Of course the plane presents itself to be blown against. Air hitting it at 90 degrees to its flight patch "hits" and pushes the plane sideways
See the jet here off the ground, but presenting itself to be blown against. And thats some weight to push. Foamies like the skywalker with its high flat sides stands no chance in cross winds. The more aerodynamic the side profile the lesser effect it has |
The only time there is wind "blowing against the side" of that plane, is when he kicks the rudder
over hard just before touchdown. The rest of the time the plane is flying dead straight into the apparent wind (combination of wind vector and its own forward airspeed vector) which does not match the direction of travel over the ground. A big flying wing, in the same high crosswind landing would crab at the exact same angle as the jet above, but would have a much harder time aligning itself with the runway at time of landing (due to no rudder). Note there is a distinction between a steady crosswind, and crosswind gusts. A gust changes the angle of the apparent wind and hits various surfaces (include the fuse) unevenly. It is true that the Skywalker fuse will see crosswind gusts more than a wing, but the effect is minimal compared to the effect a gust has on the vertical stab and what it does to any plane with dihedral or polyhedral (the Skywalker has a lot of effective polyedral). If the Skywalker had no effective dihedral (a low straight wing, in line with its CG), you'd see very little effect from crosswind gusts, in spite of the large fat fuse. Keep in mind, I'm a slope sailplane pilot. We fly in "crosswinds" *all the time*. ian |
Latest blog entry: My 2012 FPV year in Review
Read the book "Stick and Rudder" to get a real understanding of how an airplane really flys... and what really happens when the "wind" blows "against" the airplane. I will state again... the airplane does NOT present itself to be "blown against" by the wind. Only objects fixed to the ground can be "blown against" by the wind. An object in the air is not "fixed' to anything... It moves WITH the wind. |
I wonder if it's using the same joiner rod as the X8, which is significantly sturdier
than the original Skywalker joiner (no idea how it compares to the V5 joiner). ian |
I attach a pic of an earlier version wing to show you what I mean. Thank you. |
Those pictures say all you need to know. The original SW had a flat bottomed wing. The new one is a drastically different section with undercamber as well as being much larger. Can anyone with an education on wing section comment? Not really my field, but it looks like the new wing will be oriented towards slow flight, lots of lift = big payload for batteries. Much like a loitering for hours kind of wing.
| Thread Tools | |
| Discussion Skywalker 168cm FPV plane | Fergus | Video Piloting (FPV/RPV) | 17254 | Yesterday 11:32 AM |
| Discussion New Forum Suggestion: Skywalker 168cm FPV / UAV plane | heinduplessis | New Forum Requests | 69 | Jun 27, 2012 07:23 AM |
| Discussion Sander's Skywalker FPV camera plane build | ssassen | Video Piloting (FPV/RPV) | 132 | Jan 22, 2012 05:38 PM |
| Sold LPU Northwest Mo or San Antonio, Tx. Skywalker fpv plane fully set up and ready to go | randall1959 | FPV/RPV - Equipment and Vehicles (FS/W) | 2 | Jan 14, 2012 08:29 AM |
| Discussion New FPV Plane from Skywalker | borneobear | Video Piloting (FPV/RPV) | 10 | May 13, 2011 06:09 AM |
