Old Feb 10, 2012, 10:12 AM
pr0ject42 is offline
Find More Posts by pr0ject42
CEL abuser
USA, CO, Denver
Joined Dec 2010
Mini-HowTo
Build a cheap shroud for your CP omni antenna
I don't know how many of you are extremely organized and careful with your gear, but I am not.
Having said that, I've got to say that no matter how beefy they are made, the bigger CP antennas are no match for the back of my SUV. I happen to have a 1.3 GHz turbine from Hugo that I've had to repair three times now due to transportation and other mishaps and I got a little sick of it. Enter: cardboard.
So I started out measuring the diameter of the antenna and it came out to about 3", so I created a trusty compass composed of two pens, one that is the center of the circle, a string attaching them together at 3" and the other that was to mark my circumference.
I did this twice, cut the circles out, punched the center of one for the coax to go through and began to tape the antenna to the top of the other.
Once the antenna was taped down (I didn't want to make it permanent in case it sucked) I cut out some 1" wide strips of cardboard and folded them into "V" shapes and glued them down to the top in between the ribs of the antenna. This is going to give your structure some strength. After getting one between each rib, I put the bottom circle of cardboard on and glues the bottoms of the ribs to it.
Then I finished with a turgid roll of cardboard that I found in my garage from something that once was my wife's and cut it to length so that I could reach the SMA connector to screw it on. Ta-da you're done!
I went so far as to add an OMM low pass filter on my RX side, not sure how much good it will do to reduce noise but I thought I'd give it a try. I then cobbled together a toothpick structure around it for stability and ta-da now I'm done.
Please check the pictures out, I think they will be a better aid than my narrative.
pr0ject42 is offline Find More Posts by pr0ject42
Old Feb 10, 2012, 12:33 PM
philthyy is offline
Find More Posts by philthyy
UAV Integrations
United States, WA, Battle Ground
Joined Nov 2005
Cool! I have been dreaming of a system to make a light weight shroud for a cloverleaf. My only worry is the possible drag it could create.
philthyy is offline Find More Posts by philthyy
Old Feb 10, 2012, 01:04 PM
CEL abuser
USA, CO, Denver
Joined Dec 2010
This is strictly for the ground station. The wind resistance of this on an airplane would be ridiculous. Maybe what you could do for your plane is make something that could cover it up for transport (anchored with some light magnets or something) and remove it for flight. As is the drag of these antennas isn't too bad at the speeds most of us are going.
Yeah the goal of this was to protect the antenna while it is not in use, so it doesn't get snagged by clothing, wires and such while transporting and setting up/tearing down the ground station.
Old Feb 10, 2012, 01:25 PM
rob38 is offline
Find More Posts by rob38
rob38's Avatar
Noord Holland
Joined Oct 2007
hi
look great
idea
rob
rob38 is offline Find More Posts by rob38
Old Feb 10, 2012, 02:33 PM
V_Okto is offline
Find More Posts by V_Okto
Joined Feb 2011
?? thats not needed. you need the filter at the TX side!
V_Okto is offline Find More Posts by V_Okto
Old Feb 10, 2012, 02:50 PM
CEL abuser
USA, CO, Denver
Joined Dec 2010
I know the iterated purpose is for the transmitter side, however when trying to reduce interference, why would you not want to filter your RX side? If 2.4GHz is a harmonic and is everywhere, why not filter it out? I mean *gasp* you could put an amp on your RX side as well if you felt you were getting excessive losses from your antenna to your RX. I'm just giving it a shot because I had one extra laying around.
Old Feb 10, 2012, 02:52 PM
CEL abuser
USA, CO, Denver
Joined Dec 2010
Originally Posted by rob38 View Post
hi
look great
idea
rob
Rob, this would have been the smart, fast and good looking way to do what I did. Heck I might just try that next. We'll see how the cardboard holds up.
Old Feb 10, 2012, 02:56 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Ya, it seems many people are confused about LPF and HPF these days.
You put a LPF on 1.2-1.3Ghz video Tx to keep 2nd order harmonics out of 2.4Ghz Rx
You put an OMM dual notch filter on 1.2-1.3Ghz video Tx to keep primary harmonic noise out of the GPS Rx, and secondary noise out of the 2.4Ghz band.
You put a LPF (typical cutoff around 600Mhz) on 433Mhz UHF control system Tx, to keep 3rd order harmonics out of 1.2-1.3Ghz video Rx.
You can put a HPF filter on 1.2-1.3Ghz Rx to block harmonics coming from 433Mhz control system,
but it's usually easier to use the LPF on the 433Mhz system (some have it integrated already).
ian
Daemon is online now Find More Posts by Daemon
Old Feb 10, 2012, 11:11 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
it would be cool to see your video and how well you do with video
there are way easier ways to make it simple
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Feb 11, 2012, 12:37 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
For all of the above I am on 5.8GHz...
No Filters, no special need to protect the five times smaller antennas.
renatoa is offline Find More Posts by renatoa
Old Feb 13, 2012, 07:28 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
For protecting a 2.4GHz antenna, I use a 75mm play pen ball. Fits perfectly and is nice and aerodynamic.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Question CP Omni antenna gain Wearyman FPV Talk 11 Aug 25, 2011 06:04 PM
Mini-HowTo Build a performance antenna for your LRS radio IBCrazy FPV Talk 18 Apr 11, 2011 09:57 PM
Discussion 9 dB collinear omni antenna build for 900 MHz video rcgroupie Aerial Photography 14 Apr 04, 2010 09:26 PM
Discussion need the best omni directional antenna for receiver WBFlyer FPV Talk 10 Jul 07, 2007 10:24 AM
Omni-directional antenna for bit-tx? Angry_Monk Scratchbuilt Indoor and Micro Models 4 Aug 12, 2005 04:05 PM
