Old Nov 28, 2012, 09:11 AM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Originally Posted by Inverted-I-Fly View Post
I run fixed endpoints on all my castle esc, and low timing for my motrolfly motors and a separate Bec for the servos, so it is not the set-up. The esc didn't just shut off, it smoked, it's done
I'm sure Castle will replace it.
Send it in. Call them just to make sure they can't think of anything that will cause the next one to smoke but I'm sure they will replace the ESC.
Was the ESC new or had you used it before?
EDIT: Nevermind. I see you are past this already
cmala is offline Find More Posts by cmala
Old Nov 28, 2012, 10:11 AM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
I hope so, we will see and I'll report back what they do.
3drcparts is offline Find More Posts by 3drcparts
Old Nov 28, 2012, 10:59 AM
Ace4 is offline
Find More Posts by Ace4
Stick banger
Ace4's Avatar
USA, AZ, Chandler
Originally Posted by goflyhighrc View Post
Going to be replacing the Robart Hinges in my 89 Slick, would it be best to plug the old holes then re drill or is it OK to use the existing holes.
I had to re-hinge the rudder on my 87 SHP awhile back, I cut the hinges and melted the plastic out with a soldering iron (with a tip that you don't care about, obviously). I just re-used the existing holes to mount new hinge pins. You'll have to use some judgement as to whether the pins are too loose in the holes, but mine seemed ok so I went with it.
Ace4 is offline Find More Posts by Ace4
Old Nov 28, 2012, 11:11 AM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
I drilled out the hinges in the 71 & 89 ans used the same holes. I use gg to set my hinges. It expands well and makes them tight. I have a good 500+ flights since the redoing of the hinges and they are still tight
losifanatic is offline Find More Posts by losifanatic
Old Nov 28, 2012, 11:54 AM
goflyhighrc is offline
Find More Posts by goflyhighrc
Just go with the flow
goflyhighrc's Avatar
Joined Nov 2006
On my 71 I cut the hinges and poked a few of them back into the control surface.Big mistake, now I have them rattling around in there. I melted the remaining hinges with and old soldering iron, it worked well.
goflyhighrc is offline Find More Posts by goflyhighrc
Old Nov 28, 2012, 02:38 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Personally, I would use the exiting holes. As has been said, you can use a very fine point soldering iron to melt the old hinges out....
And yes, pieces of hinge rattling around inside will drive you nuts even if you only hear them when you move the plane...
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Nov 28, 2012, 06:16 PM
jamesrini is offline
Find More Posts by jamesrini
USA, NJ, West Paterson
Joined Feb 2008
Does anybody have any extra stock servo arms for a 65mg That you don't need. I need three single sided and one double sided arm. I had a whole box of them and after cleaning up the shop can't find them anymore.
Pm me if you have them
Edit
Thanks guys I have them now
jamesrini is offline Find More Posts by jamesrini
Old Nov 28, 2012, 08:42 PM
Shirty is offline
Find More Posts by Shirty
Aussies fly Down Under!
Shirty's Avatar
Australia, WA, Perth
Joined Oct 2012
Hey. Does anyone know if ADC hobby are still in business?
I have sent over 9 emails to rob@adchobbystore.com (and also cc'd info@adchobbystore.com on each one), since 14th November- without a single response to date. And I am only trying to buy another 3dhs plane off him...
Does anyone know whats going on with ADC? Thanks!
Shirty is offline Find More Posts by Shirty
Old Nov 28, 2012, 09:21 PM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
That's strange because i've always had really good luck getting a hold of Rob at ADC.
You could always go directly to 3DHS now though, they have international shipping.
hone1er is offline Find More Posts by hone1er
Old Nov 28, 2012, 09:30 PM
Shirty is offline
Shirty's Avatar
Joined Oct 2012
Thanks mate, strange I know. I know I can get the planes direct through 3DHS now, (thanks), but I was trying to remain loyal to Rob at ADC cause he did such a good job on my 59 slick purchase... Guess ADC are earning too much and cant be bothered selling overseas anymore...
Old Nov 29, 2012, 07:02 AM
Elec 1800 is offline
Find More Posts by Elec 1800
Flying 2 Fight Cancer
Elec 1800's Avatar
corona, ca
Joined Feb 2011
well as much as i dont want to, the Disco Ball will be for sale =( will post more pics and info with price later
Elec 1800 is offline Find More Posts by Elec 1800
Old Nov 30, 2012, 01:04 PM
rthorne is offline
Find More Posts by rthorne
Quit Chucking My Wood
rthorne's Avatar
USA, TX, Amarillo
Joined Dec 2003
Originally Posted by RotorJockey View Post
Anyone here coming to the Mid-America FLI?
Its a little far out for planning these days Fred, but if I can talk rmr24 into it and its not too busy at work I'd like to come again.
You and the club put on a great event last time.
Rich
rthorne is offline Find More Posts by rthorne
Old Dec 02, 2012, 04:55 AM
Mach3 is online now
Find More Posts by Mach3
Surrey, B.C.
Joined Feb 2004
I've had very good support from Rob@ADC in the past & I just order a 57" extra from him (just waiting on shipping info).
My guess it's a supply problem between him & 3DHS as if you look on the ADC site almost all the 3DHS planes are out of stock.
My buddy was waiting for him to get a Vyper Bype instock but he still hasn't so my buddy ended up having to order it direct from 3DHS at a higher shipping cost.
Mach3 is online now Find More Posts by Mach3
Old Dec 02, 2012, 10:34 AM
Shirty is offline
Shirty's Avatar
Joined Oct 2012
thanks. I finally heard from rob and 4 weeks for all the out of stock stuff i want including the plane. guess ill just be patient.
Old Dec 02, 2012, 09:26 PM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Looking to sell the gear that was in my 47" SHP. This gear was bought end of September. Thought I would give the Fanatics first dibs before I post in the FS forum. Never been crashed
Omega 130g $64.99 mew
Extreme Flight Airboss 45A Elite ESC $99.99 new
Combo price $110 shipped in the continental US
4 HS-65MG servos
$75.00 Shipped
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Discussion Unofficial NQD Tear Into Jet Boat Mod Thread Energy Racing Boats - Electric 14519 Yesterday 10:44 PM
Discussion Banana Hobby Customer Support Request/Q and A Thread! banana hobby Banana Hobby 1151 Jan 28, 2016 06:03 PM
Discussion The Official AirWare Q&A Thread AndyKunz Radios 95 Feb 14, 2013 09:36 AM
Discussion THE FIRST UNOFFICIAL Parkzone Sukhoi mods thread!!!! bluemeane Micro Ready-to-Fly 27 Aug 18, 2009 12:23 AM
Megatech H2O unofficial thread and first rewiew. grk65 Racing Boats - Electric 7 Mar 05, 2007 01:09 AM
