Old Feb 10, 2012, 03:27 PM
Joined Apr 2011
3 or 4 blades prop fon an OS .61FX
Hi people. I was searching on Internet about props of 3 and 4 blades for my OS .61 fx. I cant find a correctly answer about if possible put one of this two types of prop on my engine, i read that load factor is huge for use in it. i wanna now if anyone had knowledge about that or if i can use a type in specify prop of 3 or 4 blades.
KASL is offline Find More Posts by KASL
Old Feb 10, 2012, 08:48 PM
United States, SD
Joined Aug 2010
Lots of people say that you don't want to go with a 3 blade prop on an engine below a 91. I am guessing that it would be the same with a 4 blade.
Kyler1 is offline Find More Posts by Kyler1
Old Feb 11, 2012, 07:42 AM
Fueled by Arabica Beans
ChillPhatCat's Avatar
United States, NY, Syracuse
Joined Oct 2008
Most of the time people start by reducing the diameter by one inch or the pitch by one inch for each extra blade.
So for a .61 that usually runs a 12x7 you would want an 11x7 (3) blade/10x7 (4) blade... or 12x6 (3) blade/12x5 (4) blade.
This is just a starting point though, it's uncommon to run 3 blade props and almost never do you see 4 blade on such a small engine. You'll need a tachometer to verify that a 4 blade of a certain side isn't loading it down too much.
ChillPhatCat is offline Find More Posts by ChillPhatCat
Old Feb 11, 2012, 02:58 PM
Letchworth, Great Britain (UK)
Joined Jul 2004
For most people in our club a .61 is a large engine
Anyways, I used to run a 3-blade 12x6 (I think it was) on my OS61FSR (I'm all electric now). As others have said, the rule of thumb is to reduce it by 1" compared with whatever 2-blade you were using.
abenn is offline Find More Posts by abenn
Old Feb 14, 2012, 10:19 AM
Joined Apr 2011
Oh ok, i got it. But there is a online store where i can found some props?
in apc propellers had just two props but they are big.
Abenn you said that you used a 12x6 3 blades in a .61 os engine, how was it performance? more power? more RPM?
i was reading another forums and they all said that its not good put a 3blade prop in a small engine like the .61
Old Feb 14, 2012, 01:43 PM
Joined Oct 2008
Most of the time, multi-blade props are just used to minimize the diameter of the prop. For ground clearance reasons and to prevent blade tips from going supersonic, large planes that have a lot of power, usually use multi-blade props to get all the thrust they can from a given engine. With R/C planes, there is usually no problem with ground clearance or prop tip speed, so you are just losing some power when you run a multi-blade prop... not much, but it is measurable. It's usually best to only run them for scale reasons.
Old Feb 14, 2012, 02:24 PM
Joined Jul 2004
It was a while back, but I think the reason was that it looked cool Maybe it was also to reduce the noise a little, by reducing the rpm -- I can't honestly remember.
I have no idea what the rpm was, but performance seemed to me to be just the same as with the 2-blader I used before. It was either a Graupner or a Master Airscrew.
Old Feb 14, 2012, 08:32 PM
H&H
H&H Hobbies
H&H's Avatar
Old mystic CT U.S.A.
Joined Nov 2003
12x6 or 11x7 3 blade would be fine on a .61 FX. Performance will not be better. In fact it will probably be a little worse as the more blades you have the less efficient the prop is. You probably won't notice a drop in performance though. It's subtle. The real reason we use 3 and 4 blade props is cause they look cool more that anything else.
I have a Hobby shop that stocks 3 blade Master airscrews. Feel free to check out my site. I don't deal with four blades though. 4 blades aren't big enough sellers and the spinners get expensive
H&H is offline Find More Posts by H&H
Old Feb 20, 2012, 03:38 PM
Joined Apr 2011
i was testing some props some few days, and its true about all i read about forums, between more diameter we must reduce the pitch. So if i want use some 3 blades prop practically i must have a prop with this dimension 12x2 for the load factor in the engine. I was searching the pages that abenn give me and i saw the prop for 3blades and 4 blades are for big engines, nothing to do the hehehehehe. Someone now another prop with big diameter and low pitch? (Not apc 12,25 x 3,75 i got many of then)
Old Feb 20, 2012, 05:54 PM
Joined Oct 2008
A 12x2 prop wouldn't even get you past stall speed. For a .61FX, a 12x6 or 11x7 3 blade prop will work just fine. You are going to see an RPM drop, but it won't be terrible, you need a flyable pitch above all else.
Old Feb 21, 2012, 02:35 AM
Joined Jul 2004
... I was searching the pages that abenn give me and i saw the prop for 3blades and 4 blades are for big engines, nothing to do the hehehehehe. Someone now another prop with big diameter and low pitch? (Not apc 12,25 x 3,75 i got many of then)
I didn't give any pages link in my previous posting But, I've checked and I've still got the props I actually used -- here is my 12x6 http://masterairscrew.com/12x63-blad...propeller.aspx, and here is my 11x7 http://www.graupner.de/en/products/7...8/product.aspx
Anyway, 12x6 and 11x7 3-blade props are what I actually used on my OS61, with satisfactory results. As ChillPhatCat has said, 12x2 (if anyone makes one) won't give you any flying speed on a normal glow engine.
Old Feb 24, 2012, 02:34 PM
Joined Apr 2011
aben, yes i know, i was searching the brands on internet and i found the pages.
To Chillphatcat, im looking for a small pitch prop, just for experimental tests.
Wanted Pitts muffler for OS 61FX or 91FX Warby Aircraft - Fuel - Engines and Accessories (FS/W) 2 Feb 20, 2012 09:44 PM
Discussion Which 3 or 4 Blade Prop on this Motor?? Reely Electric Plane Talk 4 Dec 17, 2011 09:09 AM
Question AXI Gold 2212/34 with a 3 or 4 blade prop? - Now With Data! The Hog Pen Power Systems 15 Nov 29, 2011 09:09 PM
Wanted 3 or 4 blade electric prop for a prop clearance issue josephcharles Aircraft - Electric - Power Systems (FS/W) 1 Jun 17, 2011 10:08 AM
Help selecting 3 or 4 bladed prop to replace 2 blades Harley Power Systems 3 Jun 24, 2004 09:32 AM
