Old Oct 31, 2001, 10:32 PM
crazybear is offline
Find More Posts by crazybear
crazybear's Avatar
Irvine, CA
Joined Oct 2001
Hornet assemble problem... please help!
Hi,
I am assembling my hornet, but I found that the pivot support (E044) is kind of streched, and the rotor head pivot (E045) is not running free. What can I do to make it loose?. I think is not a very good idea to sand it.
Thanks in advance,
CrazyBear
crazybear is offline Find More Posts by crazybear
Old Oct 31, 2001, 11:03 PM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
Take yourself some pennies and an couple of dimes and squeeze them into the eo44 to expand it by just a little. Use the dimes as shims when 1 more penny is just too much. Make sure you have some good spreading, but not excessive to break the eo44(which woudln't be all that bad because you could then justify buying Johnk's EO44a.) Then put the eo44 into a pot of water, put the tail gears, motor and tail pinion gears, and the tail box into the water as well. Slowly bring the water up to a boil and let them boil for about 3-5 min. Then turn the heat off and let the water cool until it is again at room temperature. This will both expand your eo44 to the correct width and make all of the plastic parts stronger as well. Good luck.
Jim McPherson is offline Find More Posts by Jim McPherson
Old Nov 01, 2001, 09:37 PM
crazybear's Avatar
Irvine, CA
Joined Oct 2001
Thanks a lot Jim!. Worked great!!!!. The only problem is that the tail rotor parts are already assembled .
and a question... why the motor?. the usual is to use 2 1.5 batteries until the batteries die... right?
Thanks!
Old Nov 01, 2001, 10:13 PM
Joined Aug 2000
Sorry, you have to take it in context "motor and tail pinion gears" That's the motor pinion, and tail pinion gears.
Zagi Mixer Problem Please Help originaljoe Foamies (Kits) 0 Mar 29, 2002 10:18 AM
xing charger problem - please help! wigham1 Power Systems 5 Jan 02, 2002 12:35 AM
Servo problem, please help... Vincent Power Systems 5 Dec 10, 2001 12:00 PM
ESC Problem, please help?? Vincent Power Systems 4 Dec 06, 2001 06:58 PM
RANGE PROBLEM...please HELP!!! tnsfrk Electric Plane Talk 5 Jul 24, 2001 10:46 PM
