Old Feb 09, 2012, 03:13 AM
neilmny is offline
Find More Posts by neilmny
Bush Mechanic
neilmny's Avatar
Mt. Dandenong, Australia
Joined Oct 2005
Help!
JR X2720 won't switch on any more
My JR X2720 TX won't switch on any more. I removed the battery for charging like I always have and when I replaced it (fully charged), absolutely zip, not a thing not a sound. Does anyone knwo what the trouble is or where I can get it serviced. I really like it and don't want the exoense of switching to a DX system.
thanks for any help.
Neil.
neilmny is offline Find More Posts by neilmny
Old Feb 09, 2012, 11:54 AM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
First thing to check is the 3A fuse, you'll have to take the back of the case off to check it. Very likely it's blown.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Feb 09, 2012, 02:31 PM
neilmny is offline
Bush Mechanic
neilmny's Avatar
Joined Oct 2005
Thanks for that. I'll check it out today.
Old Feb 09, 2012, 03:49 PM
neilmny is offline
Bush Mechanic
neilmny's Avatar
Joined Oct 2005
It's fixed...it was the fuse
Thanks for the help it was a fuse hidden well in the guts of the unit under a circuit board and the antenna.
A blown fuse is often sign of other problems but all seems good. I may have attempted to fit the battery connector the wrong way around. It is polarised but it is conceivable that the contacts could touch but not plug in. This would blow the fuse for sure. So I hope that was it.
I've attached some photos for anyone else who might strike the problem. A guide to where it hides if you like.
Old Feb 09, 2012, 06:18 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
A blown fuse is a fairly common occurrence with JR radios, so don't worry too much (just keep a spare!). In most of them it's not so hard to get at. It doesn't necessarily indicate reverse polarity, though that's one common cause.
I guess I've had 2 blow in 10 years. Neither was a matter of reverse polarity. The fuse is 3A, though it may look like 0.3A.
Daedalus66 is offline Find More Posts by Daedalus66
Old Feb 09, 2012, 06:48 PM
neilmny is offline
Bush Mechanic
neilmny's Avatar
Joined Oct 2005
Thanks for the reply. Yes it does look like 0.3amp on the fuse but I thought otherwise and put a 3 amp in.
Help! JR 8103 won't turn on flyguy93 Radios 4 Aug 11, 2011 09:53 PM
Rant Why won't any seller ship!!??!! FlattyFlier Trader Talk 75 May 23, 2011 07:23 PM
Discussion Blade CX won't take off any more Bmr4life Coaxial Helicopters 6 Aug 20, 2009 05:50 PM
Discussion Avion IO won't take a charge any more crunc Micro Ready-to-Fly 3 Sep 05, 2008 04:43 PM
Help: Futaba Skysport 4, servo reverse switch won't switch back!?!? mike93 Parkflyers 0 Dec 17, 2002 04:40 PM
