Espritmodel.com Heli Air
Old Feb 10, 2012, 08:18 AM
Lucky Dog's Avatar
Joined Jun 2006
Flyzone UM Dr1 Mods Thread
Hobbico has a real winner here. And while I understand from a marketing standpoint that it just had to be red out of the box. Most will agree that there are just too many Red Fokker Tripes. So, I decided to do mine as Lothor von Richtofen's Dr1. I had done my AZM 1/5 Dr1 in these markings a number of years back and really like them.
I first stripped off the red paint on the wings with blue painters tape.The fuse was more difficult and took light applications of CA Debonder on a cloth. Still, it didn't come all the way off the fuse.
As you can see I've already painted and masked the cowl, and lightly painted some green streaks on the top wing, rear fuse, and top of horiz. stab. and elevator. This would show a bit throw the yellow later by design. Yes, I'm that anal. The fields behind the top wing and fuse crosses are darker and solid, that's why they're masked and painted on the wing.
The engine details added were the intake manifolds, which were from an old 1/32 scale plastic kit radial engine exhaust manifold (never throw anything away!). The push rods are stretched sprue. I guess I should try a painted prop next.
The final product. A light tan base was applied with an airbrush, then the green streaks were added. Cockpit was cut out, and graphics provided by Dave Johnson were printed, cut out and added to the interior. I haven't quite figured out how to mount the seat that's included with Dave's cockpit details as it would need to sit on top of the control wires to the tail feathers. While not visible in this photo, I've also added the pilot steps and lift handles on the rear of the fuse. I have made the wing tip skids out of 1/64 lite ply, but haven't added them yet. More little details to add too.
I hope that I haven't added too much weight, and it still flies as great as it did before. I have also reshaped the rudder a bit to make it more rounded. It's still too big, but it's probably that way for a reason. On the subject of the rudder, the lower part of the rudder where it get's small to hinge to the fuse I'm finding is my nemesis, I keep buggering it up, mostly do my own clumsiness, but it's the weakest part of, the design. I'm on my second rudder, and darned if I didn't screw it up working on it yesterday. It's repaired for now.
First re-flight should be this tonight.
I've shown you mine, now you show me yours.
Lucky Dog is offline Find More Posts by Lucky Dog
Old Feb 11, 2012, 10:39 PM
Just some guy
D Johnson's Avatar
Joined Aug 2006
LD thanks for starting the thread. Thanks to all who attended my seminar today at E-Fest! A whole bunch of info coming real soon.
D Johnson is offline Find More Posts by D Johnson
Old Feb 12, 2012, 07:48 AM
Centreville,VA,USA
Joined Apr 2001
Good job LD, looks great.
Here's some mods I did to mine back in December but have now only just started the repaint too much fun flying. I also have the PZ P-51 motor and gearbox in mine. I plan on doing Kempf's scheme.
Got some paint down.
Pete
mtflyr is offline Find More Posts by mtflyr
Old Feb 14, 2012, 07:30 AM
Just some guy
D Johnson's Avatar
Joined Aug 2006
Information from E-Fest:
Disassembling Fokker DR1 and Albatros DV, Ronson Lighter Fluid
Removing paint from those planes (and most others): Blue 3M tape may be used on the Depron surfaces to remove about 95% of the paint, Do not use the Green or white tapes as it can pull off the skin. Satellite City/Hot Stuff Super Solvent will remove the paint from these plane with out causing any damage to the foam. This also works on most other EPS, Depron airplanes.
3M 75 removable spray on adhesive is my favorite for making masks for painted markings. A light coat and it will stick and not pull off the paint.
Surface preparation: On EPS once the paint is removed. I like to carefully sand the foam with 400 grit sandpaper. Be careful not to leave gouges or ridges. Once that has been done, Apply a coat of Minwax Polycrylic with a foam brush. Let this dry for at least 3~4 hours and lightly sand it with 400 again. Apply one more coat and sand with 600 grit. You now have a nice stable base for your paint that will allow masking with a minimum risk of pealing the previous layer.
Paint: My personal preference (right now:-)) is Flouquill Polyscale. It has very finely ground pigments which allows exceptional coverage with a minimum of weight gain.
That is today's burst of stream of conscious modeling, more to come with pictures as I find time.
DJ
Old Feb 14, 2012, 08:37 AM
Gulf Breeze, FL
Joined Jul 2006
Originally Posted by D Johnson View Post
Information ...That is today's burst of stream of conscious modeling, ....
Thanks! Good stuff, as usual.
Gene K
speedy01 is offline Find More Posts by speedy01
Old Feb 14, 2012, 10:08 PM
WHAT THE...
barmonkey's Avatar
Evansville, Indiana
Joined Jan 2005
Lucky Dog, Thanks for starting this thread. Hoping to get back to mine soon. BTW I was planning to do a Lothar version for my first one also...it has always been one of my favorites.
