Old Nov 05, 2012, 01:27 PM
stiks is offline
Find More Posts by stiks
stiks's Avatar
Joined Jan 2012
update
Ran this weekend; sunday the 4th out at Prado Lake in Chino, CA. The weather was pretty good..the Santa Ana winds are starting to pickup so it was about 80 degrees out...
Met up with the same group of fast boaters that i met up with out at Lake Evans..before they implemented the 15mph speed limit. Anyway, even though Prado cost $10.00 to enter..there is no limit to speed, size or type of boat...
I ran with GPS this time and got 54mph with that x457 octura prop on 9s2p. My temps ran for the esc=130 degrees, motor=128 degrees, batteries=80-90 degrees.
I still am not seeing any water flow out the sides during my runs but the consensus is that with those temps there must be something getting through. I am consider boring out the pickup holes on the rudder blade or even going back to the single pickup blade ..with a second pickup mounted on the transom..(like the original setup).. I aslso made some changes to my rudder servo setup so i am now getting better turns out of it as well..
Anyway here are a couple of vids. One is a walk by on the boats that came out on sunday, the other is of a nice flip..and lastly is mine. Please forgive the quality of my run..i had to hand the camera over to someone and he was doing alot of zooming and stuff so its kinda bad actually.
Also, the area we run is at the "bottom" of the lake so we can only run up the lake then back towards us...running side to side is kinda tuff because there isnt that much room. Pretty soon they parks people are going to cut away the weeds over to the left...once thats done then we can run the boats right out in front of us..left to right...then i can get in some nice big ovals.
Having problems with youtube..will post pics/vids shortly..
here are the vids:
me:
me (4 min 8 sec)
everyone:
everyones boats (1 min 13 sec)
don 1 of 2...checkout 1:12..:
don (1 min 28 sec)
don 2 of 2:
don after crash (0 min 13 sec)
dan problems...looks like a timing issue??:
dan problems (2 min 18 sec)
stiks is offline Find More Posts by stiks
Old Nov 06, 2012, 04:49 AM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
The lake looks a little on the tight side for bigger boats. I thought on a couple of occasions your's was going to be in the cat tails.
The last clip looked / sounded more like a loose connection between the esc and motor or possibly a rx issue.
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Nov 06, 2012, 02:42 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
Bill, yep..it was pretty close for me too...!! I was a little hesitant on posting that video of my run..i was sort of doing ovals and straights and everything....sort of all over the place. But as i mentioned hopefully they will cut back those weeds then we can do pure ovals...that would be great!!
So i am going to change out that rudder for next weekend and go back to my transom pickup and see if that makes a difference.
Right now my strut is at its lowest point with the x457....should i raise it up a bit? Will that give me more speed?
Old Nov 10, 2012, 04:30 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
Going out tomorrow...sunday. Raised the strut a bit to see if i can pick up a little more speed. Also, swapped out the 2 pickup rudder with the original single pickup and added the original pickup on the transom. I will post some pics from the lake.
Old Nov 12, 2012, 12:56 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
Sunday the 11th run
Here are some pictures from this past Sunday the 11th. Several of the guys came out, pretty much the regulars. It was a little cold out probably around 55 degrees or so and about a 20 to 25 mph wind coming out of the east..
The bigger boats had no issues withe wave caps headed out into the lake as long as you kept the speed down and you could blast back into the shore with wind at your back for some outrageous speeds!!
Everyone had really nice runs..there where a couple of nice flips due to some wave jumping .. But no real damage. I hit something on the lake during my run and it sheared the rudder bolt on my hydro...luckily that was the only damage. Will post the vids shortly...
Old Nov 12, 2012, 07:40 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Hmmm your idea of shortly must be diffeent from mime
Old Nov 12, 2012, 11:55 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
Sorry about the delay on video.. Loaded the pictures at work..but no access to youtube...now im home and my memory stick is hosed....
Old Nov 13, 2012, 01:44 AM
stiks is offline
stiks's Avatar
Joined Jan 2012
Here is the link to all our video from this past sunday...
http://www.rcgroups.com/forums/showp...3&postcount=17
here is me:
me
me (0 min 45 sec)
tug
tug (0 min 51 sec)
the tug is a conversion to a brushless inrunner. 35 amp seaking, with 6v mini pump for cooling..
