Old Mar 06, 2012, 12:13 PM
makeitworst is offline
Find More Posts by makeitworst
UH-1 Gunship, AH-1G jock 69-71
makeitworst's Avatar
Joined Nov 2008
Safe paints to use on the Flyzone DR.1?
Maybe I missed this in skimming through the thread, but what types of brush on paints are safe to use on the Flyzone DR.1, especially painting the pilot??
makeitworst is offline Find More Posts by makeitworst
Old Mar 06, 2012, 01:57 PM
mtflyr is offline
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
Pretty much any acrylic basedpaint will work on the foam. Depending on your level of detail for your pilot oil paints can be used on the face as well they just take forever to dry.
Pete
mtflyr is offline Find More Posts by mtflyr
Old Mar 06, 2012, 03:46 PM
Angelo is online now
Find More Posts by Angelo
Angelo's Avatar
Chicago, IL
Joined Nov 1999
Dawn patrol, ready to go.
Angelo is online now Find More Posts by Angelo
Old Mar 06, 2012, 05:29 PM
karfrik is offline
Find More Posts by karfrik
karfrik's Avatar
United States, TX, Fort Worth
Joined Apr 2009
Originally Posted by angelo View Post
dawn patrol, ready to go.
nice!!!!.....
karfrik is offline Find More Posts by karfrik
Old Mar 07, 2012, 11:35 AM
Joined Nov 2008
Pete
I was thinking of using Testors Enamel hobby paints for painting the Pilots bust. I just can't tell from looking at the supplied Pilot, if it's Depron just like the plane, or something else. Thanks to non-existent info in the manual about the material or painting it, I'm just guessing. Anyone tried using Enamel hobby paints on the Pilot?
PS - anyone found a source for cheap replacement props .... just in case?
Old Mar 07, 2012, 01:07 PM
karfrik is offline
karfrik's Avatar
Joined Apr 2009
I did,they work fine...
Old Mar 07, 2012, 03:25 PM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Acrylics my be a better choice for foams some enamels may eat foam that's exposed skinned /sanded such as Depron or blue construction foam.
Humbrol enamel paints are great but I think they do eat some foams.
In the end whatever works for you just test first.
Pete
Old Mar 08, 2012, 12:37 AM
Joined Nov 2008
Micheal's Crafts stores carry an inexpensive line of Acrylics in bottles like the Testors but 1/2 the price. If I use silver and black permanent marker pens for the goggles, and only buy light beige for skin and brown for the skull cap and jacket, I won't feel I've put too much money into this model. (To me it's just a casual toyish model - no aspersions meant)
I do use Spray Enamels, the cheap stuff ($1.99) from Home Depot, on my Aerobatic Depron flats, but I've learned that you have to spray thin layers each time and you get no melting of the Depron. I am concerned that brushing on thicker amounts on the pilot bust might melt to some degree.
@karfrik - assume you brushed on the Testors Enamel thinly?
Question - Anyone found alternate (cheaper) sources for the same or slightly larger LiPO Batts? and Also for the Prop??
Thanks guys.
Old Mar 08, 2012, 12:56 AM
karfrik is offline
karfrik's Avatar
Joined Apr 2009
Thanks guys.
Yes brushed like 2 coats,nothing fancy and most of my remaining testors are like 20+ yrs!!!....you can also mix and match in order to get an specific color shade/tone.My Fokker pics are here, same color scheme as Angelos requiring minimal color changes.I left the red like it came out of the box but added the necessary white in the tail and then the skyblue all under the wings and fuse using acrylics from Michaels...scroll back a bit and take a look at the pics..
Old Mar 08, 2012, 11:55 PM
Joined Nov 2008
Looks great, the all white tail section is more accurate.
Anybody broken a prop yet? Where or what alternate props work?
Old Mar 09, 2012, 12:53 PM
Joined Nov 2008
Originally Posted by D Johnson View Post
Information from E-Fest:
Disassembling Fokker DR1 and Albatros DV, Ronson Lighter Fluid
Removing paint from those planes (and most others): Blue 3M tape may be used on the Depron surfaces to remove about 95% of the paint, Do not use the Green or white tapes as it can pull off the skin. Satellite City/Hot Stuff Super Solvent will remove the paint from these plane with out causing any damage to the foam. This also works on most other EPS, Depron airplanes.
