Old Oct 07, 2012, 06:32 PM
3Daddict is offline
Find More Posts by 3Daddict
Addicted to 3DHS and EF
3Daddict's Avatar
United States, FL, Bonita Springs
Joined Oct 2010
Originally Posted by quadracer View Post
I've hung them in the trees a couple times.... Don't hate.
I think we all put them in the trees. I have put three in the trees before. However I have not done so in two years.
3Daddict is offline Find More Posts by 3Daddict
Old Oct 07, 2012, 06:34 PM
goflyhighrc is offline
Find More Posts by goflyhighrc
Just go with the flow
goflyhighrc's Avatar
Joined Nov 2006
A friend at our flying field is haveing trouble with his dle30. He crashed is old 70 Slick and put a new one together, since the installing the motor his problems are state below. Anyone have an idea what could be wrong so we can give it a try before sending it back to the Vendor. Does the DLE 30 use the same carb as a DA 60?
I have to send the engine back to Troy. I believe the carburetor or ignition went south. Two things: 1) I canít get it to idle under 5200rpm and 2) after I took the carburetor off for inspection, it hard to start and when it does the engine constantly backfires. Iím bummed.
goflyhighrc is offline Find More Posts by goflyhighrc
Old Oct 07, 2012, 06:42 PM
quadracer is offline
Find More Posts by quadracer
No, I won't ship it. Don't ask
quadracer's Avatar
United States, IN, Derby
Joined Feb 2012
I've done it twice by hitting LVC in a hover over trees, and once when I didn't pull out of a flatspin in time. I've only been flying since last November-ish, but I think I can manage to not do that anymore as well.
quadracer is offline Find More Posts by quadracer
Old Oct 07, 2012, 06:46 PM
quadracer's Avatar
Joined Feb 2012
Sounds like it is leaking air around the carb base, but as far as not idling under 5k, I don't know. I would try a new ignition first, and check that the timing sensor wasn't moved or damaged in the crash. Also, clean the carb out really good, as some dirt may have gotten into the reed valves.
Old Oct 07, 2012, 07:09 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
Sounds like a stuck reed. Carb rebuild kit, bowman reed and bowman piston ring.
going4speed is offline Find More Posts by going4speed
Old Oct 07, 2012, 08:37 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
Originally Posted by jfuller1250 View Post
Congrads on the huckfest! Talked to a couple of people that went and sounded like you did a great job. It is on my list for next year!
For sure! See you here!
....Does the DLE 30 use the same carb as a DA 60?
No.
Bivens is offline Find More Posts by Bivens
Old Oct 07, 2012, 11:10 PM
hertzrepkeith is offline
Find More Posts by hertzrepkeith
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
Hey I ordered a new ignition today. I will tell you the story tomorrow. This one works fine. If he wants to use it to see if that fixes his issue he is welcome too. Talk to you tomorrow.
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Oct 08, 2012, 02:44 PM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Any fanatics out there that can make up a Power pole lead for me? I have a DA ignition and they use a power poll connections. I would like to solder this to the lead from my IBEC. I am getting a new ignition from DA and that is the way they come. On my first one I removed the PP connector and soldered the servo connector to it.
This is what they look like
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Oct 08, 2012, 03:11 PM
teookie is offline
Find More Posts by teookie
Perfect 3pt inverted landing!
teookie's Avatar
USA, AL, Huntsville
Joined Oct 2008
So what you need is a PP to female servo adapter?
Whats stopping you from cutting and soldering the new one?
I could build one for you but I'm all out of female servo connectors.
teookie is offline Find More Posts by teookie
Old Oct 08, 2012, 04:03 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
DA ignitions usually come with a power pole pigtail that matches that plug so you can make up whatever you need to connect it to a pack. that said, cutting their powerpole plug off is usually the first thing I do
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Oct 08, 2012, 04:04 PM
On loan to Texas
Joined Oct 2005
I did not know that they made that but after a search I see they do. After thinking about it though that is just to many connectors. On my first ignition I took a servo extension and cut off the PP connector on the ignition and soldered the 3" extension to the ignition. I think I will just do that again.
Old Oct 08, 2012, 09:22 PM
Bivens is offline
Team 3DHS / Team JR
Bivens's Avatar
Joined Apr 2010
Yep..I cut and splice...everytime.
Old Oct 08, 2012, 09:46 PM
Joined Nov 2006
Would anyone know the size of the axle for the 89 " Slick, can't find it anywhere, are they metric ??
Old Oct 08, 2012, 09:51 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Ok....Micrometer in right hand, axle in left, actual measurement is .1985"..... 3/16"=.1875", for a difference of .011" 3/16" easily drilled to to size.
And .1985"= 5.04mm You can drill a 3/16" wheel collar to .1990 with a #8 drill bit....
SteveT
SteveT. is online now Find More Posts by SteveT.
Old Oct 08, 2012, 09:57 PM
3DHS 'native'
USA, TX, Spring
Weird I thought they would be 5mm
Discussion Unofficial NQD Tear Into Jet Boat Mod Thread Energy Racing Boats - Electric 15109 Sep 28, 2016 11:01 AM
Discussion Banana Hobby Customer Support Request/Q and A Thread! banana hobby Banana Hobby 1166 Aug 09, 2016 01:19 AM
Discussion The Official AirWare Q&A Thread AndyKunz Radios 95 Feb 14, 2013 08:36 AM
Discussion THE FIRST UNOFFICIAL Parkzone Sukhoi mods thread!!!! bluemeane Micro Ready-to-Fly 27 Aug 17, 2009 11:23 PM
Megatech H2O unofficial thread and first rewiew. grk65 Racing Boats - Electric 7 Mar 05, 2007 12:09 AM
