Old May 09, 2012, 04:51 PM
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Let me check, if not I'll go snap a photo. Yes, on the right is where i put it cuz the waterlines came in on that side. The hull is so big that the bit of weight on that one side doesnt really matter.
scorpion1 is offline Find More Posts by scorpion1
Old May 09, 2012, 09:06 PM
Darrell Upland,CA
smokeout42o's Avatar
Joined Dec 2011
Originally Posted by stiks View Post
I think i figured out the setup for the water pickups. Although i have 3 pickups; 2 on rudder and 1 on transom, i am only using the 2 from the rudder.
I have 1 from the rudder going to the cooling tube connector for the motor...then the drain going out the side.
The 2nd pickup off the rudder goes into my esc... The esc has a 3 inlets and 3 outlets. I plugged the single inlet line from the rudder into 1 of the esc inlets...then i interconnected the other 4 plugs....that leaves 1 that goes out the side as a drain... If you look at the pictures you can see the loop back tubing that connects all the inlets..think of a spiral staircase going down...the feeding tube from the rudder comes in ...the water swirls down and around the esc...then out ...too much imagination???
Once i have get ready to mount the esc i will cut out the excess tubing...
Lol...wow looks like alot going on here with in and outlets!! that esc is crazy!! Sucks that you fried one scorp!!
smokeout42o is offline Find More Posts by smokeout42o
Old May 10, 2012, 10:32 PM
stiks's Avatar
Joined Jan 2012
esc position change
Scorp on you suggestion i moved the esc to the right of the motor. In moving the esc i had to change the connections for the drains.... Here is a pic of the moved esc and now the rerouted tubes to the cooling tube... I had to move the cooling tube around on the motor a bit ...then i just decided to slide it off the motor...find a good spot...then put it back on...
Do you think it will get good flow to the cooling tube in this configuration?..btw the inlet tube for the esc is in a straight line..so it should get good flow to the esc
The line on the right is the inlet....the line on the left is the drain..
stiks is offline Find More Posts by stiks
Old May 10, 2012, 10:58 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Sorry i never got the picture..................just forgot, but yes, thats perfect, this way the inlet line goes smoothly into the ESC, then makes the turn at the other end and comes back out of the rear to then feed the motor.
Old May 25, 2012, 12:41 PM
stiks's Avatar
Joined Jan 2012
Back again..again..on top of work..as usual... i have a teen graduating so its been really busy..
Did some modifications last night. The piece of wood i cut out in order to get inside of the boat for the turn fin has now been put back inside. I used a combo of wood glue, supper glue and wood filler. Also soldered up the additional connectors for the esc to motor connection. Since i am now moving the esc inside of the boat ...to the right of the motor....i needed longer extensions. At work right now but will post photos later. Now the big part is getting the servos to "sync"...i think the connecting rod is to short..have to lengthen it so they can move together...right now when i put power to the servos you can hear them "chattering"..
Old May 26, 2012, 12:35 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Thats exactly where I have my ESC.........same direction too!!! You would have been very disappointed with the other location..............keeping the ESC lower in the boat ensures better flow and cooling!
Old Jun 07, 2012, 10:46 AM
stiks's Avatar
Joined Jan 2012
Back again. I had a bit of an offline conversation with Bill regarding my esc. See below...
Re: aquastar 240a esc question
MY QUESTION TO BILL:
Bill, i have been checking on the blogs for information on connecting the turnigy aquastar 240amp esc to the rx and i came across your name and some entries from one of your builds. I am having problems getting it to power up. I have a spektrum 3c tx and a spektrum marine rx. I am able to bind the rx to tx with no issue but when i connect the aquastar to the battery and rx and connect a nimh 6.v pack to the rx the esc does nothing...no motor control..no beeps...any ideas?
BILL'S REPLY:
The Turnigy 240 and the Swordfish 240 are the same esc with different labeling. Your message didn't mention if you were connecting your lipo's to the esc but it has to have voltage applied to it as well before it will function. It also has to be connected to the motor.
There is also an arming switch on the esc. It's best to have it switched off when connecting your lipos. After the rx is on and lipos connected you should set throttle endpoints as well. Pull the trigger to full throttle then turn on the arming switch for the esc. After a second or two it should beep. After it beeps release the trigger to the neutral point and it will beep again then should start beeping the cell count of you packs. Once that has finished it should be ready to go.
Not sure if it's required on a Spektrum, but on Futaba and the cheapie Tactic radios I use you also have to have the throttle channel set to reverse before the esc will arm too.
Other than that I'm pretty much out of ideas except for suggesting that you want to be sure you are plugging the esc into the right channel on the rx and that the polarity is correct. The black lead needs to be on the same side as the black lead from your rx pack and steering servo.
Hope this helps
Bill
I will post pics and more details tonight.
Old Jun 07, 2012, 12:11 PM
stiks's Avatar
Joined Jan 2012
Bill, here are some additional details:
I plugged the esc, motor and battery together. The battery is a single 5c 5000mah pack that has a small charge on it. My plan was to just use it for testing.