3M 75 removable spray on adhesive is my favorite for making masks for painted markings. A light coat and it will stick and not pull off the paint.
Surface preparation: On EPS once the paint is removed. I like to carefully sand the foam with 400 grit sandpaper. Be careful not to leave gouges or ridges. Once that has been done, Apply a coat of Minwax Polycrylic with a foam brush. Let this dry for at least 3~4 hours and lightly sand it with 400 again. Apply one more coat and sand with 600 grit. You now have a nice stable base for your paint that will allow masking with a minimum risk of pealing the previous layer.
Paint: My personal preference (right now:-)) is Flouquill Polyscale. It has very finely ground pigments which allows exceptional coverage with a minimum of weight gain.
That is today's burst of stream of conscious modeling, more to come with pictures as I find time.
DJ
DJ, is there a tape type that can be used on the existing red fuse that won't pull off the red paint so I can spray paint and get straight edges?? I want to continue the white side stipes on the fuse around the top of the fuse too. You mentioned the 3M Blue can be used to "remove" the original paint, I want to keep it on. BTW, great job on the Lothar styled Dr.1
Where can we get replacement props, just in case??
Old Mar 15, 2012, 09:13 AM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Post-it notes for a mask and airbrushed water based acrylic craft paint works. Lots of very fine coats.
Tim Wolff is offline Find More Posts by Tim Wolff
Old Mar 15, 2012, 01:57 PM
D Johnson is offline
Find More Posts by D Johnson
Just some guy
D Johnson's Avatar
Joined Aug 2006
Good suggestions Tim! Another way is to put a coat of Minwax Polycrylic on and then you can mask with almost anything. The Polycrylic adheres well to the EPS and adds almost no weight.
DJ
D Johnson is offline Find More Posts by D Johnson
Old Mar 16, 2012, 12:45 AM
Joined Nov 2008
Damn, those are BOTH great suggestions!! See, 40+ years in RC modeling and I'm still learning stuff!
BTW - for those that are trying to paint their DR.1's to accurate paint schemes, including the "Red Baron's" or his brothers plane, rent the old movie produced in Europe The Red Baron. I just watched it again.
I remember a short documentary about that movie where the Director went to great lengths to be extremely accurate about the story, the props and planes and the characters. They did tons of research. There was a Dr.1 with an all white tail, but is was not Manfred von Richthofen or Lotar's. Manfred's was totally red, not even white side stripe with Iron Cross.
Think I'll still leave the tail white ... I want to see the damn thing better ... but I might just paint over the white Cross stripes after-all.
Hey, anyone know how to get the prop off without damaging it or the shaft??
Old Mar 16, 2012, 07:11 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The Prop pulls straight off. Hold the shaft with needle nosed pliers while pulling on the prop.
The Flyzone Plane isn't modeled after the real "Red Baron" plane, but instead is modeled after a real replica "Red Baron" at the Hanover Aviation musuem.
The Deutch Museum in Munich has a more acurate paint scheme on their "Red Baron" replica, but it still has a white tail and no Iron Crosses.
UNGN is offline Find More Posts by UNGN
Discussion Flyzone Albatros Mods thread D Johnson Micro Ready-to-Fly 829 Sep 14, 2016 11:35 AM
Discussion Flyzone DR1 raf37 Scratchbuilt Indoor and Micro Models 61 May 05, 2012 02:13 AM
Discussion Official Ragecam Gopro Lens Mod Thread. No more Sunex case mods or Fisheye daign Multirotor Talk 109 Jul 15, 2011 11:04 AM
Discussion Official Ragecam Gopro Lens Mod Thread. No more Sunex case mods daign FPV Talk 2 May 17, 2011 10:32 AM
Discussion Simple Hawk Sky mods + info thread chatch15117 Foamies (Kits) 2 Apr 25, 2011 11:49 PM
