33% A-10 this is very small, will prob make a better glider than rc plane but the wingspan is about 12" what you asked for
http://www.mediafire.com/?2cwgow343uq47hr |
maiden A-10 vid
im in north wales, i took the 33% plans down as i made a glider version have a go at downloading that one ill put link below, its a nice size for what you want and everything will fit together better as its made for 6mm depron.
http://www.mediafire.com/?qd6lk98wlqd4g5d where i get my depron from http://www.ebay.co.uk/itm/Depron-6mm...ht_1724wt_1037 |
My first ever foamy build
Ok so I went on to try and make a Glider from this first, I started by cutting out the taped together sheets......
a quick trip into the attic for left over floring underlay I managed to make the wings just one piece. It's late so this is as far as I go tonight. oh heres a little video...
Thanks and Yep, it's this stuff http://www.floors2go.co.uk/accessori...-foam-underlay had almost a whole pack left over from doing the floor, it looks like one pack of 19 could yield about 38 gliders.
It feels like it has more flex in one direction than the other, much like thin balsa sheet my edge are a little rough after using scalpel set, I'll cut a nicer one using the variable hot-wire cutter I made from a dimmer switch and a lighting transformer, once I dig it out from the attic that is. |
Outdoor Glider maiden flight
| Thread Tools | |
| Build Log The Puddle Shark! ADDED NEW HD DURATION FLIGHT!FREE PDF PLANS by BILLWHIT | Kronikpilot | Foamies (Scratchbuilt) | 111 | Mar 26, 2013 08:26 PM |
| Download free f16 profile parkjet pdf | boxermad84 | Foamies (Scratchbuilt) | 75 | Nov 19, 2012 05:15 PM |
| Off Site free euro fighter profile parkjet pdf | boxermad84 | Aircraft - Electric - Airplanes (FS/W) | 10 | Jan 18, 2012 11:34 AM |
| Yippee! Mini Typhoon..FREE PDF PLANS HD maiden Flight vid. | Kronikpilot | Foamies (Scratchbuilt) | 58 | May 11, 2011 04:56 PM |
| Build Log Profile F4U Corsair Foamie Build - Free PDF Plans! | Eagle-RC.com | Foamies (Scratchbuilt) | 14 | Aug 01, 2010 10:30 AM |
