Old Mar 08, 2012, 05:24 PM
DaOldGuy is offline
Find More Posts by DaOldGuy
Flying Half Pound and Down
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
Originally Posted by SteveTtoooo View Post
Man, you can tell those directions were written in China...
SteveT
hense the more questions. He was honest with me in the email and said the Manual was a tad... thin if you will. I sent some additional questions <sterring engine was one> back but I have not gotten a response yet. He indicated there are other models as well of this, but it may be a bit before they add them.
DaOldGuy is offline Find More Posts by DaOldGuy
Old Mar 08, 2012, 05:31 PM
jsmith285 is offline
Find More Posts by jsmith285
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
Originally Posted by heritageflyer View Post
Thanks everyone. This is all clear now. Makes sense. 3S with a BEC Pro it is! (if I ever need a setup like this)......
This discussion was way better than off topic Cats!
But we might be doing something different by then.
jsmith285 is offline Find More Posts by jsmith285
Old Mar 08, 2012, 05:32 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
I tried to call them, but could not find a telephone number. They used to have one on the site, as I know that I talked to him at one time to buy some P.A. wing bags (the only good product P.A. has as far as I am concerned) as they are a P.A. dealer, and that way I didn't have to deal with P.A. directly...
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Mar 08, 2012, 06:12 PM
rdsok is offline
Find More Posts by rdsok
rdsok's Avatar
United States, OK, Norman
Joined Mar 2010
I think the French Connection Cap planes had Canape's.
Good one
... and at least you remembered to put the punch line in... I had planned to say something about enjoying a snack or hor d'oeuvre while at the flying field, just not while flying... and got distracted with work and forgot that part... talk about messing up a joke...
Even worse now... I had to explain it..
Randy
rdsok is offline Find More Posts by rdsok
Old Mar 08, 2012, 06:25 PM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Could explain why people keep getting more powerful servo? They assume blow back is not enough servo torque, could be a amp bottle neck?
I am trying to get better info on the Power Expander on the Servo Page
http://milehighrc.com/servo.html
Anyone use one of these before?
There is several posts on that over on Flying Giants. I was interested in one strictly from a power management standpoint. Not much good was said but all based on opinions and the fact that it is pretty much a copy of the smart fly.
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Mar 08, 2012, 06:29 PM
On loan to Texas
Joined Oct 2005
SDHobby is where that Power Box is coming from see here
SteveT.'s Avatar
San Jose, CA
Got a link to that thread?? Heck, it looks decent...wonder what they thought was so bad, other than it is pretty much a copy?
Never mind, I see the link on the box...
And it seems they have another one too...Power box and it has "receiver binding with magic ribbon".... LOL
SteveT
Old Mar 08, 2012, 06:33 PM
On loan to Texas
Joined Oct 2005
SteveT
http://www.flyinggiants.com/forums/s...ad.php?t=69169
http://www.flyinggiants.com/forums/s...power+expander
Old Mar 08, 2012, 06:38 PM
teookie is offline
Find More Posts by teookie
Perfect 3pt inverted landing!
teookie's Avatar
USA, AL, Huntsville
Joined Oct 2008
I've enjoyed this electrical setup discussion.
Something I've been thinking about lately is voltage drop through servo extensions. Let me illustrate w/ an example:
Consider a high torque digital servo hooked up with a 48" extension. This servo can pull 4 amps if it's locked up (worst case scenario). The extension is made with 20 AWG wire. According to Hansen Hobbies Connectors PDF, your typical "20 AWG" servo extension has a resistance of ~.017 ohms/ft.
Calculating the voltage drop in the extension is pretty easy.
V=I*R
V=4amps*(4ft*2*.017) (the "2" is there because the current must flow 48" to the servo, and then 48" back to ground (back to the battery).)
V=.544
Tadaa!
So your servo is seeing half a volt less then your batteries (or regulator) is actually pumping out just due to the wiring. It only gets worse if you add more extensions, use cheap extensions, or Y mutliple servos off of one extension.
If you think .5V is no biggie, consider this: my super vyper was having blow back issues on the ailerons. I had the HS-65's running off the 5.8 or 5.9V from the ESC BEC. Several people recomended I add in a external BEC and set it to at least 6.5. I did and the aileron blow back improved noticably.
Remember though that the voltage only drops this much when the servo is fully loaded and pulling 4 amps. But on the other hand isn't this when you want it getting the most power?
What if you had all your servos plugged into your reciever, and were powering the reciever via two 12" extensions. Lets say 5 servos for a total load of 20 amps (worst case scenario). We split this load between the two 12" extensions for 10 amps each. Doing the same calc as above;
V=I*R
V=10*(1ft*2*.017)
V=.34
So in this case the receiver is seeing .34 volts less then the batteries are putting out. The servos are seeing .34V + the loss from their individual extensions less then the batteries are putting out.
