Old Sep 09, 2012, 04:54 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Got the 7 point curve done today. Man that makes all the difference in the world. Now l have to go somewhere so l can watch the video for the timer
losifanatic is offline Find More Posts by losifanatic
Old Sep 09, 2012, 04:58 PM
REXBIRK is offline
Find More Posts by REXBIRK
United States, FL, Fort Myers
Joined Apr 2009
I am an old rc flyer with three 3DHS planes. All gas. 70" Slick, 72" Extra and 71" Slick. My question pertains to wheel pants. I have a love hate relationship with them. They are a royal pain in the a## to maintain but look so good!
Weight is not an important consideration to me but durability is. Has anyone beefed up their wheel pants to make them more durable. If so how?
I assume they are resin based fiberglass instead of epoxy?
REXBIRK is offline Find More Posts by REXBIRK
Old Sep 09, 2012, 05:10 PM
skippy78 is offline
Find More Posts by skippy78
skippy78's Avatar
USA, VA, Narrows
Joined Mar 2009
A paper towel and thin ca or light fiberglass cloth and epoxy.
skippy78 is offline Find More Posts by skippy78
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
I fiberglass the inside of my wheel pants and you can glass a wood block in the outer side of the pant with a hole to fit the end of the axle....very durable.
Bivens is offline Find More Posts by Bivens
Old Sep 09, 2012, 05:17 PM
gremlin is offline
Find More Posts by gremlin
What?!? I didn't do that!
gremlin's Avatar
United States, NY, Orchard Park
Joined Dec 2002
Losi, if you can't get to watch the video the steps are listed below. It should only take a few minutes to set up.
Go to FUNCTION LIST
1. Go to STICK POS SW menu
2. Go to SPS0 and Select "THRO" to use the throttle stick as the switch
3. SYM shoulkd be set to "OFF"
5. Go to "AREA" and select "HIGH"
6. Go to "POS" and set to "L96" or whatever value you want to start the timer.
At this point you should be able to move the throttle stick and SPS0 at the top should go from "OFF" to "ON" to indicate the switch changing.
Leave STICK POS SW menu and go to TIMER menu
1. Select TIMER1 (or 2 or 3, depending on which one you want)
2. Change the next setting from INH to DOWN or STOP depending on the timer you want
3. Set the time amount after DOWN
3. Set START and STOP to "SPS0" to use the switch you just set up.
That should be it.
gremlin is offline Find More Posts by gremlin
Old Sep 09, 2012, 06:39 PM
goflyhighrc is offline
Find More Posts by goflyhighrc
Just go with the flow
goflyhighrc's Avatar
Joined Nov 2006
I take meshed drywall tape line the inside of the wheel pants, then a thin coat of Gorilla Glue. I just run water from a faucet inside the pants wet them good then shake the water out then brush the GG glue over the meshed tape. The GG glue expands to app 1/4 inch thick and just adds a couple of grams to each pant. Haven't cracked a pant since. I also use 2mm blind nuts and bolts vs. the screws on the landing gear. Other guys at my field have used the meshed tape and epoxy they are much more durable than stock but they still crack a bit. Gorrill Glue over the mesh holds yet is flexible.Done this on my 51 -70 and 89 Slicks. You won't be dissapointed.
http://www.toolup.com/marshalltown_m...FQjZQgodjVgAUg
goflyhighrc is offline Find More Posts by goflyhighrc
Old Sep 09, 2012, 06:57 PM
Luv3d is offline
Find More Posts by Luv3d
Honeybadger don't care...
Luv3d's Avatar
United States, FL, Winter Park
Joined May 2010
Guys,
I had to put my VR1 up for sale today. 10% off for any central florida fanatic interested.
http://www.rcgroups.com/forums/showthread.php?t=1728769
Luv3d is offline Find More Posts by Luv3d
Old Sep 09, 2012, 07:12 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Originally Posted by Luv3d View Post
Guys,
That's a good deal. I noticed you were also selling another plane too. Funding a new project maybe?
turnerm is offline Find More Posts by turnerm
Old Sep 09, 2012, 08:15 PM
Luv3d is offline
Luv3d's Avatar
Joined May 2010
Yessir...jones'in for a 58" Edge, maybe, and an SV...?
Old Sep 09, 2012, 08:23 PM
Sippin the Koolaid!
Joined Oct 2007
Go to FUNCTION LIST
That should be it.
Wow thanks. I will give that a go in the morning
Old Sep 10, 2012, 04:45 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
edit; fixed.
theKM is offline Find More Posts by theKM
Old Sep 10, 2012, 09:08 PM
Joined Nov 2006
You using it on gas or electric setup?
Old Sep 10, 2012, 09:21 PM
jcfab is offline
Find More Posts by jcfab
Landing, HEY, I got it!!!!!
jcfab's Avatar
United States, TX, Celina
Joined Oct 2010
It would be cool if Ben reads this.........
Dear Mr Fisher,
In 2010 I acquired several used 3DHS planes with the intent to learn how to fly some 3D stuff.
Fifty to sixty mishaps (with no real damage) later I realized that landing smoothly was important and focused on that task. Progress was very slow due to my schedule and this D@mn Texas wind, I finally felt I could get a plane back on the ground without ripping the gear out of it.
Yesterday the stars were aligned and I finally had real FUN with my V1 Velox!!!!!
Is this a great hobby or what????
I'm now looking forward the more flight time instead of dreading doing something stupid and having to fix more landing gear!
I couldn't have made this trip without fantastic, strong planes from 3DHS and countless answers to my dumba$$ questions.
Progress report to follow and only a few weeks away from having the b@lls to maiden the 51" Slick!
Jeff
jcfab is offline Find More Posts by jcfab
Old Sep 10, 2012, 09:47 PM
jcfab is offline
jcfab's Avatar
Joined Oct 2010
On another note......
I studied my DX7 settings and found my elevator end points @ 90% and dual rates @ 50% and 80%. I had the recommended throws but the plane was always straight up or straight down!!!
I removed the 3DHS long arms and used the long HS-65 arms. with this set-up I set the end points @ 140% and the dual rates @ 50% and 100%.
The plane is MUCH easier to fly smooth.
DUH! As Ben has said many times in here and elsewhere. "Use the long 3DHS arms if you NEED them for your TX."
Resolution seems to be much more important than throw!
There are a lot of newer people on here who could benefit greatly from this ooops of mine.
Jeff
Old Sep 10, 2012, 09:53 PM
DaaBears is offline
Find More Posts by DaaBears
Santi
DaaBears's Avatar
United States, MO, Clayton
Joined Nov 2003
Description:
Just starting my Chicago themed slick!
DaaBears is offline Find More Posts by DaaBears
Discussion Unofficial NQD Tear Into Jet Boat Mod Thread Energy Racing Boats - Electric 14716 Today 03:05 PM
Discussion Banana Hobby Customer Support Request/Q and A Thread! banana hobby Banana Hobby 1154 Feb 20, 2016 11:20 AM
Discussion The Official AirWare Q&A Thread AndyKunz Radios 95 Feb 14, 2013 08:36 AM
Discussion THE FIRST UNOFFICIAL Parkzone Sukhoi mods thread!!!! bluemeane Micro Ready-to-Fly 27 Aug 17, 2009 11:23 PM
Megatech H2O unofficial thread and first rewiew. grk65 Racing Boats - Electric 7 Mar 05, 2007 12:09 AM
