm wing today. With the old wing I could cruise at 8amps with the gopro and case. With this wing I could cruise at 5amps. Other than that, I couldn't really tell a difference. I didn't have much time today so next time I will try a long distance flight and see what I can get out of it.
cabster101 is offline Find More Posts by cabster101
Old Feb 19, 2012, 05:13 PM
Jim2011 is offline
Joined Aug 2011
If my math is right, that is a 37% improvement. That is impressive. I guess you could go 37% farther or stay up 37% longer. Nice.
Old Feb 19, 2012, 05:44 PM
sfakias is offline
Find More Posts by sfakias
ScratchCrasher
sfakias's Avatar
Greece, Makedonia Thraki, Thessaloniki
Joined Jun 2008
I would not say 37% farther, because I suppose tha the crousing speed is slower with the 1900mm wing. cabster101 could you please quote the crousing speed with each wing?
sfakias is offline Find More Posts by sfakias
Old Feb 19, 2012, 08:02 PM
Joined Jul 2011
I was doing around 19-20mph against the wind and around 27-28 with. I would say that pretty close to the old wing. Maybe slightly slower.
Old Feb 20, 2012, 12:58 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
8A sounds like quite a lot, even with the added drag of the GoPro case.
With GoPro mounted sans case (but including flight camera on pan&tilt), with no extra provisions
made for aerodynamics (no canopy), my V2 Skywalker would cruise at 6.5A (on 3S pack) averaging about 26.5mph.
20 upwind and 28 downwind for the 1.9m version works out to 24mph so it is a bit slower.
ian
Daemon is online now Find More Posts by Daemon
Old Feb 20, 2012, 07:41 AM
Formosa is offline
Find More Posts by Formosa
Joined Aug 2004
Hi cabster101
I would appreciate if you could share the CG that you used.
Regards
Formosa
Formosa is offline Find More Posts by Formosa
Old Feb 20, 2012, 07:43 AM
raRaRa is offline
Find More Posts by raRaRa
Joined Nov 2010
I emailed BEVRC today, and to my surprise they replied within an hour. They told me that they will be selling the 1900mm wings when they are available
raRaRa is offline Find More Posts by raRaRa
Old Feb 20, 2012, 11:13 AM
rcmonster99 is online now
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
that IS interesting !!!
rcmonster99 is online now Find More Posts by rcmonster99
Old Feb 21, 2012, 09:33 AM
gromitvt10's Avatar
Joined Feb 2002
Anyone know where i can get a Skywalker V5.1 1900mm besides Bevrc?
Old Feb 21, 2012, 05:01 PM
GuyPilot is offline
Find More Posts by GuyPilot
Joined Jan 2011
I have just ordered a SkyWalker 1900 as well from BEVRC. Hopefully I will receive it soon and I'll update everyone ~~~~~~ Yay
GuyPilot is offline Find More Posts by GuyPilot
Old Feb 21, 2012, 06:29 PM
Rrated is offline
Find More Posts by Rrated
Rrated's Avatar
United States, NJ, Ocean
Joined Aug 2011
Well after crashing my Zephyr II today I decided for what I like to do the sky walker is the best plane for me ! so on top of my 2X V4 s 2Xv5 s now just ordered 2X 1900 They better keep this design for a long time !!
Rrated is offline Find More Posts by Rrated
Discussion Skywalker 168cm FPV plane Fergus FPV Aircraft 19375 Sep 11, 2016 04:00 PM
Discussion Sander's Skywalker FPV camera plane build ssassen FPV Aircraft 134 Mar 30, 2014 10:52 AM
Discussion New Forum Suggestion: Skywalker 168cm FPV / UAV plane heinduplessis New Forum Requests 69 Jun 27, 2012 07:23 AM
Sold LPU Northwest Mo or San Antonio, Tx. Skywalker fpv plane fully set up and ready to go randall1959 FPV Equipment (FS/W) 2 Jan 14, 2012 08:29 AM
Discussion New FPV Plane from Skywalker borneobear FPV Aircraft 10 May 13, 2011 06:09 AM
