Old Feb 08, 2012, 11:19 AM
out of stock is offline
Find More Posts by out of stock
Speed only
out of stock's Avatar
United States, FL, Lehigh Acres
Joined Jan 2012
Question
motor must be installed at a certain degree/angle. true or false?
im pretty sure this may apply to some planes but i installed my motor as straight as the standoffs are. sbach 342.
is this true?
out of stock is offline Find More Posts by out of stock
Old Feb 08, 2012, 11:27 AM
elfwreck is offline
Find More Posts by elfwreck
elfwreck's Avatar
United States, CA, Oakland
Joined Dec 2002
Hey now,
Thrust angles are absolutely vital. If you get them wrong the plane will have all kinds of tracking problems. It could dive under power or with cut power or rise like crazy power on or off. Pull left or right or any combination of these.
Of course correct thrust angle depends on the airframe. High wing, low, or inbetween and various other bits will affect the thrust angle needed for good flight. Yes you can compensate by playing with other trims but those are just poor patches compared to proper thrust angle.
RobII
elfwreck is offline Find More Posts by elfwreck
Old Feb 08, 2012, 11:31 AM
cryhavoc38 is online now
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
is this true?
its a good bet that your plane's firewall already has a built in right thrust angle
cryhavoc38 is online now Find More Posts by cryhavoc38
Mike_Then is offline
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
Originally Posted by elfwreck View Post
Hey now,
RobII
Agreed. Thrust angles are vital to almost every airplane. You can get some crazy, hard-to-correct flight problems with a wrong thrust angle.
Mike_Then is offline Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old Feb 08, 2012, 11:48 AM
Speed only
Joined Jan 2012
makes good sense as someone else has also told me the same thing. thanks
Old Feb 08, 2012, 11:49 AM
Speed only
Joined Jan 2012
Hey now,
RobII
very good info. very! thank you!
Old Feb 08, 2012, 11:53 AM
srt8madness is offline
Find More Posts by srt8madness
whiirrrrrr
srt8madness's Avatar
United States, TX, Houston
Joined Nov 2011
Now on a twin, you need down thrust, but if you run counter roatating props you can install them straight, correct? Or do you still need to angle to the right?
srt8madness is offline Find More Posts by srt8madness
Old Feb 08, 2012, 12:09 PM
Speed only
Joined Jan 2012
good question
Old Feb 08, 2012, 12:18 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Down thrust counters tendency of model to go nose-up under full power. Right thrust counters tendency of model to yaw left during takeoffs. Just noticeble down and right thrust are usually about right for most models. You can make fine adjustments to thrust angles with washers. Note: It is normal and desirable for models and full size planes to fly level at 1/2 throttle, rise at full throttle and descend at 1/4 throttle. Right rudder stick is also needed with right thrust to keep model from yawing left during takeoffs. Elevator trim can be used used for sustained level high speed flight. Sorry if you knew all this!
With twin counter-rotating motors/engines, both propped and pulling equally, they should cancel each other's torque and other effects.
E-Challenged is offline Find More Posts by E-Challenged
Old Feb 08, 2012, 12:28 PM
elfwreck is offline
elfwreck's Avatar
Joined Dec 2002
Hey now,
Single or multi, contra or paralle thrust angle still depends on the airframe.
A fun game and fantastic learning experience is to bring a sack of washers out with your favorite model and play with thrust angles. Just try different ones and see how it affects flight. You may be surprised just how much you can alter flight characteristics with tiny changes in thrust angles and/or prop rotation.
This is just one of the games I like to play at the field.
RobII
Old Feb 08, 2012, 01:41 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
If the motor is mounted directly in line with the cord line, then setting it at "O" "O" angles usually works best.
On a Twin, with counter rotating props, angles would not be needed if the motor shaft lined up with the cord line. If the motor was above the wing cord line or hanging below, it may need just a bit of angle.
Butch777 is offline Find More Posts by Butch777
Old Feb 19, 2012, 04:42 AM
southside is offline
Find More Posts by southside
I fly bipes
southside's Avatar
United States, OK, Elgin
Joined Dec 2011
down thrust and right thrust
2-3 degrees down and 2-3 degrees right thrust makes for a good flyer....they correct pitch and counterforce from the revolving prop
southside is offline Find More Posts by southside
Old Feb 19, 2012, 09:38 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
It depends on the model.... and what is its designed intention.
General sport models benefit from down and usually right thrust ... countering climb tendency of lifting wing, torque / yaw effects acting on tail. But move on to full spec pattern models with fully symet wing forms .. zero incidence tails etc. and you may find as I did when I flew pattern - that zero / near zero down and limited right is called for.
Thrust angles are a consequence of design parameters ... wing incidence, wing profile / form, tail incidence, vertical fin offset angle to longitudinal line etc.
Even building a kit can alter the reqt's ....
But lets be honest in most flying conditions and sport models - you'd be hard to tell difference unless a significant adjustment... unlike an pattern machine.
solentlife is online now Find More Posts by solentlife
Old Feb 19, 2012, 09:50 AM
ChillPhatCat is offline
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Lafayette
Joined Oct 2008
For a twin you usually don't need right thrust, simply because the engines don't usually blow air right across the tail (this is different for a P-38, which requires counter rotating props to counteract the vortex flow across the dual rudders.
Down thrust is needed mostly for high wings and not so much for low and mid wings, due to where the lift vector acts on the plane. For pod mounted motors far above the vertical CG where the lift vector tends to pitch the plane down with power application, you need up thrust. (ie seaplanes)
ChillPhatCat is offline Find More Posts by ChillPhatCat
Old Feb 19, 2012, 09:54 AM
zeezee is offline
Find More Posts by zeezee
Yea, I fly dusty planes..
zeezee's Avatar
United States, LA, Angie
Joined Apr 2009
I just rebuilt a Big Stik a buddy gave me and electrified it with a .46. All he told me was that the back of the prop should be 4" from the firewall. It did CG out perfect with the addition of the ESC!!. I made a sub-mount for strength and didn't know if the plane already had offset in it. I have the point of the spinner about a 1/8" off center line on the plane and maybe 2 degrees down thrust. Looks good, according to other planes I have seen. I have enough thread on my bolts to add washers for shims if needed. I think the 1st picture is correct; how it will fly; the 2nd and 3rd are down too much. We'll see! I am anxious about my maiden tomorrow. I am sorta glad for all the rain as my strip is to wet to get on now. Time to reflect. Wish me luck. Dave
zeezee is offline Find More Posts by zeezee
Discussion Is the RCTiger MT3506 motor too good to be true? rogue277 Multirotor Talk 20 Feb 01, 2012 06:25 AM
Question True or False? Murocflyer AMA (Academy of Model Aeronautics) 24 Jul 29, 2011 10:07 PM
This MUST be too good to be true... Smokescreen38 Micro Helis 18 Dec 05, 2005 07:22 PM
False Peak on NiMh Packs. True or False? Ron D Batteries and Chargers 16 Aug 08, 2004 05:35 PM
