Old Sep 11, 2012, 10:11 PM
goflyhighrc is offline
Find More Posts by goflyhighrc
Just go with the flow
goflyhighrc's Avatar
Joined Nov 2006
Originally Posted by 3171scott View Post
That just hurts to watch! did uou find out what caused the dead stick!
Not a clue ! had it on a high idle switch with high idle on, no idea what could have happened.
goflyhighrc is offline Find More Posts by goflyhighrc
Old Sep 11, 2012, 10:18 PM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Originally Posted by dentalpain View Post
The problem i run into with blipping while trying to lower can* be sudden torque roll
True but also blipping the throttle helps me keep it from torque rolling.
I think...
Heck, I havent flown anything in 3 months so dont listen to me.
cmala is offline Find More Posts by cmala
Old Sep 11, 2012, 10:21 PM
Joined Nov 2006
I think...
I've read that guys pulse it to keep the engine from loading up fowling the plug and flamming out. Not sure it's true or not, not experienced enough.
Old Sep 11, 2012, 10:33 PM
RotorJockey is offline
Find More Posts by RotorJockey
Fly Low-Crash-Rebuild-Repeat !
RotorJockey's Avatar
Jackson, MO
Joined May 2009
I think...
Whoa! Craig!
You haven't flown since you were here!
That just plain suxxx...
RotorJockey is offline Find More Posts by RotorJockey
Old Sep 11, 2012, 11:16 PM
crazyj is online now
Find More Posts by crazyj
MultiCopterPilot & Film Maker
crazyj's Avatar
United States, WA, Kent
Joined Oct 2002
WOOT! My new 51" Slick was sitting on my door-step tonight. After just a few hours of work the tail surfaces, landing gear, and tail wheel are installed. Expect to finish the model tomorrow night or Thursday!
crazyj is online now Find More Posts by crazyj
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Originally Posted by RotorJockey View Post
Whoa! Craig!
Just about. I took the girls out and let them fly back in june. Oh, I did maiden plus one flight on my cub with floats but that doesn't really count
Old Sep 12, 2012, 06:28 AM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
If tuned properly you shouldnt need to.
With an electric a hit of throttle will stop it from torqueing. I have noticed with gas when you hit the throttle it will torque. Took me a bit to get used to that after flying nothing but electrics.
losifanatic is offline Find More Posts by losifanatic
Old Sep 12, 2012, 07:08 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
How do you guys lower your planes in hover, pulse the throttle and lower the stick a bit at a time or keep constant power and lower the stick. Used to do it pretty decent but lately can't lower it at all. 89 gas slick
Ryan Evans told me one time that to "stop" the torque roll, or help stop it for those of us/ me who are not ready for belly in, to blip the throttle LOWER. The trick it to drop it the. Get the stick back around where it was, meaning instead of goosing the throttle, yur going down instead of up. This was very hard for me to make my fingers do heheheh. But it does stop the roll.
Manta1 is offline Find More Posts by Manta1
Old Sep 12, 2012, 07:20 AM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
It takes more practice, but you will torque roll less with smooth throttle. And slowly reducing throttle to lower the plane. My friend who will torque roll his 40% carden 1" off the ground will almost never blip the throttle.
nebwake is offline Find More Posts by nebwake
Old Sep 12, 2012, 08:25 AM
ryan_m is online now
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
My problems with lowering it came just after this, might have something to do with it
http://youtu.be/w9MWjPwH2eA
Ouch. But if you were hovering lower the damage would have been less. You were right in the death zone..too low to recover, and high enough to do damage. For an 89 I would either hover higher than 75-100 feet, or under 15! So keep that in mind to convince yourself to go lower!
ryan_m is online now Find More Posts by ryan_m
Old Sep 12, 2012, 12:52 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
aerodynamics doesn't know what is causing the prop to go around, no difference between electrics and gassers... it's probably just prop selection with respect to prop weight and dimensions. Get a light prop on there like a Falcon or Vess carbon, sweetness. Throttle pulsing on 104's can actually get them to rotate slowly against torque.
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Sep 12, 2012, 12:55 PM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
Those having issues in holding the plane from torque rolling in a hover... the two best things that will help are: a) more aileron throw, or b) see if you can make the plane lighter. Most 3DHS planes will happily have enough aileron authority to stop a torque roll, but if you can make the plane lighter, this is the easiest way to help out as the plane needs less torque to hold the hover...
Old Sep 12, 2012, 04:36 PM
REXBIRK is offline
Find More Posts by REXBIRK
United States, FL, Fort Myers
Joined Apr 2009
I take meshed drywall tape line the inside of the wheel pants, then a thin coat of Gorilla Glue. I just run water from a faucet inside the pants wet them good then shake the water out then brush the GG glue over the meshed tape. The GG glue expands to app 1/4 inch thick and just adds a couple of grams to each pant. Haven't cracked a pant since. I also use 2mm blind nuts and bolts vs. the screws on the landing gear. Other guys at my field have used the meshed tape and epoxy they are much more durable than stock but they still crack a bit. Gorrill Glue over the mesh holds yet is flexible.Done this on my 51 -70 and 89 Slicks. You won't be dissapointed.
http://www.toolup.com/marshalltown_m...FQjZQgodjVgAUg
Great idea! I will try that! I will add a block on the outside for the axle to fit in also. Wonderful ideas guys!
REXBIRK is offline Find More Posts by REXBIRK
Old Sep 12, 2012, 06:01 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
REX....bring E and come on down for huckfest!!!
Bivens is offline Find More Posts by Bivens
Old Sep 12, 2012, 08:15 PM
Joined Nov 2006
Originally Posted by Bivens View Post
I fiberglass the inside of my wheel pants and you can glass a wood block in the outer side of the pant with a hole to fit the end of the axle....very durable.
Add a block to the outside of the pant, or the inside of the outeside, any pics.
Discussion Unofficial NQD Tear Into Jet Boat Mod Thread Energy Racing Boats - Electric 15005 Today 06:36 PM
Discussion Banana Hobby Customer Support Request/Q and A Thread! banana hobby Banana Hobby 1163 Jul 26, 2016 11:37 AM
Discussion The Official AirWare Q&A Thread AndyKunz Radios 95 Feb 14, 2013 08:36 AM
Discussion THE FIRST UNOFFICIAL Parkzone Sukhoi mods thread!!!! bluemeane Micro Ready-to-Fly 27 Aug 17, 2009 11:23 PM
Megatech H2O unofficial thread and first rewiew. grk65 Racing Boats - Electric 7 Mar 05, 2007 12:09 AM
