Old Feb 09, 2012, 11:06 PM
Andyincalgary is offline
Find More Posts by Andyincalgary
Calgary, Alberta, Canada
Joined Sep 2008
Question
Are the Minima 6's considered / designed as "Full Range"
Flying my A9 + Optima's (6,7 + 9) primarily in gliders, rock solid, no issues on range and flying large (3M - 4M) gliders at several hundred meters range without issue.
I have Minima's in DLG's and smaller slope planes that dont fly as far away but I have one available and am thinking of using in a new high end molded TD plane that I want to keep as lite as possible. Normal range checks are fine with the Minima's as with the Optima's in every other plane I have
I know I will not have any telemetry but are am after some view from Hittec, are the Minima's a full range RX or are they classified more as a "park Flyer" RX
Any info would be great, thanks in advance
Andyincalgary is offline Find More Posts by Andyincalgary
Old Feb 09, 2012, 11:30 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by Andyincalgary View Post
Flying my A9 + Optima's (6,7 + 9) primarily in gliders, rock solid, no issues on range and flying large (3M - 4M) gliders at several hundred meters range without issue. I have Minima's in DLG's and smaller slope planes that dont fly as far away but I have one available and am thinking of using in a new high end molded TD plane that I want to keep as lite as possible. Normal range checks are fine with the Minima's as with the Optima's in every other plane I haveI know I will not have any telemetry but are am after some view from Hittec, are the Minima's a full range RX or are they classified more as a "park Flyer" RXAny info would be great, thanks in advance
Minima 6E, (& 6T) End Port 6-Channel 2.4GHz AFHSS Micro Receiver are "Full Range" receivers
Features:
Smart Scan Mode
Dual Diversity Mini Boosted Omni-Directional Antenna (M-BODA)
Hold and Fail-Safe Function
Wide Operating Voltage: 4.8~8.4 volts
Full-Range Operation
Optima Receivers - Light Weight. Optima_6 LITE Transceiver, Minima 6E & 6T Micro Receivers...
.. Minima are compatible only with Spectra Module V3.01 or higher. Caseless Weights for 6 & 7ch Optima Transceivers.
and more under Hitec USA Support Forum Sticky:
Aurora 9, AFHSS Spectra Modules, Optima Transceivers, Minima Receivers
& Telemetry
- FAQ & Undocumented Features
- Mixes, Setups, Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links (quick search = Ctrl+F)
A.T. is offline Find More Posts by A.T.
Old Feb 10, 2012, 12:48 AM
Joined Sep 2008
Thanks Alan
Thanks Alan
DOH ! should have read the Hitec web site, but thanks for the pointer, thats good news for me and my new Xplorer 4M and a few more grams saved on the build.
cheers
Andy
Old Jan 26, 2015, 11:30 AM
sahilkit is offline
Find More Posts by sahilkit
sahil
India, Telangana, Hyderabad
Joined Aug 2005
Sorry for bring up an old thread. I want to know the range of Minima 6S and Minima 6L receivers. (some internet sites show 1200Ft clear sight range)
Sahil
sahilkit is offline Find More Posts by sahilkit
Sold SPEKTRUM SPM AR600X Full Range Sport DSMX 6 channel RX crosby Aircraft - General - Radio Equipment (FS/W) 2 Aug 26, 2011 10:13 PM
Discussion Are the JR 790's and 790-UL's full range receivers? KevinSharbonda Hand Launch 16 Nov 16, 2008 07:58 PM
Discussion Are the JR 790's and 790-UL's full range? KevinSharbonda Radios 1 Nov 07, 2008 08:10 PM
What receivers are considered the best as of now... Cal Radios 24 Mar 08, 2005 03:40 PM
F/S Expert 650 full range 6 channel Rx (hitec shift) Etonic Aircraft - Electric - Airplanes (FS/W) 3 Jul 30, 2003 02:26 PM
