Old Mar 01, 2012, 02:57 PM
lammbn is online now
Find More Posts by lammbn
Hooked on 3DHS
lammbn's Avatar
United States, ID, Boise
Joined Nov 2009
Originally Posted by SnowDog1974 View Post
Thanks guys, I am planning my first purchase of these connectors, so I think I'll go with the 45's.
Good choice. just if you didn't know the 30 and 45 use the same housing, just different terminals so you can get some 30A bare terminals for cheap and use them with the 45A sets if you have smaller wire to use occasionally. Also, i learned the hard way after months of crimping them with standard crimpers but the $40 TRIcrimp crimpers are worth hundreds of dollars in how easy they make using powerpoles. wish i hadn't have been such a cheapskate before and bought them to begin with. Block-loks are also great cheap insurance too for while your in the air and easy to use.
Sorry for the long post. just trying to help you not make mistakes i made.
lammbn is online now Find More Posts by lammbn
Old Mar 01, 2012, 03:01 PM
harddrive8 is offline
Find More Posts by harddrive8
Nothin Ventured, Nothin Gained
harddrive8's Avatar
United States, NC, Maiden
Joined Jul 2011
+1 for the crimpers. I've never tried using regular crimps or pliers to crimp the PP, but the ones offered from powerwerx are wonderful. Three slots (15, 30, 45) and just squeeze until it "clicks" and you're done.
harddrive8 is offline Find More Posts by harddrive8
Old Mar 01, 2012, 03:03 PM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
You can buy these, to cover smaller planes (same housing)...
http://www.powerwerx.com/anderson-po...pole-sets.html
Then buy these contact pins separate. I use both 30's and 45's as needed. but definitely on like ICE 100's and 30C + Batts the 45's fit over the wire better.
http://www.powerwerx.com/anderson-po...-contacts.html
Don't forget a set of Crimps!
http://www.powerwerx.com/crimping-to...-contacts.html
heritageflyer is offline Find More Posts by heritageflyer
Old Mar 01, 2012, 03:07 PM
SnowDog1974 is offline
Find More Posts by SnowDog1974
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
LOL - that's almost exactly what I have in my shopping cart on the powerwerx site! except I was just going to get one set of the 30's and one set of the 45's. and definitely the crimper.
SnowDog1974 is offline Find More Posts by SnowDog1974
Old Mar 01, 2012, 03:13 PM
Joined Nov 2008
You know what they say about Great Minds.......
Old Mar 01, 2012, 03:30 PM
Hooked on 3DHS
lammbn's Avatar
Joined Nov 2009
I also highly suggest getting a few of these. Never flown without them. Gives me the warm fuzzies
http://www.powerwerx.com/powerpole-a...mp-2-sets.html
Old Mar 01, 2012, 03:34 PM
SamBones is offline
Find More Posts by SamBones
OCRCC @ MCAS El Toro
SamBones's Avatar
United States, CA, Irvine
Joined May 2008
Also get the insertion tool. Sometimes they are a little hard to push in with smaller gauge wire.
http://www.powerwerx.com/crimping-to...oval-tool.html
SamBones is offline Find More Posts by SamBones
Old Mar 01, 2012, 03:41 PM
FireyFate is offline
Find More Posts by FireyFate
FireyFate's Avatar
USA, AZ, Surprise
Joined Apr 2010
So is B&E graphics the place to buy a sun shade cover for an 87" Extra?
$69 doesn't seem terrible... but I was sort of hoping it would cost a little bit less than that.
FireyFate is offline Find More Posts by FireyFate
Old Mar 01, 2012, 03:56 PM
Ace4 is offline
Find More Posts by Ace4
Stick banger
Ace4's Avatar
USA, AZ, Chandler
Walmart has beach towels for like $5. I hear you tho, I'll probably order one of those shade covers before it gets 110F here.
Ace4 is offline Find More Posts by Ace4
Old Mar 01, 2012, 03:58 PM
FireyFate's Avatar
USA, AZ, Surprise
Joined Apr 2010
I think a queen fitted bed sheet might work too. Thought I'd rather pay $64 more to avoid going in to a Walmart.
But yeah, we'll be using it every weekend all summer, so the convenience of a purpose built design is worth it to me!
Old Mar 01, 2012, 04:00 PM
harddrive8's Avatar
Joined Jul 2011
For $64, I'll go into Walmart, buy your choice of beach towels and ship it to you at no extra charge
On a more serious note, those covers do look nice.
Old Mar 01, 2012, 04:56 PM
quadracer is offline
Find More Posts by quadracer
No, I won't ship it. Don't ask
quadracer's Avatar
United States, IN, Derby
Joined Feb 2012
Took the 48 Edge out today, and I think the elevator servo might be about to go. Sometimes on up elevator, it will act like it's on "super-low" rate, on or off throttle. If I jam down elevator, then back up, it will travel normally. Anyone had this issue? I checked the hinge and seams between the stab and elevator, and there is no binding. The pack was also a fresh charge. I can't remember the servo's brand, but the label on the side of the servo is HTX900, with translucent blue case. Thanks for any help at all!
quadracer is offline Find More Posts by quadracer
Old Mar 01, 2012, 04:59 PM
keninvic is offline
Find More Posts by keninvic
Joined Jan 2012
Originally Posted by marksextra View Post
I can't speak for Losi, but people sucessfully use 45 amp powerpoles on 12S sytems. Your little 51 won't be using anywhere near the juice that a 12S system uses. IF you're planning on ordering some either way, then by all means get the 45amps ones; especially since there is little difference, and no notable difference in size.
You're "little" 51..... bloody hell - I was thinking the 51 I just ordered is a big plane! lol, you guys crack me up.
keninvic is offline Find More Posts by keninvic
Old Mar 01, 2012, 05:01 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
the cross section thickness is higher on the 45 which would give it more room to send the current. The only limitation is the 45 can only crimp down to 14ga based on what powerwerx publishes on their drawing.
I think 30 would be fine. There is a slight difference between the two but the majority of the difference is that the 45 has an open place to put your wire where the 30 is closed and you have to slide your wire into it.
going4speed is offline Find More Posts by going4speed
Old Mar 01, 2012, 05:02 PM
keninvic is offline
Joined Jan 2012
--- hmmm, how do I delete this msg?
Discussion Unofficial NQD Tear Into Jet Boat Mod Thread Energy Racing Boats - Electric 14509 Today 09:31 AM
Discussion Banana Hobby Customer Support Request/Q and A Thread! banana hobby Banana Hobby 1151 Jan 28, 2016 06:03 PM
Discussion The Official AirWare Q&A Thread AndyKunz Radios 95 Feb 14, 2013 09:36 AM
Discussion THE FIRST UNOFFICIAL Parkzone Sukhoi mods thread!!!! bluemeane Micro Ready-to-Fly 27 Aug 18, 2009 12:23 AM
Megatech H2O unofficial thread and first rewiew. grk65 Racing Boats - Electric 7 Mar 05, 2007 01:09 AM
