Old Feb 07, 2012, 09:28 PM
iflyrc1012 is offline
Find More Posts by iflyrc1012
no more glow models for me!!!!
iflyrc1012's Avatar
bklyn n.y.
Help!
the best bang for my 90mm bucks
guys, i need a 90mm fan, motor, e.s.c. combo for 6 cell.
i'm building an f-86 that needs some pop!!!! please help!!!!
iflyrc1012 is offline Find More Posts by iflyrc1012
Old Feb 07, 2012, 10:04 PM
torque roll is offline
Find More Posts by torque roll
A Texan abroad
torque roll's Avatar
Joined Oct 2011
Definately, the 12 blade 90mm Changesun fan from HK or x-flight :
http://www.hobbyking.com/hobbyking/s..._Fan_Unit.html
Now it's everybody else turn.
torque roll is offline Find More Posts by torque roll
Old Feb 07, 2012, 10:52 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Here's CS fan HK 1600kv outrunner on 6s or hit up edfhobbies.com and get the 1700kv motor
http://www.youtube.com/watch?feature...&v=trgxnFnBTPQ
erh7771 is online now Find More Posts by erh7771
Old Feb 07, 2012, 11:16 PM
rush1 is offline
Find More Posts by rush1
rush1's Avatar
United States, CA, Palmdale
Joined Mar 2011
I agree the change sun edf and motor combo runnin on 6s from xflight is the best bang for the buck
rush1 is offline Find More Posts by rush1
Old Feb 07, 2012, 11:20 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
I should also point out that while I agree with the above statements about the CS fan, I think it's also prudent to point out that for ultra reliability, plug and play ease, etc, you can't beat a Wemo combo. I love the look and sound of the 12 bladers though.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Feb 08, 2012, 05:59 AM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
+1 LuvE
I am gonna disagree. IF you need more performance then units like the HET or Wemo 90mm are the ones you want. The CS sounds better but I would venture to say it will not perform as well.
Kevin Cox is offline Find More Posts by Kevin Cox
Old Feb 08, 2012, 06:20 AM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
http://www.hobbyking.com/hobbyking/s...dproduct=14788
http://www.hobbyking.com/hobbyking/s...dproduct=16367
I have used this combo in a few models with great results.
It should be less than $90 with shipping but that will leave some $ for connectors
http://www.hobbyking.com/hobbyking/s...idProduct=2087
4stripes is offline Find More Posts by 4stripes
Old Feb 08, 2012, 08:05 AM
Joined Nov 2005
Originally Posted by Kevin Cox View Post
+1 LuvE
I don't see thrust\watts numbers any different than wemo or HET with the CS fans and correct KV motor.
There are videos on YT proving thrust\watt numbers that are VERY similar to Wemo and HET
Old Feb 08, 2012, 09:20 AM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
I've used a number of wemo midi style fans over the last 2 years with good success and tested a number of motors in the new CS 12 blade 90mm fan. Have also tested the factory "1600kv" setup. I have test flown the CS 12 blade on a 1400kv motor and the amp draw is higher for the thrust produced by around 10% (compared to the wemo fans). It does equate to shorter flight times.
Although the CS is less efficient, I do think the sound is worth switching for in some applications. If you need all out performance the wemo fan is still king but if you are willing to sacrifice some air time the CS will put a smile on your face (due to its pleasant sound).
Cheers Eric
Old Feb 08, 2012, 10:13 AM
Double E is offline
Find More Posts by Double E
Double E's Avatar
Atlanta, GA
Joined Mar 2009
I can vouch for the Wemo midi fan and Arc motor combo. I run 8s but I believe they have a 6s motor as well. The Midi in my JTM L-39 actually sounds pretty good. Not too whiny at all.
Double E is offline Find More Posts by Double E
Old Feb 08, 2012, 03:48 PM
snyder_man is offline
Find More Posts by snyder_man
United States, OH, Springfield
Joined Jul 2004
90mm, 6s, package
Where does one get a plug and play 6s Wemo combo?
I don't know how to balance a fan yet
snyder_man
snyder_man is offline Find More Posts by snyder_man
Old Feb 08, 2012, 03:57 PM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
snyder_man
The Freewing fan/motor I posted above is balanced pretty well right out of the box. The only thing I recommend is use locktite on the set screws and spinner screw. Do not over tighten the spinner screw or the plastic spinner will crack. On 6S it gives decent performance for most 90mm foamies. If you go to a heavier composite jet you will need 8S or higher along with a high voltage ESC.
Balancing a fan isn't really that hard but The freewing 90mm fan is a clone of the wemo midi fan.
Cheers
Old Feb 08, 2012, 06:13 PM
SCALEFAN is offline
Find More Posts by SCALEFAN
Done it all
United States, CA, Corona
Joined Feb 2006
The Wemos are balanced, just bolt in the ARC motor. Nothing can beat it. All I use is the ARC 36 motor, for 6s. If I remember correctly over 7lbs thrust. I have to admit, most uses are for large size, 7 lb plus, foamies.
SCALEFAN is offline Find More Posts by SCALEFAN
Old Feb 08, 2012, 06:25 PM
iflyrc1012's Avatar
bklyn n.y.
Scale fan,
got a link?? or two? i'm leaning towards the cs unit, but no money has been spent yet....
this is for a Koyosho f-86 that was originally a glow powered .25. I saw one fly when it first came out, and it was an underpowered dog, but with a e.d.f. this plane has alot of potential. also retracts are a possibility now..
4 stripes,
i put all those links on my list. they are not in stock now, but i'm not in a rush to get this one in the air.
i want this one to perform scale-like, not just be a beast.....i'm thinking this plane gonna weigh about
4 lbs, maybe a tad more. the cs fan set-up on 6 cell should do the trick right?
Old Feb 08, 2012, 06:33 PM
iflyrc1012's Avatar
bklyn n.y.
thanks for all the help guys!! all of your input has been enlightening...
Discussion What's the best bang for the buck in Gas Engines? daddyrabbit1954 Engines 15 Nov 09, 2011 03:31 AM
Discussion Best "bang for the buck" speed plane? Sailor Jerry Electric Plane Talk 7 Sep 12, 2011 08:03 PM
Discussion Whats the best bang for the buck RTF? inline300 Foamy EDFs 5 Mar 19, 2011 02:39 PM
Discussion Battery charger-best bang for only a few bucks? destinbeachman Mini Helis 0 Dec 27, 2010 11:00 AM
Discussion X-Twin the best bang for bucks OETOMO Micro Ready-to-Fly 3 Nov 15, 2006 02:28 AM
