Old Aug 02, 2012, 04:18 AM
Eagle34 is offline
Find More Posts by Eagle34
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Originally Posted by SnowDog1974 View Post
Wow...that was fast...Gino already has them in stock! I guess that is the benefit of a supplier who also supplies parts to the full scale aviation industry!
6mm blind nuts:
http://www.trimcraftaviationrc.com/i...roducts_id=362
Originally Posted by gallfer View Post
You lie SnowDog! They will be ready to ship by 2pm Thursday.
Pretty darn fast responce anyway
Gino
Talk about service. Way to go Gino! You Rock.
Eagle34 is offline Find More Posts by Eagle34
Old Aug 02, 2012, 04:29 AM
Eagle34 is offline
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Originally Posted by Ohio AV8TOR View Post
Can this be done?
I have a iCharger 106b and a paraboard. For those rare days where you don't get to fly all of your packs the 106 with it's 10w discharger takes for ever. This bulb is a 50w 12v bulb and is soldered to my XT60 connector. Can I run the bulb while using the storage/discharge mode? I know it won't turn off at the set level. I may just add a second bulb and connect the balance voltage cell reader to get discharged in the ball park and finish off on the charger. Any suggestions/improvements appreciated.
I don't know about running the discharge function along with your light but the light itself should do a pretty good job at bringing the pack voltage down. If nothing else rig up a second light and plug the pack in the middle of the parallel board. You could just use the parallel board with no other attachments connected that way. You might want to put one of those cheap voltage checkers on your balance tap to monitor the voltage as you discharge.
Good idea BTW. Where did you find the big 50W 12V bulb?
Old Aug 02, 2012, 05:37 AM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Originally Posted by SteveT. View Post
You have 87" wings etc. in these bags....Do you think 89" Slick wings and stab will fit?
SteveT
There is a lot of space on the wing side, I don't see 1" a wing side a problem. With the bag standing on it's side and the wing installed there is still 4" before the end of the bag. My stab the way I have it in as one piece is 36" wide with the stab tube installed and there is around 3/4" on each side. If you have an orange Slick they make this bag in orange also.
PM Joe as he has this same bag and have him try his slick in it.
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Aug 02, 2012, 05:40 AM
On loan to Texas
Joined Oct 2005
I will get you a brand and part number but we had them at work for 12v track lighting, I was thinking the same thing with the voltage monitor monitor plugged in on the balance line.
Old Aug 02, 2012, 05:45 AM
On loan to Texas
Joined Oct 2005
Has anyone heard when the Omega 130 motors will be back in stock>
Old Aug 02, 2012, 07:12 AM
Eagle34 is offline
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
No worries that should be enough info. I didn't realize that track llighting was 12V. When I get home I'll stop by the lighting supply place and see what they have.
Old Aug 02, 2012, 07:21 AM
gallfer is online now
Find More Posts by gallfer
ONEHANDRC
gallfer's Avatar
United States, WI, Genoa City
Joined Dec 2007
Service
Ain't good lookin & can't dance. I HAVE to give good service!
gallfer is online now Find More Posts by gallfer
Old Aug 02, 2012, 07:50 AM
RotorJockey is offline
Find More Posts by RotorJockey
Fly Low-Crash-Rebuild-Repeat !
RotorJockey's Avatar
Jackson, MO
Joined May 2009
LOL, made me choke on my coffee!
RotorJockey is offline Find More Posts by RotorJockey
Old Aug 02, 2012, 08:18 AM
On loan to Texas
Joined Oct 2005
Here are bulbs I am using
Old Aug 02, 2012, 08:29 AM
Eagle34 is offline
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Cool thanks. From your picture it looked like a regular flood lamp, now I see its a mr16 halogen bulb, I'm pretty sure I've seen those at Lowes. Save me a trip to the lighting store.
Old Aug 02, 2012, 12:51 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
.....build a ramp and a jump--for a golf cart.
Irg...you've gotta make it to Nall next year...
Bivens is offline Find More Posts by Bivens
Old Aug 02, 2012, 01:13 PM
Ace4 is offline
Find More Posts by Ace4
Stick banger
Ace4's Avatar
USA, AZ, Chandler
Ace it is an easy fix. I used my wife's seam ripper from the inside and removed both vertical spacers making it one large side pouch. As you can see in the photo it easily fits the SHP's stabs with the carbon rod installed. There really was not a good place for the stab carbon rod so this worked out nicely. The large side tube pocket for the main wing tube secures just fine for the large tube but I was worried the smaller tube could fall out. The other advantage of the stab going in with the tub is it places the elevator control arms (mine are 2" SWB's) in the center of this pocket where they are not under and side pressure. This is going to work out fantastic. We are 106-108 for the rest of the week so not really going to check it out soon.
Do the SFGs fit in the bag somewhere?
Ace4 is offline Find More Posts by Ace4
Old Aug 02, 2012, 01:59 PM
horton is offline
Find More Posts by horton
ExtremeFlightRC.com
horton's Avatar
Joined Jun 2006
Just a heads up... 130g Omega motors back in stock!
horton is offline Find More Posts by horton
Site Sponsor
Old Aug 02, 2012, 02:05 PM
SnowDog1974 is offline
Find More Posts by SnowDog1974
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
woot! hopefully this is the start of many wonderful "back in stock" announcements!
SnowDog1974 is offline Find More Posts by SnowDog1974
Old Aug 02, 2012, 02:23 PM
dougbo is offline
Find More Posts by dougbo
Proverbs 12:15
dougbo's Avatar
USA, WA, Richland
Joined Nov 2009
Followed by another "special sale" ... Please.
Doug B.
dougbo is offline Find More Posts by dougbo
Discussion Unofficial NQD Tear Into Jet Boat Mod Thread Energy Racing Boats - Electric 15109 Today 11:01 AM
Discussion Banana Hobby Customer Support Request/Q and A Thread! banana hobby Banana Hobby 1166 Aug 09, 2016 01:19 AM
Discussion The Official AirWare Q&A Thread AndyKunz Radios 95 Feb 14, 2013 08:36 AM
Discussion THE FIRST UNOFFICIAL Parkzone Sukhoi mods thread!!!! bluemeane Micro Ready-to-Fly 27 Aug 17, 2009 11:23 PM
Megatech H2O unofficial thread and first rewiew. grk65 Racing Boats - Electric 7 Mar 05, 2007 12:09 AM
