Old Feb 13, 2012, 03:02 PM
stiks is offline
Find More Posts by stiks
stiks's Avatar
Joined Jan 2012
Bill, thanks...Scorp..that was the "adapter" i was after.. Bill that shaft is out of stock..do you have another source..or do they restock pretty quick at OSE?
stiks is offline Find More Posts by stiks
Old Feb 13, 2012, 03:14 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
Bill/Scorp..i put some stuff in my basket at OSE..
-prop-x455 2blade...
-flex coupler
-water jacket
I put myself on the email list for the "shaft" that i listed the picture for, since its on backorder..
Old Feb 13, 2012, 03:24 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
It doesnt look like OSE has a motor mount in that size...any suggestions?? for that and the "shaft"?
thanks
Old Feb 13, 2012, 04:42 PM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Shaft http://southriverrcboats.com/shop/ar...DS250-187-0%26 shows to be in stock
Motor mount http://southriverrcboats.com/shop/ar...WRP-5-30F-0%26 5" rail
or http://southriverrcboats.com/shop/ar...P-4-30F-400%26 4" rail depending on your rail spacing.
He makes the motor mounts on demand. Average 2 week wait for them.
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Freewing 80 mm Mig 21 Fishbed
Old Feb 13, 2012, 04:49 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
I emailed OSE and this is what they have on the mounts...$75.00 each..from china...these are for the leopard with that 30mm hole spacing..sorry forgot the motor model #
Old Feb 13, 2012, 05:53 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
The coupler doesnt show out of stock now? - http://www.offshoreelectrics.com/pro...oct-ocfhe8mm25
I must be looking on a different OSE cuz the flexshaft is in stock too..........
http://www.offshoreelectrics.com/pro...?prod=ose-1290
scorpion1 is offline Find More Posts by scorpion1
Old Feb 13, 2012, 06:03 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I just ordered several of these servo's for a land application and to replace the 2075 in Big Yellow. If these are anything like the specs indicate, these should be awesome for 22 bucks!! Alloy milled case, 200oz. of torque, and all metal gears!! I'll report back as to how they perform, but geez, at 22 bucks a pop and the specs, how can you go wrong?
http://www.hobbyking.com/hobbyking/s...dProduct=12451
Old Feb 13, 2012, 06:23 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Actually the 24" stepped down to .187 is out of stock but there are a couple of 30" ones available.
I need to grab one of the straight 1/4" ones myself. I want to try the cut down S270 on my cat but the 1/4" shaft I have is about 2" too short to run in it.
BTW that is a killer looking servo. If they're still in stock after you get yours I may have to grab a couple myself. If that was a JR it would be about $100.00 higher with it being coreless.
Old Feb 13, 2012, 09:37 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
Great looking servo by the way...!!
So Bill/Scorp...im ready to put in my order tonight. for OSE...
-flex coupler
-water jacket
do i need that flexcable that scorp listed...and the shaft Bill listed from southriverboats?
Scorp if i do the flexcable..which one 24" or 30" for 3/16..
or
24" or 30 for 1/4
Old Feb 13, 2012, 10:12 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
You need the longest 1/4" flexshaft with the stepdown to 3/16 at the propshaft end. Its all one piece........the one i linked. Then you can cut it to the length you need and not be short by getting the long one.
Old Feb 13, 2012, 10:18 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
just checked out...for better or worse..may have parts for sale or trade...lol
-Octura Coupler Flex Hex 8mm to .250
-Leopard 5692 & 5698 Water Jacket
-Octura x455
-OSE .250 Cable: - 30" cable for 3/16" Proppellers
-Octura Large Drive Dog for 3/16" Prop Shafts
-spektrum mr200 2.4ghz marine receiver....local hobby store
Old Feb 13, 2012, 10:29 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
thanks scorp...i was sweating that decision a bit...I will have to check out the spacing on the boat for that motor mount that Bill sent me.
How is that prop..x455 2 blade...I know 3 blades on a plane tend to provide more torque but less speed..is it the same on the boats..in other words was the 2 blade a good choice?
Old Feb 13, 2012, 10:45 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
Scorp what kind of runtime did you get from 10,000mah?
Old Feb 14, 2012, 04:26 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
On boats, a 3 blade tends to give a little more lift to the tail. If you wind up with the tail dragging a 3 blade might fix the problem. Otherwise, a 2 blade puts less load on the motor and will let it turn more rpm.
Here's the real kicker. On 10,000 ma expect run times of 4 minutes or less. Boats pull a lot of amps in comparison to a plane.
Old Feb 14, 2012, 01:40 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
Thanks bill...i was thinking about going lower on the mah to save $$'s on the battery purchases..but 4minutes on 10,000..i think i will stick with that!!
And just like with planes 4 minutes will seem like forever..
Question Exceed Racing 49" Hydro velyter Racing Boats - Internal Combustion 19 Aug 09, 2012 08:09 AM
Build Log Scorps 50" Hydro build scorpion1 Racing Boats - Electric 360 Feb 04, 2012 03:01 PM
Discussion Brushless Hydro Build kruiser7 Racing Boats - Electric 17 Sep 15, 2011 09:51 PM
Discussion 4 Cell 34" OutRigger Hydro Build / Photos / Design Details / 720P Video ryan_t888 Racing Boats - Electric 13 Jul 07, 2011 10:39 AM
Discussion build manual for Hydro Glider dlysell Foamies (Scratchbuilt) 4 Apr 27, 2011 10:22 AM