Old Nov 21, 2012, 05:11 AM
Wilian Amaral is offline
Find More Posts by Wilian Amaral
SENTA A PUAAA!!!
Wilian Amaral's Avatar
Brazil, RJ, Miguel Pereira
Joined Apr 2007
Have you solved the cooling issues, Stiks??
I would suggest you to install a small 12v car water pump ( those for the windshield spray). they're small light and inexpensive.
Wilian Amaral is offline Find More Posts by Wilian Amaral
Old Nov 24, 2012, 01:00 AM
stiks is offline
stiks's Avatar
Joined Jan 2012
Went out last weekend and no one showed up...so didnt get to run..no recovery boat. Plan on running this sunday..will post update then.
stiks
Old Nov 26, 2012, 08:34 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Crying wolf again I see. One of these days we're going to stop coming back to look..
Old Nov 28, 2012, 01:14 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
New pics november 25th 2012 Prado
Ok Ok....sheesh.... Sorry it took awhile..been busy at work. Hospitals always try to squeeze in all there projects by the end of the year...$$$$ use it or lose it
Anyway, here are the latest pics and video. This is turning out to be a regular thing for me...i think maybe its the lower quality parts showing their true colors or what...but had another day ending break at the lake this weekend.
As you can see my rudder is ..just hanging there. The little piece of brass tubing or rod that holds the rudder to the assembly came out and once it did the rudder just worked itself free.. Talking to the older boaters the first thing they asked was did you have the grub screw in there... Well to be honest ...no i didnt.. But in my defense there was no grub screw that large in the original shipping.
Everything that i ordered for this boat including paperwork is all in one spot in the hobby hut...(garage) I double..no tripple checked and there is no grub screw "leftovers".. I had noticed that the little rod did move up and down a bit when tinkering with the rudder hardware before..but never noticed that grub screw hole until the rudder was actually out of the assembly.
Well needless to say i guess i dodged a bullet on that by not having everything broken or bent all to h....ll!! ...
Anyway, my buddy bob has a bunch of bolts and stuff so i trekked on over and found this "bolt"..it fits just right into that "holder" for the rudder. After a bit of cutting and filing; thanks bobby!!! I was able to use it ...WITH A GRUB screw..to hold it in place So i should be able to go out this next weekend.!!!
I managed to dig up some batteries from friends that no longer use them and made a few connectors to accommodate my setup...so i had planned on running a couple of times, but since this happened on my first run i was done for the day..needless to say..no gps this time Next time though!!
Will have to do the video later...work is blocking youtube...
Old Dec 01, 2012, 05:10 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
Getting ready for tomorrow. Its been raining here the last few days and its supposed to start again ...but not until late Sunday...so we'll see.
I tried to connect up some additional batteries that i have..must have connected something wrong. Got a pretty big arc out of 2 6cells...it melted the connector and some of the wiring..also..3 of my fingers are black..... There was no pain or anything but you can see where the skin melted a bit...on my thumb and index finger.. It looked and sounded like the batteries where going to blow up...but i managed to disconnect them. The battery connector must have touched at some point. I can still pick my nose with the best of them..lol..
Old Dec 03, 2012, 03:52 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
No running this past weekend..dec 2nd. I got the call from my buddy Dan and he said it was raining down in that area...as it pretty much did all over.. So nobody went out...
Getting batteries together for next weekend..weather report says its supposed to clear up...we'll see...!!
Old Dec 03, 2012, 03:58 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
Thinking about getting one of these....when everyone is done with their big boats they all have smaller ones to run...they vary in size in type..but this one is pretty cool...!!
http://www.hobbyking.com/hobbyking/s...g_n_Drive.html
Question Exceed Racing 49" Hydro velyter Racing Boats - Internal Combustion 19 Aug 09, 2012 08:09 AM
Build Log Scorps 50" Hydro build scorpion1 Racing Boats - Electric 360 Feb 04, 2012 03:01 PM
Discussion Brushless Hydro Build kruiser7 Racing Boats - Electric 17 Sep 15, 2011 09:51 PM
Discussion 4 Cell 34" OutRigger Hydro Build / Photos / Design Details / 720P Video ryan_t888 Racing Boats - Electric 13 Jul 07, 2011 10:39 AM
Discussion build manual for Hydro Glider dlysell Foamies (Scratchbuilt) 4 Apr 27, 2011 10:22 AM
