Old Feb 08, 2012, 12:14 AM
Forrest is offline
Find More Posts by Forrest
United States, CA, Big Bear City
Joined Jan 2003
Help!
Centering trim buttons on the Blade MLP4DSM. TX
How can you tell when these babies are centered?
Thanks.
Forrest
Forrest is offline Find More Posts by Forrest
Old Feb 08, 2012, 12:32 AM
SoloProFan is offline
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Thanks.
Forrest
That's one that beeps, right? Long beep means center.
SoloProFan is offline Find More Posts by SoloProFan
Old Feb 08, 2012, 12:54 AM
arbilab is offline
Find More Posts by arbilab
Fly Runaway Fans
United States, TX, Fort Worth
Joined Jan 2009
Like all the beeping Spektrums, it's only SLIGHTLY longer.
arbilab is offline Find More Posts by arbilab
Old Feb 08, 2012, 12:57 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
So you need very good hearing then. They should put that in the manual: "before operation, go get your hearing checked, or buy a better TX first..."
Old Feb 08, 2012, 01:07 PM
Forrest is offline
Joined Jan 2003
Thanks to you all for your comments.
Beeps at center...is there a way to know when it's maxed out?
Old Feb 08, 2012, 02:38 PM
arbilab is offline
Fly Runaway Fans
Joined Jan 2009
Maybe it stops beeping when it hits end of range.
Putting the up/down switch buttons is simpler/cheaper than the mechanism that actually moves the pot. Less a drawback on their programmables where the display shows where the trim is.
Old Feb 08, 2012, 04:23 PM
coaxintheface is offline
Find More Posts by coaxintheface
United Kingdom, Scotland, Edinburgh
Joined Jan 2012
It beeps slightly longer or shorter depending on which way you are going, when you reach the limit either way it triple-beeps, and when at neutral it makes a noticeably longer beep (very easy to tell ).
coaxintheface is offline Find More Posts by coaxintheface
Old Feb 09, 2012, 03:17 PM
MotownJG is offline
Find More Posts by MotownJG
United States, CA, Modesto
Joined Dec 2011
I had to push the button all the way one way, hear the beeps, go back & hear how it changes when it reaches center. Longer beep? Two beeps? Whatever it did, I had to listen to it to figure it out.
MotownJG is offline Find More Posts by MotownJG
Old Oct 02, 2014, 03:11 PM
bumpyy is offline
Find More Posts by bumpyy
bumpyy
Joined Sep 2014
finding neutral on controls
beeping things using blade mlp4dsm pain in but! lol!
bumpyy is offline Find More Posts by bumpyy
Discussion Flying with trim buttons Aerogance Dynamic Soaring 7 Dec 31, 2011 12:48 PM
Discussion GW 9958 / 9998 / Radio Trim Centering *or reset*? FreakFlow Micro Helis 0 Sep 14, 2011 07:55 PM
Question flash 5 trim buttons sunscraper Beginner Training Area (Aircraft-Electric) 9 Jul 09, 2006 04:29 PM
Sticky trim buttons eclipse 7 HELP Chuckhead1 Radios 1 Jun 23, 2005 11:18 PM
Re-Assigning Evo 9 Trim Buttons? aplphabandaid Radios 4 Feb 13, 2005 01:28 AM
