Old Mar 03, 2012, 02:42 PM
aronph is offline
Find More Posts by aronph
TEAM HILLBILLY
aronph's Avatar
Groveport, OH...USA
Joined Nov 2010
Originally Posted by shadow102 View Post
the only reason i wouldnt use them is because with an epp plane your going to be setting it down hard from time to time so its going to be possible to strip the HB gears
doesnt the slick foamie have landing gear?
aronph is offline Find More Posts by aronph
Old Mar 03, 2012, 03:00 PM
shadow102 is offline
Find More Posts by shadow102
shadow102's Avatar
United States, GA, Acworth
Joined Mar 2011
it does, i am talking about low level maneuvers where you need to set it down on something other than the landing gear
shadow102 is offline Find More Posts by shadow102
Old Mar 03, 2012, 03:03 PM
G.P. is online now
Find More Posts by G.P.
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
Originally Posted by lammbn View Post
What planes? i bought 3mm threaded spot-on arms for my 74 and turns out the hardware is 2mm. the bolts fit pretty close inside the holes so i just put the 2mm bolts through and tightened everything down tight. there is no slop in my linkages at all even after 10 flights and lots of abuse thrown at them. the ball in the link isnt supposed to move anyways so it gets locked down tight and doesn't move even though the bolt isn't a perfect fit in the hole. come to think of it i did the same thing on the metal arms for the ailerons on my 71 and they have been holding well for a while now. i check them all the time in my preflights. i grab the arm and the rod and see if there is any play from the bolt not fitting tight. i have tried pretty hard and they aren't going anywhere. it my not be necessary to redo the whole linkage.
They're Secraft arms. Usually i just drill new holes, but there isn't much extra room on these. I guess I could just put some JB Weld in the holes and re-drill. That might be a nice quick and easy option...
Thanks for the ideas.
Just to clarify. he has a more battery weight that i do. 2x gens ace 4s 4000 = 864g where my gens ace 6s 5300 = 752g. also he mounted his components a lot more forward than i did it sounds like. i didn't know CG might be an issue so i mounted my ICE2 120HV against the first former and my CC BEC pro back inside the canister tunnel under the battery tray. I also was one of the first ones to get the new lighter 5320 without the rear housing and the fiberglass X-mount. i waited an extra few days for ken to get the first batch in stock. that would explain why my batteries are more forward than his. i would compare your setup to each of ours and see where you lie to get a good idea of where you will be.
Thank you for the extra info. I got the new lightened motor too. It's pretty sweet!
G.P. is online now Find More Posts by G.P.
Old Mar 03, 2012, 03:24 PM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Did the wing bolt break?
I didn't realize we were putting much stress on them.
cmala is offline Find More Posts by cmala
Old Mar 03, 2012, 06:05 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
Originally Posted by Eagle34 View Post
Pretty sure its 12 guage.
Thanks.
zmonster97 is offline Find More Posts by zmonster97
Old Mar 03, 2012, 07:04 PM
3Daddict is offline
Find More Posts by 3Daddict
Addicted to 3DHS and EF
3Daddict's Avatar
United States, FL, Bonita Springs
Joined Oct 2010
You have a point, I might hold off on the foamy untill I can save up some money to convert the HB to MG with a gear set.
3Daddict is offline Find More Posts by 3Daddict
Old Mar 03, 2012, 08:32 PM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
Originally Posted by G.P. View Post
Little conflicting information, but that's good to hear!
I was going by this post: http://www.rcgroups.com/forums/newre...ply&p=20911754
I think it was covered above, but that new lightened 5320 is probably a big part of that, I think that cuts about 3-4 ounces off. I didn't realize he had the lightened 5320 series.
ryan_m is offline Find More Posts by ryan_m
Old Mar 03, 2012, 08:41 PM
DeuceTrinal is offline
Find More Posts by DeuceTrinal
Landings are not optional
DeuceTrinal's Avatar
Van Nuys, CA
Joined Sep 2003
Just fly them. If they do strip, put MG in them. I've had HBs last through some pretty hard stuff, especially in foam airframes which give some.
DeuceTrinal is offline Find More Posts by DeuceTrinal
Old Mar 03, 2012, 09:09 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
The new 5320 is ounces lighter than the original?
going4speed is offline Find More Posts by going4speed
Old Mar 03, 2012, 09:12 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Holy cow I didnt relize that the lightened 5320 was that much lighter. Well since my 71 slick is down for a freashing up I guess I am going to send mine back to get lightened. 3 to 4 ounces is alot. I am also going to send back my 3615 to get lightened when I get the 71 back in the air (dont want to be without both of those at one time)
losifanatic is offline Find More Posts by losifanatic
Old Mar 03, 2012, 09:15 PM
3DHS 'native'
USA, TX, Spring
sounds like the new 5320 is lighter than a 4325 then...holy carp!!
Old Mar 03, 2012, 09:20 PM
Sippin the Koolaid!
Joined Oct 2007
The 5320 was 5 ounces heavier than my 4325. So it will bring it closer to that weight
Sippin the Koolaid!
Joined Oct 2007
Jut sent Ken an email about sending my motor back to get lightened
Old Mar 03, 2012, 09:28 PM
SportFlyer2 is offline
Find More Posts by SportFlyer2
United States, TX, Palacios
Joined Feb 2009
Some one suggest a good plane for a Motrolfly 4320-300 that's in stock at 3DHS...besides a Big Vyper...
SportFlyer2 is offline Find More Posts by SportFlyer2
Old Mar 03, 2012, 09:30 PM
HugoCraft is offline
Find More Posts by HugoCraft
Aerobatic Fanatic
HugoCraft's Avatar
United States, KY, Louisville
Joined Sep 2007
One time I flew the 70" gas slick then out of nowhere I need to move the aileron stick 1/4 inch for it to fly straight so I immediatly landed it. One wing bolt started to come loose and the wing wanted to come out but didn't.
HugoCraft is offline Find More Posts by HugoCraft
Discussion Unofficial NQD Tear Into Jet Boat Mod Thread Energy Racing Boats - Electric 14954 Jun 27, 2016 03:25 PM
Discussion Banana Hobby Customer Support Request/Q and A Thread! banana hobby Banana Hobby 1157 Jun 26, 2016 09:16 PM
Discussion The Official AirWare Q&A Thread AndyKunz Radios 95 Feb 14, 2013 08:36 AM
Discussion THE FIRST UNOFFICIAL Parkzone Sukhoi mods thread!!!! bluemeane Micro Ready-to-Fly 27 Aug 17, 2009 11:23 PM
Megatech H2O unofficial thread and first rewiew. grk65 Racing Boats - Electric 7 Mar 05, 2007 12:09 AM
