| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#46 |
That sickening crunch..
I realized I mis-calculated the weight of the FAUP's.. they're actually 1.37oz.. Still, a big improvement over full-size sub-C's..
..a |
#47 | |
Don't Fear the Reaper
#48 |
I'm ordering one now! Thanks.
Scott |
#49 |
Low wing models, such as the Dynamic, are a bit different to balance as the center of gravity is located significantly above the bottom of the wing. A good trick to get around this is to mark the balance point on the top of the wing and balance the plane upside down.
I've gotten a few more flights on my Dynamic and I'm really starting to love it. While it's pretty speedy, I'm amazed at how much it can be slowed down while maintaining good control. I just wish it had better duration. It goes through the 9 cell pack of FAUP's pretty quickly. I guess it's time to get on the LiPoly bandwagon :-) |
#50 | ||
)..a |
#51 | ||
)..a |
#52 |
#53 |
Watts is life...
Hi Folks,
Could I get a recomendation on control throws? It appears the instruction papers I have did not include any suggestions. Thanks, Bob |
#54 |
"lots"..
She doesn't mind plenty of throw - snaps nicely.. ..a |
#55 |
hello everybody. I have been reading the post and found that I don"t seem to be the only one with balance problems on the dynamic. I put a16 25 4 mega motor in it and I can get it to balance at recomended spot but I have to push the sanyo 8 cell pack almost to the motor.what will I do with my 3s2p lipoly?Should I try adding weight? Seems like it will be tough to remove the pack from velcro with the batt stuffed way in the front. any advice on this would really help thanks.
#56 |
Watts is life...
Hi Chris,
I'm using an Aveox 36/24/2 with two types of packs: 8 GP3300's 7 RC2400's Balancing has the packs well inside the canopy section, though its still a bit forward with 1 or 2 cells partially inside the foward fuselage. No flight yet but soon ![]() What type of sanyo cells are you using? |
#57 |
Chris, I just sent this to the email you sent..
CG is good per provided instructions. It also happens to be right at the wing mounting bolt location. If it balances on the bolt heads, you're good. ..a |
#58 |
wow that was a fast replie hope my plane will be. I am using sanyo 1700 8 cell nimhs @11oz. as a base pack. I also have 8cell 1700 nicad @ 15 oz. and a 3s2p lipoly @ 9 oz. that I would like to use. I guess I could make up some kind of a tray to insert and remove packs. I wounder how much play you have with the cg on this model? I have other planes that were a half inch or so off the cg marked on the plans and flew the same as always. I have beefed up the landing gear as to Andys advice and that was a little weight forward of the cg but my pack gos in beyond the front hatch opening compleatly to balance.
#59 |
ooo
#60 |
Watts is life...
Chris,
A suggestion, if you need to add weight, how about using your 4 cell RX pack as the ballast? You could velcro mount them way inside the fuselage. I checked you power setup on Motocalc, looks like 10 1950's would be sweet ![]() Bob. |