DJ thank you too for posting the info on removing the paint from the airframe. I am kind of interested to see how many times someone asks how to remove the paint or complains that their gearbox is noisy...may just keep count throughout the evolution of this thread.
So far, I have only tinkered with making my own photo-etch cooling jackets for the Spandaus...a complete failure so far. Also, I have experimented with casting my own pilot...which also has been a complete failure. These are things that I can add later anyway, so I will return my focus to painting the airframe.
I did manage to make some decent looking wheels...I'll post some picks in the near future.
barmonkey is offline Find More Posts by barmonkey
Old Feb 15, 2012, 04:53 PM
Just some guy
D Johnson's Avatar
Joined Aug 2006
Dohhh, another Lothar Triplane:-( Hey at least it is an earlier version prior to the top wing being painted yellow. 4 channels, all pull-pull. Has a Cox motor fora little more Omph with the added weight. Not completed but getting close. It has been test flown. Note the scale rudder and wings with no dihedral.
Old Feb 15, 2012, 04:55 PM
Just some guy
D Johnson's Avatar
Joined Aug 2006
A few more shots with the pull-pull, gunns, CP, ect.
Old Feb 15, 2012, 05:20 PM
-=BS=-
BlazingStar's Avatar
Thousand Oaks, CA
Joined Jul 2009
Dave
It looks great.
A couple of questions
How did you take the dihedral out of the wings? Is it an entirely new wing?
How does the pull-pull work in the business end inside? I'm having a hard time visualizing where the wires go (what are they made of by the way?)
Any pictures of the inside works?
Hi Pete, we meet again!
It's far down the list but I had planned to make Kempf's dr1 when I get around to it. I see you beat me to it. Hope you don't mind if there is a copy flying on teh west coast. It won't look as great as yours of course! You have my Email if you are willing to share your graphics files.
Thanks! (and nice pilot!)
(oops, thanks Jim - corrected)
BlazingStar is offline Find More Posts by BlazingStar
Old Feb 15, 2012, 05:37 PM
Centreville,VA,USA
Joined Apr 2001
Don,
It looks great. Super job! How did she fly with the ailerons and straight wing?
Pete
Old Feb 15, 2012, 07:23 PM
No dear, That isn't New!
pattypilot's Avatar
USA, IL, Urbana
Joined Nov 2006
Blaze, Pete! That's Dave, not Don. Just a heads up. Jim
pattypilot is offline Find More Posts by pattypilot
Old Feb 16, 2012, 01:32 PM
I Fly!
jrtubb's Avatar
United States, AL, Huntsville
Joined Jan 2011
Awesome bird, I too would like to see some details on that pull pull on the wing and how it is controled inside, especially how this controled.
jrtubb is offline Find More Posts by jrtubb
Old Feb 16, 2012, 09:07 PM
Lucky Dog's Avatar
Joined Jun 2006
I crunched my rudder again being careless. Truthfully, It's (frail I think) at the hinge. So, I'm trying to build a very light weight built up one using cane reed.
Soaked the reed for an hour or so then shaped it around a cardboard form, and let it dry overnight
Then added the ruder hinge area made from 1/64 balsa laminated cross grain with piece of old floppy inserted for the hinge.
I just wish I had a clue as to it's weight compared to the stock foam rudder. I have some small dia. CF rod that I could have used for the cross braces. I wonder if it would be significantly lighter?
Here's a test fit before covering. Shape still isn't right, but it'll do for now.
Dave, I noticed you've modified your rudder hinge. Can you elaborate on how you did yours? I looks great! The whole Tripe looks wonderful!
Old Feb 17, 2012, 12:32 AM
Registered Plan-a-holic
Hepdog's Avatar
Stonewall, MB, Can
Joined Jul 2004
Here's my 2C
I didn't take mine apart - never thought of it
Instead I stripped most the red off with a paint brush and methyl hydrate (alcohol - wearing GLOVES). Then I started the paint job in black sharpie but switched to a super thin coat of Creative airbrush paint brushed on. Total weight gain .5 grams
Not super scale but that wasn't my goal - just wanted a different look
Hepdog is offline Find More Posts by Hepdog
Old Feb 17, 2012, 07:57 AM
Just some guy
D Johnson's Avatar
Joined Aug 2006
It looks very cool!
Discussion Flyzone Albatros Mods thread D Johnson Micro RTF 701 Apr 20, 2013 10:40 PM
Discussion Flyzone DR1 raf37 Indoor and Micro Models 61 May 05, 2012 02:13 AM
Discussion Official Ragecam Gopro Lens Mod Thread. No more Sunex case mods or Fisheye daign Multirotor Talk 109 Jul 15, 2011 11:04 AM
Discussion Official Ragecam Gopro Lens Mod Thread. No more Sunex case mods daign Video Piloting (FPV/RPV) 2 May 17, 2011 10:32 AM
Discussion Simple Hawk Sky mods + info thread chatch15117 Foamies (Kits) 2 Apr 25, 2011 11:49 PM
