Old Nov 27, 2012, 07:02 AM
DaaBears is offline
Find More Posts by DaaBears
Santi
DaaBears's Avatar
United States, MO, Clayton
Joined Nov 2003
Originally Posted by hone1er View Post
Another servo question...If you can run hs 7955TGs on 7.4v would that give it about the same specs as the 7954SH?
Is there a reason to choose one over the other? I'm probably going to go with hs 7955s but was just wondering, is the only difference titanium gears vs steel gears?
What are you grabbing 7955's for? I just grabbed 4 for $80 each on Black Friday for my 89" slick that i don't have! seems the crowd loves them on the big birds,'with a 5665 on throttle...
DaaBears is offline Find More Posts by DaaBears
Old Nov 27, 2012, 07:23 AM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
Yep that is a perfect set up. There are much better servos out there but for the money, the Hitecs are great, reliable, strong and fast. The titanium gears last much longer than the steel gears which will save you money in the long run. I have replaced the gears in all my 7954's after about 2 years. At $30 a pop, its rather spendy.
nebwake is offline Find More Posts by nebwake
Old Nov 27, 2012, 08:22 AM
Irg is online now
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
you'll need 5, fyi.
Irg is online now Find More Posts by Irg
Old Nov 27, 2012, 09:06 AM
DaaBears is offline
Santi
DaaBears's Avatar
Joined Nov 2003
Originally Posted by Irg View Post
you'll need 5, fyi.
What!?!?!
Lol- they only had 4 left at the $80 price!
Good catch though, that would have been a bad day if I found out I needed 5 at the time of the build!
But, when I was budgeting I did completely forget about the throttle servo. All this electric flying!! It's weird, when I started, electric wasn't around, so I knew all about gas tanks and clunks and carbs, but knew nothing about an esc, brushless, what C meant, and deans connectors.
Old Nov 27, 2012, 09:25 AM
ryan_m is online now
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
no - the throttle will be a 6th servo. You have two elevator servos in the 50cc class. So two elevator, two ailerons, one rudder, one throttle, and if you desire, another for a choke servo.
ryan_m is online now Find More Posts by ryan_m
Old Nov 27, 2012, 09:42 AM
Irg is online now
Irg
Irg
Irg's Avatar
Joined Apr 2009
I think he gets it.
chief and troy built both sell the 7955s for about $85 if you buy four, iirc.
Old Nov 27, 2012, 09:47 AM
DaaBears is offline
Santi
DaaBears's Avatar
Joined Nov 2003
I think he gets it.
Thank you- tb was sold out, but looks like chief has some for 90... Only need 1!
Old Nov 27, 2012, 10:43 AM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
7954 has a coreless motor. Does the 7955? If it does then I have to wonder why the 7954 even exists as the prices are near identical.
So it's pretty much titanium or steel than.
going4speed is offline Find More Posts by going4speed
Old Nov 27, 2012, 10:52 AM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Yeah they're both coreless...
hone1er is offline Find More Posts by hone1er
Old Nov 27, 2012, 11:23 AM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
My 70" slick is really nose heavy. I am at the point of needing to add weight to the tail I think. I was thinking about adding a second elevator servo. Will 2 oz in the tail of a 10.5 pound plane change things very much?
3DNater is offline Find More Posts by 3DNater
Old Nov 27, 2012, 11:36 AM
Irg is online now
Irg
Irg
Irg's Avatar
Joined Apr 2009
yes it will, rcbirk dropped the physics somewhere but I don't know it off the top of my head.
you might try a dubro tailwheel with aluminum hub. a small amount weight that far from cg can help quite a bit
Old Nov 27, 2012, 11:49 AM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
Thanks! My nose-heaviness is pretty bad... I think I'll try the servo... I have one on-hand that I can try. I'll probably start out just taping it on the outside for a test flight to see how it changes things. At least another servo will be adding redundancy in case one of the servos fails.
Old Nov 27, 2012, 11:59 AM
Irg is online now
Irg
Irg
Irg's Avatar
Joined Apr 2009
not sure if this actually backs up my statement, but since I took the excruciating six minutes to find it on my phone:
cg physics
Old Nov 27, 2012, 12:05 PM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
cg physics
It makes pretty good sense to me I like it when I can see how to evaluate the effects based on math. It makes everything make a lot more sense... even if the numbers are estimates Hope that makes your excruciating search worthwhile
Old Nov 27, 2012, 01:10 PM
quadracer is online now
Find More Posts by quadracer
No, I won't ship it. Don't ask
quadracer's Avatar
United States, IN, Derby
Joined Feb 2012
Gas or electric? My 70 had the rudder servo in the tail and balanced nicely with the DLE30.
quadracer is online now Find More Posts by quadracer
Discussion Unofficial NQD Tear Into Jet Boat Mod Thread Energy Racing Boats - Electric 15000 Jul 26, 2016 07:33 PM
Discussion Banana Hobby Customer Support Request/Q and A Thread! banana hobby Banana Hobby 1163 Jul 26, 2016 11:37 AM
Discussion The Official AirWare Q&A Thread AndyKunz Radios 95 Feb 14, 2013 08:36 AM
Discussion THE FIRST UNOFFICIAL Parkzone Sukhoi mods thread!!!! bluemeane Micro Ready-to-Fly 27 Aug 17, 2009 11:23 PM
Megatech H2O unofficial thread and first rewiew. grk65 Racing Boats - Electric 7 Mar 05, 2007 12:09 AM
