Old Jul 27, 2012, 06:29 PM
United States, NC, Charlotte
Joined Jan 2007
Originally Posted by Tim Wolff View Post
You are correct in your observation that CA is too brittle for this application. I assembled mine from parts and used Canopy glue throughout. I'd give it a try on yours, but it won't work miracles. You need a good smooth surface and the ability to actually land on it.
Same here once I started using canopy glue no more pulled out landing gear or struts
Tim
w4yn is offline Find More Posts by w4yn
Old Jul 29, 2012, 08:04 PM
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
Originally Posted by jrtubb View Post
Awesome bird, I too would like to see some details on that pull pull on the wing and how it is controled inside, especially how this controled.
Dave,
I'd really like more details on your pull-pull aileron setup
356Jim is offline Find More Posts by 356Jim
Old Nov 18, 2012, 03:45 PM
Gravity is a harsh mistress.
Tim Wolff's Avatar
Lambertville, Michigan, United States
Joined Sep 2002
I finally got to painting the pilot figure that mtflyr (Pete) molded. More molded in detail than most humans can paint. Yes, he's a "ginger". I was mixing colors for another pilot I was painting trying to get the right brown leather color and the eyebrows are done with an intermediate color I stumbled on during the process. The scarf is Esaki tissue. It really dresses the plane up. Thanks Pete!
Ran a couple more batteries through it at the last indoor session. The big prop makes for rudder trim changes with throttle. I may try some throttle rudder mix, a smaller prop, or both to get that under control. Like every other Dr.1 I've flown, it has to be flown the whole time it is in the air and does not act nice if you get ham fisted with the stick.
Needs some guns. The photo etched guns from overseas look like the best candidate if I can assemble them neatly.
Tim Wolff is offline Find More Posts by Tim Wolff
Old Jan 01, 2013, 12:13 PM
Joined Jun 2011
Raise this thread from the dead.
Been working on this all night... Very close to being done. Gave a test flight a couple hours ago, been just working on final details now.
FlyZone DR.1 Modded (1 min 15 sec)
WonkoTehSane is offline Find More Posts by WonkoTehSane
Old Jan 01, 2013, 04:20 PM
No dear, That isn't New!
pattypilot's Avatar
USA, IL, Urbana
Joined Nov 2006
Wonko, Very nice. Glad to see another four channel DR 1. I love flying mine. Just make sure you fly it like a WW 1 plane, What I mean is start into the turn with rudder then add opposite aileron to complete the turn. If you just use the ailerons it doesn't really turn, just kind of fly's on its side. Of coarse I maybe preaching to the choir here, sorry? Have fun.
Jim
pattypilot is offline Find More Posts by pattypilot
Old Feb 07, 2013, 03:56 PM
Joined Sep 2012
So many super nice dr1's in here.
I see people have changed to pz champ or p51 motors. Any flight reports with those? How are the flight characteristics of the heavier setup, and can it handle more wind outdoors? Considering getting this and modding it with a pz motor, or just get a stock se5 Any input appreciated.
boro92 is offline Find More Posts by boro92
Old Feb 07, 2013, 06:05 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
With so much wing, i don't think it would ever be able to handle much wind.
This plane can use as much nose weight as it can get, so the extra 2.5g doesn't hurt at all.
If you convert the plane to a Spektrum brick, it will lose at least a gram of nose weight, so the heavier motor is a +.
on the longer nose plane, you can keep the 7mm, but for the rotary motored airframes, there are few downsides to an 8.4mm motor/gearbox.
UNGN is offline Find More Posts by UNGN
Latest blog entry: AR6400 guillows Space Shuttle
Old Feb 17, 2013, 03:19 PM
United States, WA, Battle Ground
Joined Sep 2012
1st flight...
I finally got the 1st flight in with my DR-1. Even with the foam removed up front, and the battery pushed all the way forward to the rotary engine, it was tail heavy. Flew pretty good actually, but had to use full down on the elevator trim. I'm going to stick a couple small pieces of lead in the cowling... and this will be a fun little flier!
(but out of the box... the Albatros is perfect!)
swcushing is offline Find More Posts by swcushing
Old Feb 18, 2013, 11:15 PM
Joined Sep 2012
I mounted 2 pieces of lead, (1 gram each) to the front of the firewall and flew the DR-1 today in a 6-8 mph breeze. Could almost back it up, and it did jump around a little.. but flew great. I'm re-gluing all the gear and wing attachment points with canopy glue and will do some detail painting shortly. Neat little flier!
Discussion Flyzone Albatros Mods thread D Johnson Micro RTF 701 Apr 20, 2013 10:40 PM
Discussion Flyzone DR1 raf37 Indoor and Micro Models 61 May 05, 2012 02:13 AM
Discussion Official Ragecam Gopro Lens Mod Thread. No more Sunex case mods or Fisheye daign Multirotor Talk 109 Jul 15, 2011 11:04 AM
Discussion Official Ragecam Gopro Lens Mod Thread. No more Sunex case mods daign Video Piloting (FPV/RPV) 2 May 17, 2011 10:32 AM
Discussion Simple Hawk Sky mods + info thread chatch15117 Foamies (Kits) 2 Apr 25, 2011 11:49 PM
