Old Oct 12, 2003, 09:38 PM
Columbia, South Carolina, United States
Joined Feb 2000
Ideas Needed so I can Double Check Plane before 2nd Attempt "crash"
I have a Kavan High wing Fokker WW1 Plane. One its first maiden,as soon as it broke ground it wanted to roll over to the right something bad. I fought it but when I cut power to abort,she rolled over. The motor mount was prebuilt so Im assuming the thrust angle is correct. I had some right rudder added in as all my planes do. Any IDEAS on what would cause a hard roll and uncontrollabilty? CG within range,throws dialed down and everything appears to be straight.
JIMJAM is offline Find More Posts by JIMJAM
Old Oct 12, 2003, 09:41 PM
Lookin' Good. Real Good.
larsy87's Avatar
London, Canada
Joined Aug 2002
Maybe there is a warp in your wing. With aileron you could correct it but with rudder...no, you can't. I'd check for warps, and if that isn't it, im outta ideas.
larsy87 is offline Find More Posts by larsy87
Old Oct 12, 2003, 09:47 PM
Joined Feb 2000
Staring at the wing and nothing really jumps out as being obviously wrong. There is a small landing gear wing but I cant see with its size and slow speed being able to upset the plane that badly. I considered the elevators being at different pitches but they appear to be equal.
Old Oct 12, 2003, 09:51 PM
larsy87's Avatar
London, Canada
Joined Aug 2002
Is it possible, that one wing tip could be higher than the other? With how it's set up, it looks kind of easy to offset it. That might contribute to your rolling tendancies.
Old Oct 12, 2003, 10:20 PM
Tiger Moth World Tour
Clydewinder's Avatar
New Berlin, WI USA
Joined Jan 2001
Also check your lateral balance. A lot of pilots neglect this and trim it out with aileron only to have a plane that rolls at high speeds.
Clydewinder is offline Find More Posts by Clydewinder
Old Oct 12, 2003, 10:42 PM
Joined Feb 2000
Suspended by a string tapped dead center the rec CG, the plane hangs level. Im going to attempt again with the rudder centered. But what bothers me is that it was less of a yaw problem than a roll. I ruled a stall out cause I let the plane lift off on her own and power is no problem. Then again the entire event probably took less than 2 seconds....
Old Oct 12, 2003, 10:50 PM
LcJ
Forever TMWT Pilot #11
LcJ's Avatar
United States, LA, Monroe
Joined Mar 2003
To my bad eyes, it looks like the leading edge at the last third of the left wing is higher that the right wing. If this is the case, it would tend to push the left wing up, causing the right wing to dip. I may be wrong, but it would be worth checking. Of course if the picture shown is a mirrow image then you can forget that.
Peace, and good luck,
LcJ
LcJ is online now Find More Posts by LcJ
Latest blog entry: Own your own - What it means
Old Oct 12, 2003, 11:06 PM
Joined Feb 2000
PIC ONE
Old Oct 12, 2003, 11:07 PM
Fort Collins, CO.
Joined Sep 2002
from my past experience with this same problem I did have a warped wing... very tough to see as it was not much, but had a drastic effect never the less....
flybye is offline Find More Posts by flybye
Old Oct 12, 2003, 11:08 PM
Joined Feb 2000
Pic 2.
Old Oct 12, 2003, 11:18 PM
Joined Feb 2000
Outboard the wing struts, its easy to twist and pull up and flex the wing.
Old Oct 13, 2003, 06:47 AM
LcJ
LcJ's Avatar
Joined Mar 2003
From the frontal view it looks just the opposite, but only very slightly. You probably do have some warp in the wing, but from these picture, it is hard to tell. Have you made any adjustments yet? I hate to say this, but be sure your contols are set correctly. Right stick, rudder move to the right, left stick, rudder moves to the left. From you earlier post, I would think that is correct, but it doesn't hurt to check. Also verify that the back of the tip of the trailing edges are an equal distance for the back middle of the fuselage.
Good Luck,
LcJ
Old Oct 13, 2003, 07:28 AM
rtideas's Avatar
wyoming, mi usa
Joined Dec 2000
Trying erring on a bit nose heavy. If you hit the stall angle of attack and it's tail heavy, it will want to wallow.
Either way, dang handsome little Fokker!
rtideas is offline Find More Posts by rtideas
Old Oct 13, 2003, 07:40 AM
xmech's Avatar
Hernando,Mississippi, United States
Joined Apr 2003
Assuming everything is correct,wing warp, controls,motor mount etc. The only thing I can think of is that even if the plane lifted off, it still could have snap rolled on you.Have you tried a hand launch to see what it does? If two much up elevator is used on take-off it can get airborne before it has sufficent flying speed to substain flight, followed by a snap roll.Just one more thought.Try a hand launch next time with a gentle climb out and see what it does.
Finally, you may still need a little more nose weight , balance level may still be tail heavy for this plane, some of the manufacturers are a little off on there recommended balance point.If you read any of the GWS P-51 threads, we had a learning curve on that airplane to find the best balance point.It really sounds to me that the airplane lifted off to early and snap rolled in.Classic symtoms.
Good Luck, and let us know what you find.
xmech is offline Find More Posts by xmech
Old Oct 13, 2003, 08:15 AM
Rip-N-Burn's Avatar
Chandler Williams, Arizona, United States
Joined Nov 2002
Boy that is a sweet looking plane. The snaproll theory sounds pretty logical to me. I had a similiar problem on one of my scratcho's and it was a result of a very slight wing warp. The one thing I noticed by your picture is that I couldn,t visualy draw a straight line down the center. It could just be a slight angle in the photo, but I figured I'd roughly grid it out to better explain what I was seeing.
Good luck
Kenny..
Rip-N-Burn is offline Find More Posts by Rip-N-Burn
Discussion So can't fly and no plane to build now what???? boomerace Parkflyers 10 Apr 16, 2007 05:49 PM
Before I make this purchase, can someone check it out? coomarlin Electric Plane Talk 15 Jul 12, 2004 06:41 AM
need ideas on what i can use a weight for my plane jeff262 Foamies (Kits) 9 Jan 15, 2004 11:02 PM
how to tell if a motor can pull a certain plane bmess Electric Plane Talk 2 Oct 17, 2001 11:17 AM
Ideas for making $$ with an E-plane maciek Electric Plane Talk 7 Aug 07, 2001 06:31 PM
