Old Sep 08, 2012, 07:58 PM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
The last time out with my 87" SHP i pulled the throttle back pulled back some elevator and some left rudder. They felt about 25% so that is what I set up along with throttle position to zero and also killing my IBEC (two shots at killing the motor) The flight looked like a gental spiral down. On FG there is two sides basically for those that set it up one believe that you put it in a snap and let it go in right over its position and the other though is the slower crash like I just described. One advantage of the slower method is that there will be more time to warn bystanders.
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
goflyhighrc is online now
Find More Posts by goflyhighrc
Just go with the flow
goflyhighrc's Avatar
Joined Nov 2006
Originally Posted by gremlin View Post
If it's like my JR 11x I would have to assume "stk" means the actual stick position and "out" mean the throttle percentage being sent out to the motor set in the curve.
Should the they match ? should the stick position = the output %.
goflyhighrc is online now Find More Posts by goflyhighrc
Old Sep 08, 2012, 08:04 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
No dont match them b/c if you set the stk at 36% and the out at 36% you havent done anything. What that means is at 36% stick travel you are putting out 36% power. So its still linear= no curve
losifanatic is offline Find More Posts by losifanatic
Old Sep 08, 2012, 08:15 PM
gremlin is offline
Find More Posts by gremlin
What?!? I didn't do that!
gremlin's Avatar
United States, NY, Orchard Park
Joined Dec 2002
About the only thing that sucks about the 11X is the manual, I think it is very flexible once you figure out how to set things up.
Originally Posted by losifanatic View Post
Why does the 11x only have a 3 point throttle curve? Kind of useless to me. Or am I doing something wrong?
The 11X has up to a 7 point throttle curve, you just add additional points where you want them. Go to the throttle curve option and start moving the throttle stick. You will see "ADD" in the bottom left. Press the button and it will add a curve point at that stick position. Once a point is added, when you move the stick back to that position "DEL" will appear at the bottom left for you to delete that point if you want it somewhere else
Oh while I am asking Jr radio questions is there a way to put the timer on the throttle stick with the 11x. I can't seem to remember to hit the button.
You have to set up a stick position switch first then tie it to a timer. Here's a youtube video on how to do it, except he may have the on and off options switched.
JR11X Throttle Stick Timer (1 min 19 sec)
Losi, please PM me if you need to chat about anything on setting up the radio.
gremlin is offline Find More Posts by gremlin
Old Sep 08, 2012, 08:20 PM
gremlin is offline
gremlin's Avatar
Joined Dec 2002
You should be able to scroll to the "out" setting for each point and change it to whatever value you want the throttle at for that curve point.
Old Sep 08, 2012, 08:26 PM
Joined Nov 2006
How does that relate to the "stk" % on the screen.
Sippin the Koolaid!
Joined Oct 2007
http://www.youtube.com/watch?v=oN70ZUNYZ-0
Wow awesome. I knew it just had to be me. I will try it out tomorrow. Thanks. If i run into a snag l will pm ya
Old Sep 08, 2012, 08:39 PM
gremlin is offline
gremlin's Avatar
Joined Dec 2002
The "stk"% is the percentage of full travel of actual throttle stick,. 0% would be when the stick is at the bottom and 100% is where the stick would be at the top. So if you have a "stk' value of 25 and an "out" value of 10, when your throttle stick is a quarter of the way up, the motor will be operating like it's at 10% throttle. Lokking at the 10C manual, it looks like you can move or delete curve points too.
Old Sep 08, 2012, 08:42 PM
Joined Nov 2006
That make a little sense, looks like you have to adjust both "stk" and "out" to set up your throttle curve. On my 9303 there are 7 points I set each point to the percentage I want. On the 10c if you want your throttle to run at 30% at mid stick you have to set point 4 "stk" at 50% and point 4 "out" at 30%. Doe's that seem correct.
Old Sep 08, 2012, 08:53 PM
gremlin is offline
gremlin's Avatar
Joined Dec 2002
That make a little sense, looks like you have to adjust bothe "stk" and "out" to set up your throttle curve.
Yes, It would depend on what shape you want the curve and how smooth you want the transition from point to point. Once you start setting the curve the graph helps give you an idea what the motor will see as you move the throttle stick from bottom to top.
And yes, your example seems correct.
Old Sep 08, 2012, 09:00 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
so failsafe you should be able to shut off the transmitter and the servos go to failsafe position?
If this is the case I am missing a step as it does not work
going4speed is offline Find More Posts by going4speed
Old Sep 08, 2012, 09:26 PM
On loan to Texas
Joined Oct 2005
Yes but on my 8FG there are two fail safe's to program, one is signal and one is battery. Check that out. What % of stick movement did you set?
Old Sep 08, 2012, 10:05 PM
3DHS 'native'
USA, TX, Spring
all stick movements are about 12-15%. I think it sometimes does not work if you turn the transmitter on after the receiver. Now I dont do that when I am about to fly but this was just on the bench.
Old Sep 09, 2012, 07:06 AM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
Gremlin, thanks for the curve fix, ill have to let my buddy know about that, we were perplexed by the 3pt curve as well.
nebwake is offline Find More Posts by nebwake
Old Sep 09, 2012, 01:26 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
That 11x programming is very similar to the 12X....overall it's a big upgrade over the 9503...but the DX18 is still way MORE programmable in many ways.
Bivens is offline Find More Posts by Bivens
Discussion Unofficial NQD Tear Into Jet Boat Mod Thread Energy Racing Boats - Electric 14954 Jun 27, 2016 03:25 PM
Discussion Banana Hobby Customer Support Request/Q and A Thread! banana hobby Banana Hobby 1157 Jun 26, 2016 09:16 PM
Discussion The Official AirWare Q&A Thread AndyKunz Radios 95 Feb 14, 2013 08:36 AM
Discussion THE FIRST UNOFFICIAL Parkzone Sukhoi mods thread!!!! bluemeane Micro Ready-to-Fly 27 Aug 17, 2009 11:23 PM
Megatech H2O unofficial thread and first rewiew. grk65 Racing Boats - Electric 7 Mar 05, 2007 12:09 AM
