Old Feb 29, 2012, 08:45 PM
Park_aviator is offline
Find More Posts by Park_aviator
3D, 1D at a time!
Park_aviator's Avatar
United States, TX, Plano
Joined Aug 2010
Originally Posted by keninvic View Post
recently subscribed :-)
Just ordered a 51" AJ Slick - what do you guys suggest for the power connectors?
EC3? EC5? Deans Ultra?
Hacker A30-12XL
Castle Creations Phoenix Ice Lite 75 25V ESC
HITEC HS-85MGs
4S LiPo 2600mah 25C (not ordered - any recommendations?)
Ken
In Yuma, AZ for the winter.
I use deans on just about everything (except for small foamies, then I use micro JST).. A friend uses power poles on his 89" Slick though.
Park_aviator is offline Find More Posts by Park_aviator
Old Feb 29, 2012, 08:50 PM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
I run my 985's at 6.5 volts
cmala is offline Find More Posts by cmala
Old Feb 29, 2012, 09:01 PM
jonathan7x70 is offline
Find More Posts by jonathan7x70
Fly, fly, fly, fly , fly more!
jonathan7x70's Avatar
Lafayette, Louisiana
Joined Dec 2005
I really like the specs on those Savox SC-1258TG...(thanks lammbn)
Also on amazon with my member ship I get them for 60.00 ea free shipping..
Instead of asking for each different part.... How about give me some specs of a good setup.
FOR THE: 74" Edge if your just tuning in.
My list of stuff to buy.
looking for...
*Motor, and KV
The Hacker A60-6xs in a vid on 6s, 5000mah seamed kinda week
*thinking im going with the Savox SC-1258TG
*I Have a ESC
*Seperate BEC to the Rx and servos??
*6s or 8S not sure yet. and Mah Size.
Batteries I have.
*6S but there 3000 Mah, to small im sure unless you say different
* bunches of 4S in 3500 mah, could use together as 8S.
Also if I went with 8S it would have to be 2x 4S = 8S because my charger only charges up to 6S
*Prop size to match that KV
jonathan7x70 is offline Find More Posts by jonathan7x70
Old Feb 29, 2012, 09:06 PM
Brill 1 is offline
Find More Posts by Brill 1
Artillery! King of Battle!
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
Hacker A30-12XL
HITEC HS-85MGs
Ken
Sounds like a good setup! You'll love the Slick!
I use Deans plugs on everything from a 38" EPP Slick to a 103" Extra. I would recommend getting the actual Deans, not an imitation brand.
I've had good luck with Turnigy packs and with GensAce from HobbyPartz. Lots of good battery choices available.
Brill
Brill 1 is offline Find More Posts by Brill 1
Old Feb 29, 2012, 09:21 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Originally Posted by jonathan7x70 View Post
anyone using the min requirement on servos with good results?
HS-985MG
on all the 65+ airframes I've had and have with zero failures and hundreds of flights on each...killer durable smooth servo
Manta1 is offline Find More Posts by Manta1
Old Feb 29, 2012, 09:39 PM
TOFAST4U2C is offline
Find More Posts by TOFAST4U2C
"Failure is not an option"
TOFAST4U2C's Avatar
West Babylon NY
Joined Dec 2006
Originally Posted by tominator06 View Post
I have 985's in my 71 and they seem pretty good on 6v. I might try and bump them up a tad.
They were fast for sure. I tried running my 985's on A123 power and after 2 flights the 985's started to act strange in my 71 Slick. They were making a sound I never heard out of a servo before. Hitec never responded to my post in the MFG support so I returned them to Tower and replaced them with another slower servo I had on hand. It started with the right wing then the other. I replaced both then the elevator started doing it. I would love to know what was up. Here are the short videos I took.
Defective Hitec servo??? (1 min 27 sec)
Slick Tail (0 min 37 sec)
TOFAST4U2C is offline Find More Posts by TOFAST4U2C
Old Feb 29, 2012, 09:41 PM
lammbn is offline
Find More Posts by lammbn
Hooked on 3DHS
lammbn's Avatar
United States, ID, Boise
Joined Nov 2009
looking for...
