Old Feb 08, 2012, 12:45 AM
Ribble is offline
Find More Posts by Ribble
Crash and learn
United States, PA
Joined Dec 2011
Nine Eagles J6 Transmitter Appendix 1
Is this for real or what? From J6-Manual-2
I need to know how to play with the J6 transmitter and to be sure that I don't reset to factory default. First I want to copy the existing SP100D-280A (Mode 2) to another memory (to save a good copy) so I can play with the trim tabs and not have them go away when I turn the J6 off,
Select for 10 model parameters.
Press button A+ B for one second to enter the menu to select, the character
mode and single character in parameter region blink , press button C to enter,
turn the dial plate to choose the model No, from 0-9, Press button C to confirm,
Press button B to exit, the choosing for Model No is completed!
Model parameter copy setup
Model parameter copy setup, press button A+B for one second to set the
parameter, turn the dial plate until the character MODE and CP blink
simultaneously, Press button C to enter, the first character displays the Model No
which has been copied, turn the dial plate to select the model No. Press button
C to confirm, the second character displays the model NO which needs to be
copied, turn the dial plate to choose the model No, press button C to confirm and
save,press button B to exit, the model parameter copy setup is completed!
Model Type Setup
Next is the basic parameter set and model type set for Nine Eagles’ J6
transmitter. Press button A+B for one second, the character MODE and the
model icon blink simultaneously, press button C to confirm and enter, character
MODE lights constantly, Model icon blinks, turn the dial plate to choose the
model needed, press button C to confirm, press button B to return, the model
type setup is completed.
3D switch protection
CCPM mix control capacity set
Curve setup of control stick
Servo parameter setup.
Airplane mix control setup
Model No set
Model Type Setup
Undercarriage operating speed setup
Lock tail sensitivity set
Swashplate type setup
Setup for the throttle and five points curve setup of pitch channel
Protection method for the throttle switch
Throttle hold setup
The midpoint trim for transmitter
Reverse setting of the channel
J6 manual-3 on NE site (doesn't have 6 page "Nine Eagles J6 Transmitter Appendix 1" at end
http://www.nineeagle.com/products_de...9b82955cd.html
My J6 is like this one, doesn't say"Futaba Code Inside" and maybe different screws holding the stick modules in.
Same size switches in same locations, with same labels.
http://helidaily.com/wp-content/gall...r-d1-_0331.jpg
Ribble is offline Find More Posts by Ribble
Old Feb 08, 2012, 01:19 PM
EKron is offline
Find More Posts by EKron
EKron's Avatar
United States, AZ, Gilbert
Joined Jul 2011
Where did you find this appendix? It is good info but I just took a look at the J6 that came with the SP180 I got from HK last week and as far as I can tell, there is only one model memory. Can choose heli or aircraft and no options to pick a different model memory or save, copy, etc. Curious that manual-2 has this appendix but the manual-3 you linked to and the one that came in my box doesn't.
I'm thinking this might apply only to the ones that say "Futaba code inside"? It would be nice to be able to use this TX with another NE heli or plane if I ever wanted to but don't think the unit I have is capable of doing so?
What would be really nice is if someone would make one of these micros that would bind with the nice Futaba TX I already have for my 450.
--Elisabeth
EKron is offline Find More Posts by EKron
Old Feb 08, 2012, 03:54 PM
Ribble is offline
Crash and learn
United States, PA
Joined Dec 2011
Downloaded several versions of the J6 manual in PDF format. The one with the "Nine Eagles J6 Transmitter Appendix 1" was very clean and easiest to read.
1/20/2012 is the date that I saved J6 Manual-2 with the appendix.
1/26/2012 is the date that I saved J6 Manual-3 from Nine Eagles site.
I don't know where I downloaded the J6 Manual-2 with the appendix and thought it might be something that doesn't exist yet. The clarity of the PDF is outstanding, perhaps because it is greyscale with red highlighting.
Tried "Model parameter copy setup" and get an "A" for "model number which has been copied" and a "5" for "model NO which needs to be
copied" whatever that means. The J6 came with the SP100D-280A.
EDIT: First set Communication Protocol R-0 for old 4 Channel and less or R-1 for new protocol
EDIT: CP = Model Copy function.
EDIT: The "A" is likely an "R" for receiving a new model from another transmitter.
