Old Aug 27, 2012, 11:04 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Today I finished up the newest plane in my hangar. It's a replacement for the one in my avatar which was destroyed a week ago due to an aileron servo failure (still my fault, though). I made a few needed improvements to this one and it came out two ounces lighter and significantly stronger
This picture gets the idea across, but it was too dark to get any good shots by the time I had her totally done today.
Piece is offline Find More Posts by Piece
Old Aug 28, 2012, 12:11 AM
diddoo is offline
Find More Posts by diddoo
Australia, VIC, Altona Meadows
Joined Jul 2012
NIce plane... what model is it? or is it a scratchy?
diddoo is offline Find More Posts by diddoo
Old Aug 28, 2012, 05:17 AM
3dkiwi is offline
Find More Posts by 3dkiwi
Joined Aug 2012
inside out
have a few hk 3d hawks and the last one i extended all the control arms and put two servos on the ailerons.cut foam away so you get absolute max throw on everything..This plane turns inside out on high rates, can crawl along or zoom around. You can run the battery flat doing summersaults on the spot for 10 minutes full throttle with no ill effects. wing flex is out of control to watch and you have to carve enough of the ailerons so as not to snag on fuselage when diving and spinning. can be taken out with carbon spar...but why would you when it cracks you up as it flys so great trying to snap its own wings off. It won't happen though, for the price it is a blast of fun. climbs straight,hovers. knife edge fly inside and out. can even cope with a breezy day if your good enough. Before you buildone of these it is a must to tape all the front vertical and horizontal surfaces right back to cock pit. Now it will handle crash after crash with ease you break the motor out but just keep hot glueing back in..Sweet
3dkiwi is offline Find More Posts by 3dkiwi
Old Aug 28, 2012, 07:26 AM
scruffy1 is online now
Find More Posts by scruffy1
looking up down under
scruffy1's Avatar
Australia, NSW, Fairlight
Joined Feb 2008
it must have been really dark, because you seem to have missed a bit of covering near the empennage
nice plane, by the way
scruffy1 is online now Find More Posts by scruffy1
Old Aug 28, 2012, 07:31 AM
RCAddict16 is offline
Find More Posts by RCAddict16
United States, VA, Ashburn
Joined Apr 2012
That was on purpose. he was trying to create a WW1 style look. It came out nicely IMO.
RCAddict16 is offline Find More Posts by RCAddict16
Reply With Quote  (Disabled)
Old Aug 28, 2012, 02:00 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
She's a scratchbuild. I think the closest plane on the market is the RadicalRC E-Hornet, which was a significant (and somewhat obvious) influence on the original design.
As for the uncovered tail, I really just like the way it looks. What you almost don't notice are the scalloped trailing edges of the ailerons and elevator which seem simple but are a real bear to cover
I flew her today. Everything went well, but she needs a bit of adjusting to be perfect. Still needs iron crosses for the wings, too.
Old Aug 28, 2012, 02:55 PM
Joined Apr 2012
The scalloping was the first thing I noticed. It looks awesome.
Old Aug 31, 2012, 07:03 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
Here's a pic of the finished product just before the very successful maiden. A buddy of mine says he can make me some crosses for the wings (maybe the tail, too, if I ask nicely ) so I've probably got that covered now.
Old Aug 31, 2012, 07:04 PM
scruffy1's Avatar
Joined Feb 2008
most of it
Old Aug 31, 2012, 08:33 PM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Daytona Beach
Joined Jan 2011
most of it
I see what you did there
Endlesslag is offline Find More Posts by Endlesslag
Old Sep 04, 2012, 12:34 PM
HeeBeeGeeBee is offline
Find More Posts by HeeBeeGeeBee
Lysdexic I'm
HeeBeeGeeBee's Avatar
Spring, TX
Joined Oct 2010
Glad to hear the maiden went well. She's a beauty!
HeeBeeGeeBee is offline Find More Posts by HeeBeeGeeBee
Old Sep 04, 2012, 05:50 PM
ChinoDiablo is online now
Find More Posts by ChinoDiablo
Chef Pilot: Planes vs Butter
ChinoDiablo's Avatar
United States, VA, Hamilton
Joined Jul 2012
Crashed my UMX Carbon Cub SS into the grass on a "You-Shoulda-Known-Better-than-to-fly-on-this-kinda-day" kinda day.
Dummy....
ChinoDiablo is online now Find More Posts by ChinoDiablo
Latest blog entry: Refining the Hanger
Old Sep 06, 2012, 08:10 AM
wingspann is offline
Find More Posts by wingspann
Certified Codger
wingspann's Avatar
NE Texas
After trying unsuccessfully to fly my new Wild Hawk ($50 on sale ) with stock power, I removed the brushed motor/ESC and replaced with a HURC 370 Zoom brushless motor and 30 amp ESC.
I didn't want to use a solid block in the pylon hole for a motor mount as that would block the air flow to the motor. I found a piece of 1 1/8" OD aluminum tube in the garage, which was a perfect match for the diameter of the brushed motor. For mounting the new brushless motor, I cut 4 tabs in one end of the tube and bent them out and drilled them for screws.
The addition of an air scoop to cool the ESC and battery seemed like a good idea, so I cut a hole in the canopy and adapted a plastic spoon to form a scoop. For the outlets I used two pieces of carbon fiber tube into the lower sides of the fuselage to draw air through the scoop and out the bottom.
The 240 watts (measured) will take this thing vertical almost forever!
wingspann is offline Find More Posts by wingspann
Old Sep 06, 2012, 03:26 PM
blackbrabus is online now
Find More Posts by blackbrabus
If it flies.....I can crash it
blackbrabus's Avatar
United Kingdom, England, Preston on Stour
Joined Nov 2011
I added a eflight heli tail gyro to my parkzone extra 300 elevator to see if it impoves it any, not that it was bad to start with but I wanted something to do lol
blackbrabus is online now Find More Posts by blackbrabus
Old Sep 07, 2012, 05:15 PM
WingNut64 is offline
Find More Posts by WingNut64
RC Newb/Gorilla Glue User
United States, OH
Joined Jul 2011
Added rubber-band wing retention to the Dynam Cub...the OEM latch was pulling loose and the wing was loose on the fuselage. Also, added a proper landing gear (made for a larger plane) along with 3" DuBro wheels.
It tracks great, less flex means less ground-looping, and with the wing held tight, flying manners are more consistent.
WingNut64 is offline Find More Posts by WingNut64
Discussion What did you steal from the field today? Jim Varley Arizona Model Aviators 9 Nov 09, 2011 10:14 AM
Discussion What did you fly today? xrx1113 Electric Plane Talk 4 Oct 25, 2011 09:37 PM
Discussion What's the most lights you have put on your HZ Champ and what did you use newflyer100 Micro Ready-to-Fly 0 Jul 12, 2011 10:27 PM
Discussion What did you do to/for your Heli today? roady89 Mini Helis 20 Oct 04, 2010 09:24 PM
Discussion What did you do for your planes today? This week? I'm Rick James Slope 135 Sep 25, 2008 09:21 PM
