Old Mar 01, 2012, 07:30 PM
stiks is offline
Find More Posts by stiks
stiks's Avatar
Joined Jan 2012
Scorp..checked your battery position on the old post ...on page 21..you had moved the batteries much further forward...was that where you ended up with them in the end?
stiks is offline Find More Posts by stiks
Old Mar 01, 2012, 08:05 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Just learned something new.................you can link an individual post by clicking on the post number in the top right corner
http://www.rcgroups.com/forums/showp...&postcount=256
Oh........and there is no page 21 stiks
scorpion1 is offline Find More Posts by scorpion1
Old Mar 01, 2012, 08:41 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
http://www.rcgroups.com/forums/showt...379537&page=21
page=21.....nuff said...lol
Old Mar 01, 2012, 10:29 PM
hotlinercort is offline
Find More Posts by hotlinercort
Joined Jul 2011
stiks here is a link for that tug you mentioned...
seaport work boat brushless (1 min 45 sec)
hotlinercort is offline Find More Posts by hotlinercort
Old Mar 01, 2012, 10:54 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Originally Posted by stiks View Post
Was that the picture you needed?
Oh............we all have different post settings, so I only have 15 pages, i have more posts per page
15 of 15 LOL
Old Mar 02, 2012, 02:55 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
Scorp so what do you think about that grub screw...should i just drill it out of there? ..since i wont be using that dog nut or shaft...??
Old Mar 02, 2012, 07:07 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
If you're not using the Drive Dog(not dog nut) or the shaft why even bother with it?
Old Mar 03, 2012, 02:24 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
Thats what i needed....cutting away!! Received update that the motor mount has been shipped..will be posting pics this weekend..
Old Mar 03, 2012, 02:51 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
Scorp, after my last message i checked the mail and the motor mount is here. Right now i am staging things up to get a feel for the positioning..
Question, on the cooling tube..do i need to apply some "grease" or something to get the tube over the motor?
Old Mar 03, 2012, 04:11 PM
bill34207 is online now
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Yeah, you need some grease, oil anything to make the O rings slipperey while sliding the cooling jacket into place. If it's a HRC jacket, it even tells you that on the label.
bill34207 is online now Find More Posts by bill34207
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Mar 03, 2012, 05:23 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
more tear down pics
Scorp, i cut down the existing dog nut so i could get the existing shaft out..here are some pics.
After i cut the nut off there was a plastic washer and sort of a "guide" washer that kind of fits inside the metal shaft "holder"..it fits my shaft so i guess i can use it again..??
Question, when i removed the old original shaft ..as i was pulling it out there was another internal tub..i just pushed it back inside...so i guess that is ok??
As i pushed in my new shaft it slides in good enough but it stops before exiting the back of the metal shaft "holder" ..i took pictures of both the new shaft..on the left and the old shaft on the right..as you can see the new shaft has a "ridge" on it...i think that is preventing me from pushing it all the way out the back...can/should i grind that down??
I'm going to have to get another shaft arent i?????
Old Mar 03, 2012, 05:45 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
On the old shaft...after the main length..were it gets smooth..its 4.9mm...then the threads
On my new shaft..its 6.3mm then it steps down to 4.7...then the threads...
So that area on my new shaft that is 6.3mm needs to be 4.9 at least...
I looked inside that shaft "holder" metal piece and there is some type of collar that is keeping the shaft from coming out the back..
IM GOING TO NEED A NEW SHAFT ARENT I.....?? AHHHHHHH!!!
Old Mar 03, 2012, 06:16 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Take good look inside the bore of the strut. Chances are you will fins a couple of bushings that you will need to knock out. Once they are gone you'll probably need a piece of 5/16" brass tube to fit inside it. That brass tube will be the right size for a Speedmaster bushing yhat will fit your flex shaft. http://www.offshoreelectrics.com/pro...ds-015-bsf-250
Old Mar 03, 2012, 06:24 PM
stiks is offline
stiks's Avatar
Joined Jan 2012
Bill, thanks for the tip..so those bushings can be knocked out of there?..with a flat head and hammer? Right now the plastic tube comes out of the boat and into the "strut"...am i knocking the bushings back inside ...??
If that link is what i need i will order right now!!!! ..im ready to start building....!
And of course they are out of stock...
this is the ose part i have OSE-1290...OSE .250 cable: 30" cable for 3/16' proppellers..... So this adapter is for my shaft?? just want to confirm..
Old Mar 03, 2012, 07:07 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Got to this page. http://www.rcgroups.com/forums/showt...1478759&page=3 (or post 32 and post 36) That should give you a good idea of what it entails. At leas that's what I did with mine.
I saw the bushing was out of stodk when I listed it for you. He's also got them for a "stinger" that are in sttock. http://www.offshoreelectrics.com/pro...s-spds-015-bsf I'm not 100% sure on the OD of that one though.
Question Exceed Racing 49" Hydro velyter Racing Boats - Internal Combustion 19 Aug 09, 2012 08:09 AM
Build Log Scorps 50" Hydro build scorpion1 Racing Boats - Electric 360 Feb 04, 2012 03:01 PM
Discussion Brushless Hydro Build kruiser7 Racing Boats - Electric 17 Sep 15, 2011 09:51 PM
Discussion 4 Cell 34" OutRigger Hydro Build / Photos / Design Details / 720P Video ryan_t888 Racing Boats - Electric 13 Jul 07, 2011 10:39 AM
Discussion build manual for Hydro Glider dlysell Foamies (Scratchbuilt) 4 Apr 27, 2011 10:22 AM
