Old Sep 22, 2012, 08:39 PM
Endlesslag's Avatar
USA, VA, Spotsylvania
Joined Jan 2011
Played with my new x9303
Also finished the repair on the beechcraft and fixed and balanced the t-28.
I'd call that a productive day!
Endlesslag is offline Find More Posts by Endlesslag
Old Sep 25, 2012, 10:55 AM
United States, CA, San Rafael
Joined Mar 2012
I built a new fuse (tractor) for my sky surfer and cut the wing tips off to make it more fun to fly!
Averan is offline Find More Posts by Averan
Old Oct 09, 2012, 06:59 AM
looking up down under
scruffy1's Avatar
Australia, NSW, Fairlight
Joined Feb 2008
having received the bits yesterday i needed to get on with finishing my durafly slick-360, i managed to tear one of the newly modified motor leads near the plug end i had attached
so today i managed to solder the wire (which is the calibre of pubic hair) after sanding off the invisible coating on that lead that comes from the windings and then tinning it with solder
i then went even more adventurous, and stripped the insulation from the bigger wire before re-doing the heatshrink, to save weight and make it more petite
thank god for a binocular loupe and strong daylight
even more astounding, it works !
scruffy1 is offline Find More Posts by scruffy1
Old Oct 09, 2012, 05:30 PM
Low'n Slow is safest, right?
KaiWE's Avatar
Norge, Østfold, Fredrikstad
Joined Jun 2011
Glued my Dynam Pitts Python together after ejecting the battery in a outside loop, resulting in a nosedive to the ground from 30ft+
Velcro decided to part with battery, so from now it will be straps
Not to much to glue, this plane is really robust and took the crash with minimal damage.
It went down out of sight, and I asked my buddy to come with me to pick up all the parts - when we got sight of the plane, it was all in one piece, just cracks here and there
KaiWE is offline Find More Posts by KaiWE
Old Oct 09, 2012, 11:47 PM
Always puts it on the numbers.
Spookeay's Avatar
United States, AL, Sylacauga
Joined Jul 2012
Originally Posted by KaiWE View Post
Glued my Dynam Pitts Python together. I asked my buddy to come with me to pick up all the parts - when we got sight of the plane, it was all in one piece, just cracks here and there
Dynam is a pretty good plane...Any one who knocks them has never had one I say....... as for doors coming off,,,, and battery's getting ejected.... Yep been there Have the video to prove it.
PT 17 (2 min 39 sec)
Spookeay is offline Find More Posts by Spookeay
Old Oct 10, 2012, 05:29 AM
scruffy1's Avatar
Joined Feb 2008
2x 3s 370mah through the bonsai, and 2x 2s 750mah as well - more sedate, but flies forever
at time for recharge i discovered that a 9 minute flight with the 2s 750mah hadn't even used enough to be able to get the charger to top it to 50% for storage - i presume there's 20 minutes of gas in that tank
Old Oct 10, 2012, 08:33 AM
Joined Sep 2012
Nice tx!
I bought a cheap 2.4g recently. I already have a DX7 (old one), but with my cheap 2.4 I have an amplifier connected that gives me more ranve on my fpv. Previously, I was only able to do a 1/4 mile with my DX7, even though Spektrum says it should go further.
Eli Lipschitz is offline Find More Posts by Eli Lipschitz
Reply With Quote  (Disabled)
Old Oct 10, 2012, 08:51 PM
scruffy1's Avatar
Joined Feb 2008
i completely destroyed my spitfire
spiraled in from relatively low - i had been concerned that it was out of trim - landed beautifully, checked the trim against the transmitter settings, made sure the controls were fine, and was still dissatisfied as i took off again because it kept tracking to one side
after the post mortem, all the bits work fine, so i doubt radio failure as no other transmitters likely where i fly
my surmise is that in adjusting the trims at too low a level while going too slow, i tip stalled and the rest is now history
pity, because i love(d) that plane
Old Oct 10, 2012, 09:16 PM
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
Dynam FW190, came with one prop( everyone else seemed to get 2), crap esc, something causing contiuous brownouts( bad servo overcurrent or servo's just not up to teh task of a big plane), battery recommendations too small. retracts went defective after 5 flights( had to tear the plane apart to return them, therefore damaging my new plane.
that was my first and last Dynam ARF.....anything I get will only be in kit form...
JDMJim is offline Find More Posts by JDMJim
Old Oct 11, 2012, 09:18 AM
resU deretsigeR
Belgium, Vlaams Gewest, Brakel
Joined Jul 2012
I finally got someone to film my Wild Hawk properly while I was flying it last week-end...
Although he had to keep on talking the whole time, I think it worked out quite well...
If you don't understand Flemish (Dutch) , more specifically the South-East-Flanders accent, you might wanna mute the video, and put on some music
Another Wild Hawk movie... but properly filmed this time! (12 min 59 sec)
Enjoy!
T.
CrosstownTee is offline Find More Posts by CrosstownTee
Old Oct 11, 2012, 04:39 PM
Getting good at foam repair
GTrain's Avatar
Australia, QLD, Surfers Paradise
Joined Aug 2012
Used my EPP profile 3d plane to practice hammerheads / cuban 8s / inverted flight and outside loops so I can build stick memory and not risk my good looking planes!
GTrain is offline Find More Posts by GTrain
Old Oct 17, 2012, 08:12 PM
JDMJim's Avatar
Joined Jul 2011
added some color to my scratchbuilt bipe. plans found on this site
Old Oct 17, 2012, 09:23 PM
scruffy1's Avatar
Joined Feb 2008
care to give us a hint where ?
Old Oct 18, 2012, 09:28 AM
JDMJim's Avatar
Joined Jul 2011
here-
http://www.rcgroups.com/forums/showthread.php?t=497522
Old Oct 18, 2012, 10:53 AM
United States, ID, Burley
Joined Mar 2012
i built this,also got to fly the super sky surfer !
fastfwd is offline Find More Posts by fastfwd
Discussion What did you steal from the field today? Jim Varley Arizona Model Aviators 9 Nov 09, 2011 10:14 AM
Discussion What did you fly today? xrx1113 Electric Plane Talk 4 Oct 25, 2011 09:37 PM
Discussion What's the most lights you have put on your HZ Champ and what did you use newflyer100 Micro RTF 0 Jul 12, 2011 10:27 PM
Discussion What did you do to/for your Heli today? roady89 Mini Helis 20 Oct 04, 2010 09:24 PM
Discussion What did you do for your planes today? This week? I'm Rick James Slope 135 Sep 25, 2008 09:21 PM
