Old Aug 18, 2012, 05:13 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
checked the needle positions on the OS GT 33 and they are about one turn out. The manual says to start at two turns out.
I thought this would have been set to two turns out from the factory.
Is a turn a whole 360 degree turn or just 180 degree turn?
going4speed is offline Find More Posts by going4speed
Old Aug 18, 2012, 05:46 PM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
One turn is 360
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Aug 18, 2012, 06:10 PM
3DHS 'native'
USA, TX, Spring
Something is wrong with this motor. about 300 flips today and only one start. Went back to the manual to check the settings. Okay two turns ... did it. Now about 100 flips later still no start. After about five flips it starts to leak fuel out of the back of the carb.
I am freakin' wrecked.
Old Aug 18, 2012, 06:12 PM
quadracer is offline
Find More Posts by quadracer
No, I won't ship it. Don't ask
quadracer's Avatar
United States, IN, Derby
Joined Feb 2012
Sounds like your plug is bad.
quadracer is offline Find More Posts by quadracer
Old Aug 18, 2012, 06:16 PM
racerman27410 is offline
Find More Posts by racerman27410
racerman27410's Avatar
United States, NC, Greensboro
Joined Dec 2006
turn both needles in 1/2 turn and try again..... 2 turns out this time of year is too rich.
racerman27410 is offline Find More Posts by racerman27410
Old Aug 18, 2012, 06:20 PM
3DHS 'native'
USA, TX, Spring
Yea it ran today at about 1 1/4 turns out. But then I followed the manual and that bit me. It's raining now so it will have to wait till tomorrow. The wife is also sick of standing there watching flip that damn prop time after time.
3DHS 'native'
USA, TX, Spring
Do these little plugs go bad that fast? It only ran once.
Old Aug 18, 2012, 06:26 PM
quadracer's Avatar
Joined Feb 2012
I wouldn't think it would go bad that often, but that's just what it sounds like to me if it's not firing.
Old Aug 18, 2012, 06:27 PM
3DHS 'native'
USA, TX, Spring
If I let it sit for an hour I get a sputter and then absolutely nothing for 100 flips.....I'll adjust the carb in the morning and see if that helps if not its a call to tower.
Old Aug 18, 2012, 06:29 PM
quadracer's Avatar
Joined Feb 2012
Try taking the plug out and cleaning the tip and electrode off. If its been running too rich, there will be carbon built up on these, and it won't spark as good as it should.
Old Aug 18, 2012, 06:38 PM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
Yep, take plug out, clean and gap it, hook it up to the ignition and with the plug out, flip the prop to check that it sparks good. some plugs go bad real fast, make sure that it is a real NGK plug usually CM-6 size for most engines. Also those little engines are a pain to start anyway, anything smaller than a 30cc i run a starter on. Even the 30's seem to take a ton of flips to start. I cant speak about OS but some of the Chinese knock offs and the DLE's are real hard to get started. It might be worth rebuilding the carb also. Ive got new enigines that sit for a long time and the carb membranes go bad.
nebwake is offline Find More Posts by nebwake
Old Aug 18, 2012, 08:50 PM
3DHS 'native'
USA, TX, Spring
Went to Orielly auto parts and bought all the CM-6 they had per quadracers suggestion of a replacement. Got a few spares now and only $3.50 each. Took the plug out and it was just coated in oil as I think the gas evaporates off and leaves the oily mess. Replaced the plug after flipping the motor 10 times to clear in out. Could not find a gap spec for the plug so just popped it in there. Turned the needles down per racerman.
Flipped in ten times about and bang! Fired up. Good start but when gave it gas it would sort of fall on its face anything over half throttle and would start to sputter real bad at full throttle. Adjusted the high speed needle a quarter turn fat and tried again. Made a big difference up top so I let it run for the 10 seconds they say for in the manual. After that is was a little rough in the upper middle. Adjusted the low speed needle just a little fatter and boom its running like a champ. I've got it to the point it starts on the second or third flip.
Thanks a ton guys!!!!
Old Aug 18, 2012, 08:58 PM
davebloomer is offline
Find More Posts by davebloomer
Fly Low, Fly 3d, Repair Often
davebloomer's Avatar
United States, OK, Weatherford
Joined Jun 2011
horray!!
davebloomer is offline Find More Posts by davebloomer
Old Aug 18, 2012, 09:32 PM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
Glad you got it resolved so I could just read about it
3DNater is offline Find More Posts by 3DNater
Old Aug 18, 2012, 10:01 PM
3DHS 'native'
USA, TX, Spring
Yea its been a challenge for sure. The whole plane has been a challenge really. Will start it again tomorrow to be sure its repeatable.
Discussion Unofficial NQD Tear Into Jet Boat Mod Thread Energy Racing Boats - Electric 15109 Yesterday 11:01 AM
Discussion Banana Hobby Customer Support Request/Q and A Thread! banana hobby Banana Hobby 1166 Aug 09, 2016 01:19 AM
Discussion The Official AirWare Q&A Thread AndyKunz Radios 95 Feb 14, 2013 08:36 AM
Discussion THE FIRST UNOFFICIAL Parkzone Sukhoi mods thread!!!! bluemeane Micro Ready-to-Fly 27 Aug 17, 2009 11:23 PM
Megatech H2O unofficial thread and first rewiew. grk65 Racing Boats - Electric 7 Mar 05, 2007 12:09 AM
