Off we go.....
Right, basking in the success of the Mamba's maiden flight today, it is time to get this build thread on the road.
As is often the case I am starting with the tail surfaces to encourage that "1/3rd finished" feeling. However, in this case there is another and more practical reason for doing it this way. At present I have absolutely no real idea about how to distribute the radio and electric hardware in order to get the CG to come out in the right place. This means that, except for the motor mounting, I am unable to decide on where extra structure will be required for the electronics. So the plan is to complete the flying surfaces, covered and finished, and the fuselage as a bare box structure of longerons and spacers, and then sort out where the gear has to go to get the CG right, build in the necessary mounting structure and finally cover and finish the fuselage. First job then was to make the rib templates and cut out the wing and tailplane ribs, then trace and cut out the wing and tailplane tips. After drawing in the necessary modifications for the rudder and elevator control surfaces, I built the fin/rudder and tailplane. The rudder and elevator are built integral with the fin and tailplane and will be cut free before covering, then hinged afterwards. Some slight changes, such as double tailplane centre ribs to slot the fin into were necessary, but I resisted the temptation to change the wing and tail tips from assemblies of 3/32" sheet pieces to laminated outlines. The wings are going onto the board now, it is pleasant to be building a very light and entirely conventional structure, it's a long time since I last built a rubber model!
Looks good George. That airfoil looks just right for a slow, floaty, modestly powered model.
For assessing the CG position can I recommend Dan P's CG Calculator. It allows you to put in the point masses of various objects and tells you where the CG will be. Pretty clever stuff, but easy enough to work your way through the spreadsheet. Jon |
Hi Larry
I'll try to get some photos with just the mylar on - doesn't show up too well. If you look at http://www.rcgroups.com/forums/showt...1515121&page=2. post #25 shows bits of the Zephyr with just the mylar on. I shall be using the 5 micron on the Witch rather than the 10 micron. The 5 stuff is much harder to handle, but I want to absolutely minimise weight on this one. If you still have trouble finding mylar, Mike Woodhouse at www.freeflightsupplies.co.uk will ship world-wide, shouldn't cost much for mylar as it is light enough. He also does all the grades of Esaki tissue. |
| Thread Tools | |
| Contest Build off for FROG designs October 1st 2011 to April 30th 2012 | Sundancer | Vintage & Old-Timer Designs | 237 | Apr 23, 2013 03:29 PM |
| Build Log Frog Build Off Oct 2011-April 2012 - MAMBA | Sundancer | Vintage & Old-Timer Designs | 104 | Nov 26, 2012 07:57 AM |
| Build Log 2011 Build-off - Frog Senior Series "Tomtitx2" | Sundancer | Vintage & Old-Timer Designs | 137 | Jul 30, 2012 07:26 PM |
| Discussion Frog Build Off Oct 2011-April 2012 - Vanda Mk. 2 | vega | Vintage & Old-Timer Designs | 13 | Apr 29, 2012 09:15 AM |
| Build Log FROG build-off Oct 2011 - April 2012; ZEPHYR | Sundancer | Vintage & Old-Timer Designs | 75 | Mar 09, 2012 12:49 PM |
