Old Feb 15, 2012, 08:21 AM
slarys is offline
Find More Posts by slarys
The Netherlands
Joined Jul 2011
I want to order one of those but late BEVRC news stopping me to hit the buy button. I heard their website was hacked and dont know if they turned their system back to normal and is stable now. Also reading some reviews about their 0 support about returning the broken or missed items.
Anyone can advice here?
slarys is offline Find More Posts by slarys
Old Feb 15, 2012, 08:59 AM
Jim2011 is offline
Find More Posts by Jim2011
Joined Aug 2011
Mine arrived as well.
I saw on their web site they only ship the carbon fiber spars with a plane. I did not notice this when I ordered mine. Can I just pick some up at a local hobby shop and do most builders put in this extra strength precaution? If so is there a recommended size and shape? This will be my first skywalker and I am just reading a little about the wings being a little weak.
Jim2011 is offline Find More Posts by Jim2011
Old Feb 15, 2012, 09:16 AM
cabster101 is offline
Find More Posts by cabster101
United States, TX, Austin
Joined Jul 2011
Originally Posted by sfakias View Post
Can you please also post a pic of the end of one wing half, where it is joined with the other wing, looking along the wing? This is to let us get a feel of the airfoil used.
I attach a pic of an earlier version wing to show you what I mean.
Thank you.
Sure, I will post one later today when I get home from work.
cabster101 is offline Find More Posts by cabster101
Old Feb 15, 2012, 09:23 AM
Joined Jul 2011
Originally Posted by Daemon View Post
I wonder if it's using the same joiner rod as the X8, which is significantly sturdier
than the original Skywalker joiner (no idea how it compares to the V5 joiner).
ian
My V5 wing is glued together so I can't compare it but I will take some measurements and post them up later today.
The new Skywalker did come with better control horns. They came with back plates and screws. My V5 came with ones you just push into the foam.
Old Feb 15, 2012, 10:23 AM
turboready is offline
Find More Posts by turboready
ON, Canada
Joined Nov 2007
Dont want to go go off topic here, but they NEVER replied to 5 emails I have sent them regading a few questions of some of their products, this was over a three month period.
I was going to get a SK and a bunch of FPV equipment from them but held back as well.
I have started a thread here inquiring about their customer service
http://www.rcgroups.com/forums/showthread.php?t=1594363
turboready is offline Find More Posts by turboready
Old Feb 15, 2012, 10:26 AM
ON, Canada
Joined Nov 2007
Just for the wing or the entire SW?
Old Feb 15, 2012, 12:18 PM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
Here are some pictures of the new wing. The fuselage looks the same as V5.
definitely the wing chord is wider the profile looks thicker and there seems to be an undercamber which should improve the gliding .
it looks like these wings will slot straight in any version fuselage.
can't wait to see some reports on flight performance !
rcmonster99 is offline Find More Posts by rcmonster99
Old Feb 15, 2012, 08:40 PM
Joined Jul 2011
Thank you.
Here is that side view you wanted.
Old Feb 15, 2012, 08:47 PM
Joined Jul 2011
ian
The joiner rod is 43.25" long by 10mm. The CF is 1.2mm thick.
Sorry for the standard and metric measurements. How does that compare to the X8?
Old Feb 15, 2012, 09:46 PM
CTvxl is offline
Find More Posts by CTvxl
United States, TX, Mansfield
Joined Jan 2012
You might find CF strips, tubes, etc. at your local hobby shop(s)
If you don't have a local option, you can order that stuff from rcfoam.com - They have a pretty good selection of carbon stock.
Also, regarding rcfoam.com, I feel I need to tell you that I have no prior experience ordering from there. I did place a small order yesterday (for the first time) and so far, everything is going smoothly. The shipped it today and sent tracking #.
I'm not sure if there are any other/better online sources for carbon stock. rcfoam.com is the best I've found so far...
CTvxl is offline Find More Posts by CTvxl
Old Feb 15, 2012, 11:02 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
man that CF rod just looks too small for that big wing..... Two of those would work great...
I would definitely put a ribbon or two in the wings to help. Maybe make the wing a one piece and have CF going across the joint..
ashdec87 is offline Find More Posts by ashdec87
Old Feb 16, 2012, 12:36 AM
heinduplessis is offline
Find More Posts by heinduplessis
Foam Snow
South Africa, WC, Cape Town
Joined Aug 2011
That's a looong wing to fit in a car!
heinduplessis is offline Find More Posts by heinduplessis
Old Feb 16, 2012, 12:43 AM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
X8's joiner is shorter, same OD, and I think the same wall thickness. It's definitely a lot
sturdier than the old Skywalker joiners, but then it had two of them.
ian
Daemon is offline Find More Posts by Daemon
Old Feb 16, 2012, 12:49 AM
Joined Jul 2011
I've got truck with a bed cover so its not a big deal for me to transport. My old wing gets most of it's bumps and bruises from hauling back and forth from the tuck to the house. Bumping in the walls and scraping it turning the corners. It would be nice to have a 2 piece wing but It seems so much stronger glued together.
Old Feb 16, 2012, 04:25 AM
sfakias is offline
Find More Posts by sfakias
ScratchCrasher
sfakias's Avatar
Greece, Makedonia Thraki, Thessaloniki
Joined Jun 2008
Thank you very much cabster101!
It is now obvious that they changed the airfoil used, as well as the wing dimensions.
sfakias is offline Find More Posts by sfakias
Discussion Skywalker 168cm FPV plane Fergus FPV Aircraft 19051 Dec 01, 2015 03:10 PM
Discussion Sander's Skywalker FPV camera plane build ssassen FPV Aircraft 134 Mar 30, 2014 11:52 AM
Discussion New Forum Suggestion: Skywalker 168cm FPV / UAV plane heinduplessis New Forum Requests 69 Jun 27, 2012 08:23 AM
Sold LPU Northwest Mo or San Antonio, Tx. Skywalker fpv plane fully set up and ready to go randall1959 FPV Equipment (FS/W) 2 Jan 14, 2012 09:29 AM
Discussion New FPV Plane from Skywalker borneobear FPV Aircraft 10 May 13, 2011 07:09 AM