*Motor, and KV
*I Have a ESC
Batteries I have.
I would look into the motrolfly 5320. Great motor and tons of power. Its what i run custom wound for 6s. 4325 just not quite enough for great performance on this plane per ken at subsonicplanes. Use a CC BEC Pro! Dont use the internal bec. It sounds like you might already have suitable packs to double up for 8s. I would do that if they are good quality packs. If your buying new packs anyways you can go either way. Just decide what other planes the packs your using might work for one day. 4s 4000 for 55-60" planes or 2x 6s 5000 for 50cc electrics. You might also get away with two 6s 3000 packs in parallel for 6s 6000. With the 5320 you might not even notice the weight.
lammbn is offline Find More Posts by lammbn
Old Feb 29, 2012, 09:54 PM
Joined Dec 2005
Also to add to post#843....
Should I worry about a high C discharge rating? It seams that on all the bigger planes videos on youtube most all of them are using 25C discharge rate... Ive been use to buying like 70-90 but that is for my Heli's.
Old Feb 29, 2012, 10:08 PM
lammbn is offline
Hooked on 3DHS
lammbn's Avatar
Joined Nov 2009
My turnigy 20c packs work just fine but... my 35c gens ace packs rock and really bring the plane alive!
Old Feb 29, 2012, 10:10 PM
Joined Dec 2005
really like the looks of the motrolfly 5320-300kv
What kind of amps is it going to be drawing?
I have a 85amp ESC.
Old Feb 29, 2012, 10:20 PM
lammbn is offline
Hooked on 3DHS
lammbn's Avatar
Joined Nov 2009
For 8s i have no idea. Figure for 2400-3000 watts. Not sure what kind of voltage sag others get at those ratings though. Ask losi. he is running one on a 71 slick. Im running 380kv for 6s on mine.
Old Feb 29, 2012, 10:25 PM
Joined Dec 2005
This is what I found so far to use for my new plane. Not to hard to pic out stuff like the small planes. Not much to choose from at this size.
for the 74" edge..
MotroFly 5320-300 ( i guess the -300 is KV ?)
Castle Creations Phoenix ICE 100
Castle Creations CC BEC Pro
Savox SC-1258TG Super Speed Titanium Gear Standard Digital Servo
Battery I have here Turnigy Nano Techs 8S, 3500Mah, 35C
Old Mar 01, 2012, 06:01 AM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
I have a 85amp ESC.
That motor with a 19x8 prop I would look for atleast a 100amp. 18x8 or 18x10 you should be good with the 85amp but that motor is soooo much more powerfull with a 19inch pop on it (insert evil smilely here) It has more than enough power with an 18inch prop and a 85amp esc though
losifanatic is offline Find More Posts by losifanatic
Old Mar 01, 2012, 06:30 AM
Joined Dec 2005
looks like its says 19x10 to 20x10.
What size ESC to get if I use the 20x10 or like a 20x8?
Reason... I was thinking the larger the prop the more prop wash the better hovering.
Old Mar 01, 2012, 06:44 AM
Kurtzz is offline
Find More Posts by Kurtzz
Pounding the Kool-Aid
Kurtzz's Avatar
First Hill of the Ozarks
Joined Dec 2008
I am using EC3's on my 51
Kurtzz is offline Find More Posts by Kurtzz
Discussion Unofficial NQD Tear Into Jet Boat Mod Thread Energy Racing Boats - Electric 14954 Jun 27, 2016 03:25 PM
Discussion Banana Hobby Customer Support Request/Q and A Thread! banana hobby Banana Hobby 1157 Jun 26, 2016 09:16 PM
Discussion The Official AirWare Q&A Thread AndyKunz Radios 95 Feb 14, 2013 08:36 AM
Discussion THE FIRST UNOFFICIAL Parkzone Sukhoi mods thread!!!! bluemeane Micro Ready-to-Fly 27 Aug 17, 2009 11:23 PM
Megatech H2O unofficial thread and first rewiew. grk65 Racing Boats - Electric 7 Mar 05, 2007 12:09 AM