EDIT: The "5" is likely an "S" for sending model data to another transmitter.
EDIT: Pressing C button shows "--------" meaning it is (R)eceiving or (S)ending data.
I got brave and went in to the J6 and changed some parameters and worked my way through the menu's without causing a factory default reset. This is all new to me and was hoping someone knew if this thing has 10 model memories or not.
Old Feb 08, 2012, 06:02 PM
EKron is offline
EKron's Avatar
Joined Jul 2011
Well, I messed with this some more and it's not working for me. I can get to the screen with the blinking CP and going into it displays an "A" but that's it. Turning the dial doesn't change anything and if I do press C, it shows - - - - and again, it can't be changed.
At least I didn't wipe everything out.
Any info in that manual-2 that shows how to get to the idle up throttle curve menu?
Old Feb 08, 2012, 09:06 PM
Ribble is offline
Crash and learn
United States, PA
Joined Dec 2011
Found it. Now I don't have to post it
The site - under SP100D-280A
http://www.helipal.com/nine-eagles-s...z-edition.html
17MB PDF
J6 manual with Nine Eagles J6 Transmitter Appendix 1
http://image.helipal.com/helipal-nine-ealges-j6-2.pdf
Helipad also shows a version of the SP100D-280A with supports on the tail boom. First time I've seen that - may be old, may be new.
Interesting:
Nine Eagles Large 2.4ghz Transmitter
Item Id: NE-24TX
This transmitter will bind with all Nine Eagles 2.4Ghz helicopters. Every transmitter has been tested and bound to a Nine Eagles 2.4ghz helicopter prior to shipping. Rick does it again?
http://www.clubheli.com/Nine-Eagles-...er_p_2524.html
Old Feb 09, 2012, 05:27 AM
Donaldsneffe is offline
Find More Posts by Donaldsneffe
Vienna calling...
Donaldsneffe's Avatar
Österreich, Wien
Joined Aug 2010
Hi,
thanks for the manual.
Whats this:
Walter
Donaldsneffe is offline Find More Posts by Donaldsneffe
Old Feb 09, 2012, 08:53 AM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
17MB PDF
Interesting:
Item Id: NE-24TX
As far as I know the NE-24TX only binds with all NE 2.4 GHz helis that were being produced at the time this TX was released. Not with the newer versions, like the 100D. Rick seems to have forgotten to update the info, or deemed that unnecessary as this TX is out of stock anyway...
SoloProFan is online now Find More Posts by SoloProFan
Old Mar 10, 2012, 11:23 AM
BogGSM is offline
Find More Posts by BogGSM
Romania, Buzau, Buzau
Joined Dec 2010
Hi,
Just discovered that j6 pro has adjustable tension on pot`s springs.
PS.Does all the j6 pro have LCD backlight?I bought mine second hand and thought that is defective so I open it and saw that never had from the factory, maybe is an early version?
BogGSM is offline Find More Posts by BogGSM
Old Mar 13, 2012, 09:41 PM
Swilson50 is offline
Find More Posts by Swilson50
Dodge City, Kansas
Joined Oct 2003
Need help with the mixes
I bought the J6 to tame down my micro fixed wing Nineagles warbirds. It did a great job with dual rates and expo, but I haven't been able to figure out their "English" instructions for mixes.
Can someone help?
Swilson50
Stan in Dodge City
Swilson50 is offline Find More Posts by Swilson50
New Product Nine Eagles Solo Pro 328 (Nine Eagles' answer to the Blade 120 SR?) SoloProFan Micro Helis 1758 Feb 27, 2015 04:24 PM
Discussion nine eagles sky eagle not responding to transmitter jamiek123 Micro Ready-to-Fly 4 Mar 28, 2012 04:40 AM
For Sale Cox / Nine Eagles Transmitter, 2 x RX, 1 x Aileron Servo NEW Unused ShokWaveRider Aircraft - General - Radio Equipment (FS/W) 0 Sep 08, 2011 09:34 AM
Discussion Nine Eagles Solo Pro modified transmitter Nisei Micro Helis 5 Jul 24, 2011 03:38 PM
Question Nine Eagles 2.4GHz heli transmitter eyemdee Micro Helis 2 Jun 06, 2011 03:49 PM