The tx i have is the dxc3 3channel controller. The rx is the mr200 both by spektrum. I bound the rx to the tx by going through the menu and selecting bind on the tx. With the bind plug in the specific port and a nimh 6 v battery as a power source bound the tx to the rx. The blinking light on the rx stopped and is now in sync with the tx. I then removed the battery and bind plug.
I connected the esc; with lipo battery, and motor connected, to the rx using the single long wire from the esc. I plugged this into the throttle port on the rx.
As i read the directions from the aquastar esc; found online. I plugged the 6v nimh battery rx pack into the bind port on the rx. The esc plug is already in the esc. I then turned on the tx while holding the throttle to full. The tx powers up and then the rx power comes on...and then nothing....
Would not setting the throttle channel to reverse cause that? If so then i imagine i need to set it on the tx before powering up the rx?...then repeat the turn on sequence?
Old Jun 07, 2012, 01:41 PM
stiks's Avatar
Joined Jan 2012
Still reading.
The aquastar esc comes with a small Y cable attachment. That is used for programing the esc using the usb link that came with it. When you get the esc you have 2 ways power the unit up for programing. One way is by connecting the unit directly to a lipo battery then into the usb link using the same connector you use on the rx for throttle. The other way is to use a little Y cable that comes with the esc.. On the Y one end goes to the usb stick and the other connects to what looks like a short red and black power connector on the esc and then it ends in 2 loose red and black wires. I guess the idea is that power is provided solely over the usb link.
Well in a posting i read on the OSE forum....it sounds like using that Y connector someone connected there rx battery pack to those small red and black wires at the end of the Y...to power on the esc...which then feeds power to the rx. So in other words..no direct power to the rx....it goes to that red and black short connector on the esc...and it powers the rx??? ..here is the link from OSE its post #5 :
http://forums.offshoreelectrics.com/...r+esc+no+power
Old Jun 07, 2012, 04:53 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I think you may have misread something. You don't need to have the trigger pulled to turn on your rx. Turn on the TX, turn on the RX, check your steering servo to be sure it's armed. (you might also try plugging a servo into the throttle port to verify it works).
After the TX & RX are working plug in the lipo for your esc. Pull the throttle to full and turn on the arming switch for the esc. After a second or two it should beep. After makes the beep release the trigger to neutral and it will beep again then start counting the cells in your pack.
Also note that you need the voltage from a 5s pack minimum to get the esc to work. It will not arm with a 4s pack or smaller.
If it still doesn't work change the servo reversing switch on the throttle channel to reverse (re bind the RX after reversing to play it safe) and try the process again.
If it still doesn't work you may have a dead esc.
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Hobby King "SIX" hexa
Old Jun 07, 2012, 10:28 PM
stiks's Avatar
Joined Jan 2012
Bill, i connected the rx to a servo and using the tx i am able to manipulate the servo; in both the throttle and steering ports on the rx.
I did a full charge on my 5c 5000mah pack and went through the steps you outlined above. After connecting everything ...the esc is not powering up...no beeps..nothing.
I tried changing the port for throttle to reverse and i even redid the binding and still nothing. Originally i was able to perform the programing on the esc via the usb stick ...so i want to go back and try that again..but will being able to program mean the esc is functional..or ...am i just making program changes on the usb stick..(its a conspiracy...only the usb stick works!!)..this would really BLOW if my esc never worked...how long has it been since i got that thing...!!! and its never been used!!!
Old Jun 08, 2012, 04:20 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Before giving up try it with a 6s pack or a couple of 4s in series to make 8.
Does it make a spark (charging the caps) when you plug the pack in?
Old Jun 08, 2012, 09:04 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
If its the 240a hv(same as the Swordfish) I give full throttle while turning switch on and then it gives a little "song", I release to neutral.
Do you know yours has a switch?
Old Jun 08, 2012, 11:25 AM
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Stiks,
In addition to your re-routing of the cooling lines; see if you can get the outlet in the highest spot, to avoid trapping air inside the jacket.
The picture shows my Turnigy 3674-B-1900Kv in my Arowana, the blue tube is the outlet.
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Question Exceed Racing 49" Hydro velyter Racing Boats - Internal Combustion 19 Aug 09, 2012 08:09 AM
Build Log Scorps 50" Hydro build scorpion1 Racing Boats - Electric 360 Feb 04, 2012 03:01 PM
Discussion Brushless Hydro Build kruiser7 Racing Boats - Electric 17 Sep 15, 2011 09:51 PM
Discussion 4 Cell 34" OutRigger Hydro Build / Photos / Design Details / 720P Video ryan_t888 Racing Boats - Electric 13 Jul 07, 2011 10:39 AM
Discussion build manual for Hydro Glider dlysell Foamies (Scratchbuilt) 4 Apr 27, 2011 10:22 AM
