Unless I'm mistaken scorp was running a cut down S270 on his big hydro, but it's being pushed by a Castle 2028 too. I'd suggest starting around a 452 or 455. |
Latest blog entry: Hobby King "SIX" hexa
I just PM'd you Stiks................... and i suggested basically the same props that Bill did before i saw his post.................we outta be close then. The Turnigy motor is about 75-80% as powerful as the 2028 is, so it cant turn quite as much prop...............
I dont know if OSE.........or anyone for that matter, sells a turnfin the size of my custom made one. You need a pretty beefy fin in my opinion. Mine probably cost about 50 cents in raw aluminum stock. |
FOR CONTINUITY; this was question scorp answered regarding the shaft and motor connection..
*scorp hope you dont mind... You wont be able to use the stock strut, its for a 5mm shaft. I had to buy a new strut from OSE and put it on..........i'd strongly suggest 1/4" driveline sytem. You can buy a flexshaft that reduces to 3/16" on the propshaft to use the prop sizes you will need...............i'd suggest somewhere in the x455-x457 range for 10s and x452-x455 for 9s. |
Here come the newbie questions:
So the drive line is the "stiff" piece see below: http://www.offshoreelectrics.com/pro...od=hug-b8666sp then the flex shaft is something different or are these one in the same?...starting out as 1/4 then changing to 3/16 |
Also on props, the 455 to 457 would probably be for 9s and the 452 to 455 for 10s. |
Yep, wrote it back wards:
"You wont be able to use the stock strut, its for a 5mm shaft. I had to buy a new strut from OSE and put it on..........i'd strongly suggest 1/4" driveline sytem. You can buy a flexshaft that reduces to 3/16" on the propshaft to use the prop sizes you will need...............i'd suggest somewhere in the x455-x457 range for 10s and x452-x455 for 9s." reverse these. |
Whoa..Whoa..just trying to get my ducks in a row.. Take it easy..the pics will come...Mozzy..or would you rather i buy a bunch of stuff then start asking a bunch a questions..
![]() The boat should be here today or tomorrow. The motor and esc have been ordered and are coming?? (from hobbyking). The servos will be in tomorrow. With that said..Bill do i need to purchase another part for that drive "rod" or is that it? I thought there was some type of coupler from the motor shaft to the drive |
You will need a drive coupler. Not sure of the Turnigy motor shaft size but guessing it will be 8mm? So you'd need one of these from OSE as well
http://www.offshoreelectrics.com/pro...oct-ocfhe8mm25 |
| Thread Tools | |
| Question Exceed Racing 49" Hydro | velyter | Racing Boats - Internal Combustion | 19 | Aug 09, 2012 08:09 AM |
| Build Log Scorps 50" Hydro build | scorpion1 | Racing Boats - Electric | 360 | Feb 04, 2012 03:01 PM |
| Discussion Brushless Hydro Build | kruiser7 | Racing Boats - Electric | 17 | Sep 15, 2011 09:51 PM |
| Discussion 4 Cell 34" OutRigger Hydro Build / Photos / Design Details / 720P Video | ryan_t888 | Racing Boats - Electric | 13 | Jul 07, 2011 10:39 AM |
| Discussion build manual for Hydro Glider | dlysell | Foamies (Scratchbuilt) | 4 | Apr 27, 2011 10:22 AM |
