Old Feb 21, 2012, 09:06 AM
stiks's Avatar
Joined Jan 2012
Bill, on scorps hydro build you mentioned a thrust bearing from OSE..you talked about which side of the drive dog it should go on i think... is that a needed part?
stiks is offline Find More Posts by stiks
Old Feb 21, 2012, 09:30 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
The thrust bearings I use go between the shaft coupler and motor. There's a photo of one installed on a 2028 in the big Llumar hydro I started (and abandoned to build the Falcon cat)
http://www.rcgroups.com/forums/showt...3#post19073378
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Hobby King "SIX" hexa
Old Feb 21, 2012, 03:13 PM
stiks's Avatar
Joined Jan 2012
Bill, thanks for the link...wow you guys are boat kings...where do you keep all those things..between you and scorp you have your own seventh fleet!! I will have to look at OSE and see if there is something else i can order..with the thrust bearing.. I will check with my local shop too..is there a specific size? I guess it would have to match the motor shaft size, correct?
Old Feb 21, 2012, 05:41 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
10-4 on matching the motor shaft size. OSE sells then in 5, 6, and 8 mm.
Old Feb 21, 2012, 07:06 PM
stiks's Avatar
Joined Jan 2012
got it..
Motor and ESC showed up today....they are both huge!! I will post pics in a bit..
Scorp i pm'd you...
Old Feb 21, 2012, 07:38 PM
stiks's Avatar
Joined Jan 2012
ESC and motor
Turnigy 5692 1000kv 8mm shaft and Turnigy Aquastar 240a 12c 36.3v...the other picture is with a deck of normal playing cards....for scale.
The esc comes with no instructions nor does the motor.. The esc does come with the pictured extension and the usb programing stick. There is a link on the site for the software...we'll see..
Old Feb 21, 2012, 07:40 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
8s 2p I'm guessing? (& suggesting)
Old Feb 21, 2012, 07:42 PM
stiks's Avatar
Joined Jan 2012
The picture of the esc with the connectors on it. One i imagine is the cut off switch? The other is the rx connector and since there is no bec then the middle wire stays put... The last connector...is that for a separate power supply to the esc?
Old Feb 21, 2012, 07:43 PM
stiks's Avatar
Joined Jan 2012
bill .i am looking at 9s2p...... i was looking back at scorps thread..an exchange between you and him..is the x270 prop the way to go....looking for an excuse to pick up the thrust bearings
Old Feb 21, 2012, 08:01 PM
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Bill, we're swapping motors, he's getting my new 5692 780kv and I'm getting his 1000kv...............
scorpion1 is offline Find More Posts by scorpion1
Old Feb 21, 2012, 08:03 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
First off lets make sure you are going to use a 2p setup. I believe Bill and I both suggested a prop in the 52-55mm range..........
Old Feb 21, 2012, 08:30 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
That's right, I forgot all about that. I hate getting old and forgetful.
Sometimes it takes me hours to accomplish a simple task because I forget what I was doing and start working on something else
Old Feb 21, 2012, 08:33 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Heck, I've gone down to work on a boat and ended up cleaning the catbox...............then noticed the fish needed to be fed.............then etc......etc............
So Bill, with the 5692 780kv on 9s2p, you think an x452/x455?
Old Feb 21, 2012, 09:09 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Yeah, Im still thinking along the 452 - 455 range at least for a starting point. A stock S270 is way too much prop for that motor. It puts a pretty good load on a 2028 even. I know mine is cut down to about 60 mm and think your's is too best I recall.
Old Feb 21, 2012, 10:48 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Yeah.............no way it can spin an s270................
Question Exceed Racing 49" Hydro velyter Racing Boats - Internal Combustion 19 Aug 09, 2012 08:09 AM
Build Log Scorps 50" Hydro build scorpion1 Racing Boats - Electric 360 Feb 04, 2012 03:01 PM
Discussion Brushless Hydro Build kruiser7 Racing Boats - Electric 17 Sep 15, 2011 09:51 PM
Discussion 4 Cell 34" OutRigger Hydro Build / Photos / Design Details / 720P Video ryan_t888 Racing Boats - Electric 13 Jul 07, 2011 10:39 AM
Discussion build manual for Hydro Glider dlysell Foamies (Scratchbuilt) 4 Apr 27, 2011 10:22 AM
