Old Feb 10, 2012, 03:26 PM
aussieman is offline
Find More Posts by aussieman
Joined Jan 2012
need help figuring out what battery to use to get max fly time
i have a airfield sky trainer cessna 184 and need to know what is the best battery to use that will give me the max fly time and not drasticly change the (CG) of my plane i will include the spec's of the plane in hope's of geing the correct answer to my question could you please include link's of any potiental battery's
Specifications
Wingspan: 55.5in/1410mm
Overall Length:40.5in/1100mm
Flying Weight: 1100g
Wing Area: 27.35dm
Wing Loading: 34g/dm
Drive System: Brushless Outrunner Motor (3536-kv900)
Servo: 6X 9g High Speed Micro Servos
Speed Controller: 30A Brushless ESC
Battery: 11.1V 2200mAh Li-Poly
Control System: 2.4Ghz 6 CH Multi-functional FHSS Radio Transmitter and 6 CH Micro Receiver
Radio Control Range: 3000 Feet (1000m)
aussieman is offline Find More Posts by aussieman
Old Feb 10, 2012, 04:27 PM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Use what the specs call for. You could increase the mah (but never the voltage),however the larger battery will also be an increase in weight and will make the plane harder to fly.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Feb 10, 2012, 06:05 PM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
55.5 inch wing span.
you can easily use a 2650mAh pack versus that 2200mah.
Given that its a tooling around in the air type plane, you could get away with a 3000mAh 3s pack MAX i would say.
but definitely a 2650mAh 3s pack is perfect.
cryhavoc38 is offline Find More Posts by cryhavoc38
Discussion What motor/esc/battery to get maximum flight time? Notdead Power Systems 8 Aug 16, 2011 08:37 AM
Discussion need some help figuring out a few things nick30head Scale Boats 6 Jun 21, 2011 02:45 AM
Discussion Need help figuring out series battery connection bpking Batteries and Chargers 4 Jun 10, 2010 01:40 PM
Discussion Help with figuring out what is what Olias Radios 4 Oct 21, 2008 09:20 AM
need help figuring out what number to get on my brushless jeff262 Power Systems 2 Nov 22, 2003 06:22 AM