I guess the point of all this is that it's important to consider the voltage losses in your setup, in addition to potential amp bottlenecks.
teookie is offline Find More Posts by teookie
Old Mar 08, 2012, 06:42 PM
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
Data from Scott Servo connector Test
Well, here is the first run of tests on servo connectors. The control test sets the stage on what is expected as normal as we all know it. 3amp current and the connector is just fine, no detectable heat gain felt or measured by laser temp dodad. To start off with there is 15.2mv dropped across a new pair of pins showing there is some voltage loss and some resistance to current under normal conditions. In a perfect or near perfect world we want none of each or at least the same across a piece of wire but since it is a friction fit there is going to be some losses. It's these losses at higher current flow that get us into trouble with brown outs and melted connectors and such.
Test two is much of the same just at a 4amp flow. The voltage drop is a bit higher 20.1mv and after about 3 minutes a little heat can be detected by feel but my laser dodad has a hard time reading the contacts and show little to no rise in temps however, we know there is because of the higher voltage drop.
Test three is at a 6 amp flow, the voltage drop 30.7mv is really coming up now and the pins are quite warm, not so hot you can't touch them but uncomfortable. By this stage it is apparent that the pins are well over their max rating and too much power is being lost across the resistive contact surface, I'm sure the temper in the pins will be lost by this point making the pins loose there gripping strength over time making them even more resistive.
Okay, I'm having fun now just seeing what will happen. At an 8amp flow there is a 42.3mv drop across the pins and are hot enough that I can not hold on to them. At 10 amps my Fluke tops out and the pins are just at the spit sizzle stage so I reset the test with the plastic shell in place and take the Fluke out of the circuit and pour the coals to it. The meter on the adjustable power supply is not accurate enough to use but I know that by adding the last 1157 bulb to the test I was well over the 12 amp range and with in one minute the plastic shell and wire coating began to smoke showing thermal runaway. In the last pic you can see a wiff of smoke off the connector.
Anything over about 5 amps going thru 1 servo connector will become a failure point sooner or later.
We run at least 4 servo connectors on a 50CC plane for power distribution. Might have a lot to do with how Joe flies (Rifle rollers all the way across the field). But minimun of 4 servo connectors for us to power our servos.
Old Mar 08, 2012, 07:11 PM
tominator06 is offline
Find More Posts by tominator06
Team Hillbilly
tominator06's Avatar
United States, MD, Dundalk
Joined Feb 2009
I'm running a 3s 1800 rx pack into a bec pro in my 71. Only has 4 985mg's running on it. I had the bec already when I decided to run the extra battery so I just used it. Seems to work fine.
tominator06 is offline Find More Posts by tominator06
Old Mar 08, 2012, 07:21 PM
DaOldGuy is offline
DaOldGuy's Avatar
Joined Dec 2007
What.... Someone in China making copies... Wait, that is a different thread.
So are the losses completely in the connectors, or is it the line loss of the 48 inches, which is worst?
I get the feeling you enjoy things <controlled enviroment> burning and blowing up... Nicely done!
Old Mar 08, 2012, 07:25 PM
marksextra is offline
Find More Posts by marksextra
Once u go yak u never go back
marksextra's Avatar
Erie, PA
Joined Mar 2005
Really great information right there. Thank you!
marksextra is offline Find More Posts by marksextra
Old Mar 08, 2012, 07:32 PM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
What voltage are you running them at?
cmala is offline Find More Posts by cmala
Old Mar 08, 2012, 08:08 PM
teookie is offline
teookie's Avatar
USA, AL, Huntsville
Joined Oct 2008
I only considered the losses from the wire. Jim's post listed the losses from the connectors at variouse current levels. Just add 'em together for a total.
Discussion Unofficial NQD Tear Into Jet Boat Mod Thread Energy Racing Boats - Electric 14762 Today 06:54 PM
Discussion Banana Hobby Customer Support Request/Q and A Thread! banana hobby Banana Hobby 1156 May 03, 2016 08:01 PM
Discussion The Official AirWare Q&A Thread AndyKunz Radios 95 Feb 14, 2013 08:36 AM
Discussion THE FIRST UNOFFICIAL Parkzone Sukhoi mods thread!!!! bluemeane Micro Ready-to-Fly 27 Aug 17, 2009 11:23 PM
Megatech H2O unofficial thread and first rewiew. grk65 Racing Boats - Electric 7 Mar 05, 2007 12:09 AM
