Old Feb 19, 2012, 01:42 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Hmmm... Today I glassed the forward center section of the wing on the pylon plane I'm building. I didn't trust the foam/epoxy/wood/steel sandwich and I hate feeling shy on the elevator stick with planes like this. I want to be able to crank it around as hard as the airfoil will let me without worrying about the wing ripping off.
It's insanely tough now
I also replaced the shaft in a little 24mm 3790Kv HobbyKing inrunner. Great motor for a plane like this on a 4.1x4.1 prop. I might end up using it instead of the 4.5 ounce monster that's in it now; the little purple motor is almost 1.5oz lighter I flew a different pylon plane with it once and it was fast as a mofo until the wing snapped...
Piece is online now Find More Posts by Piece
Old Feb 20, 2012, 10:08 AM
HeeBeeGeeBee is offline
Find More Posts by HeeBeeGeeBee
Lysdexic I'm
HeeBeeGeeBee's Avatar
Spring, TX
Joined Oct 2010
Completed the Phase 3 EF-16. She's all set up, balanced and ready to rip. Now for time to maiden her...I can only hope it'll be soon.
HeeBeeGeeBee is offline Find More Posts by HeeBeeGeeBee
Old Feb 20, 2012, 09:34 PM
Piece is online now
Piece's Avatar
Joined Aug 2009
I just ordered me one of those adhesive-backed light strips from Value Hobby, as well as a wattmeter. I figured it was time
I'm sort of ridiculously excited about the light strip. Just one of them isn't really enough for a true night flyer, but if it's good I might pick up a few more. Even with just a little illumination I've found that can fly much later into the evening, so it should open up more flying opportunities during these winter weekdays that are short on daylight.
Old Feb 21, 2012, 02:08 PM
dkrhardy is offline
Find More Posts by dkrhardy
United States, FL, The Villages
Joined Oct 2010
I did maiden the MX2 last Friday and found a dropping wing. Landed safely, played with it a bit, flew out the rest of the battery. Still dropping a wing. Came home, asked a lot of questions and found that the DX8 has adjustable trim "rates" in a sub menu. Don't think the 6i had that! Factory default setting is 5 out of 10 and each click barely moved a surface. Set it to 8 out of the 10 and each click moves the surfaces about like the 6i did. Also found one aileron not quite flush. Fixed it. Going out today! So today I did the fixing and today I will fly it again. So I hope what I do is successfully fly it!
Don
dkrhardy is offline Find More Posts by dkrhardy
Old Feb 25, 2012, 04:39 AM
809Flyer is offline
Find More Posts by 809Flyer
809Flyer's Avatar
United States, FL, Weston
Joined Jan 2012
I got my AMA card in the mail today... Time for some flying...
809Flyer is offline Find More Posts by 809Flyer
Old Feb 25, 2012, 08:35 AM
dkrhardy is offline
Joined Oct 2010
Didn't get to fly on the 21st, too windy. It's been bad all week, but tomorrow is SUPPOSED to be good. So all this week I've been setting, checking, re-checking a few planes to get ready for tomorrow. Just pidling.
Don
Old Feb 25, 2012, 11:05 AM
scootrb4 is offline
Find More Posts by scootrb4
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
I assembled & re-powered the new PZ Spitfire MkIX
Looks like this thread needs some PICS
scootrb4 is offline Find More Posts by scootrb4
Old Feb 25, 2012, 11:09 AM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
Also, getting ready to maiden the HK AT-6 Texan here at the ranch.... .... think I will put some shipping tape over the underbelly while the color is still good.... I'm waiting for the morning heavy dew to dry off a bit.
Old Feb 25, 2012, 01:19 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
What did you do to your plane today?
I looked at them.
I looked outside at the perfect flying conditions, the first in weeks.
I remembered it's Saturday, and I had finished any shopping.
But. I knew the flying site I use, (a sports field), would be covered in people kicking footballs about,
I hope someone else had a good day.
eflightray is offline Find More Posts by eflightray
Old Feb 25, 2012, 01:47 PM
Piece is online now
Piece's Avatar
Joined Aug 2009
I got my new wattmeter in the mail today
I soldered up some Deans connectors and also added JR receiver plugs for testing radio setups and BECs. I haven't actually tested any planes yet, but I've got a pack on the charger just for that purpose.
I have been testing my ghetto-rigged lipo-powered computer speakers, though. It seems that they draw a max of about 0.49A at 11.7V when Brad Paisley is singing about camouflage, and roughly 0.31A when Busta Rhymes is rapping about.... something... He's going too fast to understand
Very cool little device. I can't wait to see what kind of power my planes are actually running.
Old Feb 25, 2012, 06:33 PM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
It took three tries to get the little AT-6 to stay in the air! If you're not careful the little bugger likes the ground So ...... I'm putting an 8x6 ACP prop on it ( I broke both of the lightweight SF 7x6 that came with it) and a little more packing tape
Old Feb 25, 2012, 08:07 PM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
I did the final trim and glued the razorback to my Jug today. smoothing the lines is next
JDMJim is offline Find More Posts by JDMJim
Old Feb 27, 2012, 04:28 PM
VARSITY is offline
Find More Posts by VARSITY
United Kingdom, England, Oxford
Joined Feb 2012
Today I moved the tail wheel on the two Champs from the rudder to the fuselage, you have to start somewhere. AND, a few weeks ago I switched the wires over in the mcx2 plug so the flashing side lights are permanent navigation lights
VARSITY is offline Find More Posts by VARSITY
Old Feb 27, 2012, 09:23 PM
Billypark is offline
Find More Posts by Billypark
Joined Dec 2010
Whaddaya think I did. I broke it in half
After installing my third pack, noticed the ailerons hard over to right. So took it to shop and found most of the time the servo wanted to jam full right. The Rx ready plane only had 9 flights, but I replaced the bad servo with another Chinese servo, all the while congratulating myself on preventing the crash that would have come from that bad servo
So.......... on take off it rolled to the left and broke in half Not wanting to loose a good calm day, I flew my heli and P38. All the while wondering how that plane could have been so out of trim, as I was applying plenty of right rudder, then aileron when up to speed. Then it hit me check the direction. Sure enough it was reversed, never thought about that. After over 30yrs of rc aircraft you would think I would know to check direction at pre-flight. I usually do.
Oh well she is almost ready to fly again
Billypark is offline Find More Posts by Billypark
Old Feb 28, 2012, 12:36 PM
mrodgers is offline
Find More Posts by mrodgers
United States, PA, Butler
Joined Jun 2006
Didn't do anything today, but last Friday I took my UM T-28 out of the trunk of my car. It's been in there since October. Will probably have to wait until May to fly it because of wind.
mrodgers is offline Find More Posts by mrodgers
Discussion What did you steal from the field today? Jim Varley Arizona Model Aviators 9 Nov 09, 2011 10:14 AM
Discussion What did you fly today? xrx1113 Electric Plane Talk 4 Oct 25, 2011 09:37 PM
Discussion What's the most lights you have put on your HZ Champ and what did you use newflyer100 Micro Ready-to-Fly 0 Jul 12, 2011 10:27 PM
Discussion What did you do to/for your Heli today? roady89 Mini Helis 20 Oct 04, 2010 09:24 PM
Discussion What did you do for your planes today? This week? I'm Rick James Slope 135 Sep 25, 2008 09:21 PM
