Jun 24, 2012, 01:11 PM
United States, OH
Joined Jul 2011
Yesterday; flew through 3 batteries and 4 takeoff/landings, without putting a scratch on it.
Today; addressed some deficiencies in the wing attachment. From previous crashes, the wing anchors were pulling loose from the fuse, and the cheap glue used in it's construction was part of the cause. I pulled them loose, scraped off the residue, and Gorilla-glued them in place, securing with tape. I'll trim excess, then go to "phase II", consisting of;
Removing the factory struts; they are too short and actually bow the wing downward. Also, the tiny screws make it a pain to remove/install the wing for storage/transport/servicing.
Embedding a balsa "spar" in the wing underside, extending 1 ft to each side of the fuse.
Using skewers through the fuse, make a rubber-band wing anchor system, with balsa strips to prevent gouging of the foam wing.
